基于51單片機的負載平衡監控系統仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
2019-5-9 17:10 上傳
負載平衡監控系統單片機源程序如下:
#include <AT89X52.h>
unsigned char code SEGtable[]=
0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0x00
sbit sw7 = P0 ^ 7;
sbit sw6 = P0 ^ 6;
sbit sw5 = P0 ^ 5;
sbit sw4 = P0 ^ 4;
sbit sw3 = P0 ^ 3;
sbit sw2 = P0 ^ 2;
sbit sw1 = P0 ^ 1;
sbit sw0 = P0 ^ 0;
sbit FMQ = P1 ^ 7;
bit alarmflg = 0;
unsigned RxByte = 0x00;
unsigned char counter = 0;
unsigned char Scounter,Lcounter; //分別存放自己的水位狀態和遠方的水位狀態
unsigned char FMcounter = 0x02; //報警狀態參數
void DelayFM(unsigned int x)
unsigned char t;
while(x--)
for(t=0;t<120;t++);
//蜂鳴器驅動函數,參數為發聲聲調
void FM(unsigned char x)
unsigned char i;
for(i=0;i<100;i++)
FMQ = ~FMQ;
DelayFM(x);
FMQ = 0;
void Delayms(unsigned int MS) //延時ms函數
unsigned int i,j;
for( i=0;i<MS;i++)
for(j=0;j<1141;j++);
void InitUART(void)
TMOD = 0x20; //9600bps
SCON = 0x50;
TH1 = 0xFD;
TL1 = TH1;
PCON = 0x00;
EA = 1;
ES = 1;
TR1 = 1;
void Send(unsigned char x)
SBUF = x;
while(TI == 0);
TI = 0;
void Serial(void) interrupt 4 using 1
unsigned char RxByte;
if(RI == 1)
RxByte = SBUF;
RI = 0;
P2 = RxByte;
switch(RxByte)
case 0x00: Lcounter = 0;break;
case 0xf9: Lcounter = 1;break;
case 0xa4: Lcounter = 2;break;
case 0xb0: Lcounter = 3;break;
case 0x99: Lcounter = 4;break;
case 0x92: Lcounter = 5;break;
case 0x82: Lcounter = 6;break;
case 0xF8: Lcounter = 7;break;
case 0x80: Lcounter = 8;break;
default:{};
if(Scounter > Lcounter)
if((Scounter - Lcounter) > 2) //如果超過2%
FMcounter = Scounter - Lcounter;
alarmflg = 1; //報警標志位
alarmflg = 0;
alarmflg = 0; //清除
main(void)
InitUART();
Delayms(100);
P0 = 0xFF;
counter = 0;
counter = counter + (unsigned char)sw7;
counter = counter + (unsigned char)sw6;
counter = counter + (unsigned char)sw5;
counter = counter + (unsigned char)sw4;
counter = counter + (unsigned char)sw3;
counter = counter + (unsigned char)sw2;
counter = counter + (unsigned char)sw1;
counter = counter + (unsigned char)sw0; //計算當前的負載
Scounter = counter;
Send(SEGtable[counter]);
if(alarmflg == 1)
FM(FMcounter);
2019-5-9 18:57 上傳
全部資料51hei下載地址:
基于51單片機和Proteus仿真的負載平衡監控系統.zip
(66.79 KB, 下載次數: 9)
2019-5-9 17:09 上傳
下載積分: 黑幣 -5
