查看: 1631|回復: 0
基于51單片機和Proteus仿真的天車控制系統
#include "AT89X52.h"
#include "intrins.h"
// Definition for output port and input pins
#define out_port  P3
unsigned char const sequence[8] = {0x02,0x06,0x04,0x0c,0x08,0x09,0x01,0x03};
sbit key_for = P1 ^ 2;
sbit key_rev = P1 ^ 3;
sbit Inc = P1 ^ 0;
sbit Dec = P1 ^ 1;
sbit Dir = P2 ^ 0;
sbit PWM = P2 ^ 1;
int speed;
void delay(unsigned int j)
  for(; j>0; j--);
void delayms(unsigned int j)
  unsigned char i;
  for(; j>0; j--)
    i = 120;
    while (i--);
void DCMotoDeal(void)
      if(!Inc)
         speed = speed > 0 ? speed - 1 : 0;
      if(!Dec)
         speed = speed < 500 ? speed + 1 : 500;
      PWM=1;
      delay(speed);
      PWM=0;
      delay(500-speed);
void StepMotoDeal(void)
    unsigned char i;
    if (!key_for)
       i = i<8 ? i+1 : 0;
         out_port = sequence[i];
         delayms(50);
    else if (!key_rev)
        i = i>0 ? i-1 : 7;
        delayms(50);
void main(void)
   // 選擇方向和時間
   Dir = 1;
   if (Dir)
      speed = 400;
      speed = 100;
   out_port = 0x03;
      DCMotoDeal();
      StepMotoDeal();
基于51單片機和Proteus仿真的天車控制系統.zip
56.85 KB, 下載次數: 6, 下載積分: 黑幣 -5
