查看: 9523|回復(fù): 4
單片機24小時制時鐘顯示,且可調(diào)鬧鐘程序
ID:531603 發(fā)表于 2019-5-9 15:24 | 顯示全部樓層 |閱讀模式
運用6位集成數(shù)碼管;蜂鳴器;4個按鍵開關(guān);(我用的是4*4掃描按鍵的開關(guān)沒有改圖,不影響)
k1為模式按鍵,第一次按下調(diào)整時,第二次按下調(diào)整分,第三次按下調(diào)整秒;
K2為調(diào)鬧鐘(同K1);
k3為時間加一;
k4為時間減一;
proteus接發(fā)如下:
程序如下:
#include <reg51.h>
void delay(unsigned int i)
        unsigned int k;
        for(k = 0; k < i; k++);
unsigned char count = 0;
unsigned char miao = 0, min = 0, hour = 0;
unsigned char miao2 = 0, min2 = 0, hour2 = 0;
unsigned int b = 0, c = 0, d = 0; i = 0, bm = 0, btime = 0;
sbit keymode = P2^3;
sbit keyclock = P2^2;
sbit keyup = P2^1;
sbit keydown = P2^0;
sbit beep_b = P3^6;
void dispall();
void key_mode();
void key_clock();
void key_scan();
void key_scan2();
void set();
void set2();
void disp();
void disp2();
void beep();
        TMOD = 0x10;
        TH1 = (65536 - 50000)/256;                                        //重新設(shè)置T1計數(shù)初值高8位
        TL1 = (65536 - 50000)%256;                                        //重新設(shè)置T1計數(shù)初值低8位
        ET1 = 1;        //開放T1中斷允許
        EX1 = 1;
        IT1 = 1;
        EA = 1;        //開放總中斷允許
        TR1 = 1;        //啟動T1開始計數(shù)
                key_scan();
                key_scan2();
                disp();
                disp2();
                beep();
void key_mode()
        if(!keymode)
                delay(1000);
                if(!keymode)
                        b++;
                        if(b > 3)
                                b = 0;
                while(!keymode);
void key_clock()
        if(!keyclock)
                delay(1000);
                if(!keyclock)
                        c++;
                        if(c > 3)
                        c = 0;
                d++;
                while(!keyclock);
void key_scan()
        P2=0x0f;
        key_mode();
        if(b == 1)
                c = 0;
                disp(); set();
        else if(b == 2)
                c = 0;
                disp(); set();
        else if(b == 3)
                c = 0;
                disp(); set();
void key_scan2()
        P2=0x0f;
        key_clock();
        if(c == 1)
                b = 0;
                disp2(); set2();
        else if(c == 2)
                b = 0;
                disp2(); set2();
        else if(c == 3)
                b = 0;
                disp2(); set2();
void set()
                if(keyup == 0)        //時間增加按鍵
                        if(b == 1) {hour++;        if(hour > 23)        hour = 0;}
                        else if(b == 2) {min++; if(min > 59) min = 0;}
                        else if(b == 3) {miao++; if(miao > 59) miao = 0;}
                while(!keyup);
                if(keydown == 0)                                                        //時間減少按鍵
                        if(b == 1) {if(hour != 0) hour--; else hour = 23;}
                        else if(b == 2) {if(min != 0) min--; else min = 59;}
                        else if(b == 3) {if(miao != 0) miao--; else miao = 59;}
                while(!keydown);
void set2()
                        if(c == 1) {hour2++;        if(hour2 > 23)        hour2 = 0;}
                        else if(c == 2) {min2++; if(min2 > 59) min2 = 0;}
                        else if(c == 3) {miao2++; if(miao2 > 59) miao2 = 0;}
                while(!keyup);
                        if(c == 1) {if(hour2 != 0) hour2--; else hour2 = 23;}
                        else if(c == 2) {if(min2 != 0) min2--; else min2 = 59;}
                        else if(c == 3) {if(miao2 != 0) miao2--; else miao2 = 59;}
                while(!keydown);
int timer() interrupt 3
        count++;        //50ms計數(shù)器加1
        if(count == 20)        //1s時間到
                count = 0;
                if(bm)
                {btime ++;
                miao++;
                if(miao == 60)
                        miao = 0;
                        min++;
                        if(min == 60)
                                min = 0;
                                hour++;
                                if(hour == 24) hour = 0;
void disp()
        unsigned char led[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
        if(b == 1)
                P1 = 0x3e; P0 = led[hour/10]; delay(100);
                P1 = 0x3d; P0 = led[hour%10]; delay(100);
        else if(b == 2)
                P1 = 0x3b; P0 = led[min/10]; delay(100);
                P1 = 0x37; P0 = led[min%10]; delay(100);
        else if(b == 3)
        {        P1 = 0x2f; P0 = led[miao/10]; delay(100);
                P1 = 0x1f; P0 = led[miao%10]; delay(100);
        else if((b == 0) && (c == 0))
                dispall();
void disp2()
        if(c == 1)
                P1 = 0x3e; P0 = led[hour2/10]; delay(100);
                P1 = 0x3d; P0 = led[hour2%10]; delay(100);
        else if(c == 2)
                P1 = 0x3b; P0 = led[min2/10]; delay(100);
                P1 = 0x37; P0 = led[min2%10]; delay(100);
        else if(c == 3)
        {        P1 = 0x2f; P0 = led[miao2/10]; delay(100);
                P1 = 0x1f; P0 = led[miao2%10]; delay(100);
                dispall();
void dispall()
  P1 = 0x37; P0 = 0x80; delay(100); P0 = led[min%10]; delay(100);
  P1 = 0x3d; P0 = 0x80; delay(100); P0 = led[hour%10]; delay(100);
void beep()
        if((hour==hour2) && (min==min2) && (miao==miao2) && (d != 0))        //計數(shù)10秒后 P3^6 輸出低電平,啟動蜂鳴器
                bm = 1;
                beep_b = 0;
        if(btime == 10)
                beep_b = 1;
                bm = 0;
                btime = 0;
                d = 0;
24小時制可調(diào)鬧鐘.rar
29.28 KB, 下載次數(shù): 56, 下載積分: 黑幣 -5
參與人數(shù) 1黑幣 +50 收起 理由
ID:328014 發(fā)表于 2019-5-9 18:19 | 顯示全部樓層
好東東,能分享下仿真工程文件嗎?
ID:448556 發(fā)表于 2019-5-13 11:26 | 顯示全部樓層
自己建立一個工程區(qū)仿真也可以 的啊
ID:537650 發(fā)表于 2019-5-14 09:55 | 顯示全部樓層
我是學(xué)生能問一下六個數(shù)碼管是怎么接的嗎?
ID:564003 發(fā)表于 2019-6-16 23:47 | 顯示全部樓層
數(shù)碼管顯示一部分是怎么回事吖
