查看: 1533|回復: 0
單片機程序有個錯誤,麻煩專家看一下 求幫助
ID:530742 發表于 2019-5-8 16:16 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#include"13c02.h"
sbit dula=P2^6;
sbit wela=P2^7;
sbit rs=P3^5;
sbit lcden=P3^4;
sbit s1=P3^0;
sbit s2=P3^1;
sbit s3=P3^2;
sbit rd=P3^7;
sbit beep=P2^3;
uchar count,slnum;
char miao,shi,fen;
uchar code table[]=" 2008-9-30 MON";
void delay(uint z)
  uint x,y;
  for(x=z;x>0;x--)
     for(y=110;y>0;y--);
void di()
        beep=0;
        delay(100);
        beep=1;
void write_com(uchar com)
        rs=0;
        lcden=0;
        P0=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_date(uchar date)
        rs=1;
        lcden=0;
        P0=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_sfm(uchar add,uchar date)
    uchar shi,ge;
    shi=date/10;
    ge=date%10;
    write_com(0x80+0x40+add);
    write_date(0x30+shi);
    write_date(0x30+ge);
void init()
   uchar num;
   rd=0;
   dula=0;
   wela=0;
   lcden=0;
   fen=0;
   miao=0;
   shi=0;
   count=0;
   slnum=0;
   init_13c02();
   write_com(0x38);
   write_com(0x0c);
   write_com(0x06);
   write_com(0x01);
   write_com(0x80);
   for(num=0;num<15;num++)
                        write_date(table[num]);
                        delay(5);
                write_com(0x80+0x40+6);
                write_date(':');
                delay(5);
                write_com(0x80+0x40+9);
                write_date(':');
                delay(5);
        miao=read_add(1);
        fen=read_add(2);
        shi=read_add(3);
        write_sfm(10,miao);
        write_sfm(7,fen);
        write_sfm(4,shi);
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
void keyscan()
        if(s1==0)
                delay(5);
                   if(s1==0);
                        slnum++;
                           while(!s1);
                           di();
                           if(slnum==1)
                                   TR0=0;
                                   write_com(0x80+0x40+10);
                                   write_com(0x0f);
                           if(slnum==2);
                                   write_com(0x80+0x40+7);
                           if(slnum==3)
                                   write_com(0x80+0x40+4);
                           if(slnum==4)
                                   slnum=0;
                                   write_com(0x0c);
                                   TR0=1;
   if(slnum!=0)
                   if(s2==0)
                           delay(5);
                           if(s2==0)
                           while(!s2);
                           di();
                           if(slnum==1)
                                   miao++;
                                   if(miao==60)
                                   miao=0;
                                write_sfm(10,miao);
                                write_add(1,miao);
                        if(slnum==2)
                                fen++;
                                if(fen==60)
                                fen=0;
                                write_sfm(7,fen);
                                write_add(2,fen);
                        if(slnum==3)
                                shi++;
                                if(shi==24)
                                shi=0;
                                write_sfm(4,shi);
                                write_add(3,shi);
        if(s3==0)
                delay(5);
                if(s3==0)
                        while(!s3);
                        di();
                        if(slnum==1)
                                miao--;
                                if(miao==-1)
                                        miao=59;
                                write_sfm(10,miao);
                                write_add(1,miao);
                        if(slnum==2)
                                fen--;
                                if(fen==-1)
                                        fen=59;
                                write_sfm(7,fen);
                                write_add(2,fen);
                        if(slnum==3)
                                shi--;
                                if(shi==-1)
                                shi=23;
                                write_sfm(4,shi);
                                write_add(3,shi);
                   init();
                        keyscan();
        void timer0() interrupt 1
                count++;
                if(count==20)
                        count=0;
                        miao++;
                        if(miao==60)
                                miao=0;
                                fen++;
                                if(fen==60)
                                        fen=0;
                                        shi++;
                                        if(shi==24)
                                                shi=0;
                                write_sfm(4,shi);
                                write_add(3,shi);
                        write_sfm(7,fen);
                        write_add(2,fen);
                        write_sfm(10,miao);
                        write_add(1,miao);
