查看: 1572|回復: 0
單片機信號燈程序
ID:528461 發表于 2019-5-6 13:55 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>
#include<rtx51tny.h>
sbit con=P3^2;                 //存儲寄存器的時鐘輸入。
sbit snr=P2^2;                //上升沿時移位寄存器中的數據進入存儲寄存器,
sbit sng=P2^3;                    //下降沿時存儲寄存器中的數據保持不變。
sbit sny=P2^4;                    //應用時通常將ST_CP置為低點平,
sbit ewr=P2^5;                    //移位結束后再在ST_CP端產生一個正脈沖更新顯示數據。
sbit ewg=P2^6;
sbit ewy=P2^7;
sbit KEY1 = P1^0;
sbit KEY2 = P1^1;
sbit LA=P2^0;
sbit LB=P2^1;
uchar minute=0;
uchar hour=0;
uchar code DSY_DUAN[]={0x3f,0x06,0x5b,0x4f,0x66,
                                                0x6d,0x7d,0x07,0x7f,0x6f};
unsigned char code tew[]={0x06,0x7f,0x06,0x07,0x06,0x7d,0x06, 0x6d,
                                                        0x06,0x66,0x06,0x4f,0x06,0x5b,0x06,0x06,
                                                        0x06,0x3f,0x3f,0x6f,0x3f,0x7f,0x3f,0x07,
                                                        0x3f,0x7d,0x3f,0x6d,0x3f,0x66,0x3f,0x4f,
                                                        0x3f,0x5b,0x3f,0x06,0x3f,0x3f,0x06,0x66,
                                                        0x06,0x4f,0x06,0x5b,0x06,0x06,0x06,0x3f,
                                                         0x3f,0x6f,0x3f,0x7f,0x3f,0x07,0x3f,0x7d,
                                                        0x3f,0x6d,0x3f,0x66,0x3f,0x4f,0x3f,0x5b,
                                                        0x3f,0x06,0x3f,0x3f,0x3f,0x4f,0x3f,0x5b,
                                                        0x3f,0x06,0x3f,0x3f};
                                             //東西方向數碼管倒計時段碼表
unsigned char code tsn[]={0x06,0x66,0x06,0x4f,0x06,0x5b,0x06,0x06,
                                                        0x3f,0x5b,0x3f,0x06,0x3f,0x3f,0x3f,0x4f,
                                                        0x3f,0x5b,0x3f,0x06,0x3f,0x3f,0x06,0x7f,
                                                        0x06,0x07,0x06,0x7d,0x06,0x6d,0x06,0x66,
                                            //南北方向數碼管倒計時段碼表
void delay(uint t)
   uchar i;
   while(t--);
   for(i=0;i>250;i++);
void job0() _task_ 0
    os_create_task(1);
        os_create_task(2);
        os_create_task(3);
        os_create_task(4);
        os_create_task(5);
        os_delete_task(0);
void job1() _task_ 1                  //十字路口數碼管倒計時部分
        uchar i;
        SCON=0x00;                          //配置串口通信為方式0,八位同步移位寄存器
        con=0;                                  //con先拉低,后拉高
           for(i=0;i<38;i++)             //每兩個數碼管倒計時部分共有76個段碼,
                                      //所以需要乘2才能到達下一個狀態。
                           SBUF=tsn[i*2];              //南北方向9-15數碼管掃描
                           while(!TI);
                           TI=0;                          //軟件清零部分;
                           SBUF=tsn[i*2+1];      //南北方向1-7數碼管掃描
                           while(!TI);
                           TI=0;
                        SBUF=tew[i*2];
                           while(!TI);
                           TI=0;
                        SBUF=tew[i*2+1];
                           while(!TI);
                           TI=0;                      //接收完畢信號;
                           con=1;                           //595芯片ST_CP端工作;
                           os_wait(K_IVL,10,0);       //延時100ms;
                           con=0;                           //595芯片ST_CP端停止工作;
void job2() _task_ 2
                minute++;                    //分鐘加一
                if(minute==60)               //分鐘滿60;
                        minute=0;                //分鐘清零;
                        hour++;                  //小時加一;
                        if(hour==60)             //小時滿60;
                                hour=0;              //小時清零;
                os_wait(K_IVL,100,0);        //延時1s;
void job3() _task_ 3                    //按鍵檢測
                if(P1!=0xff)                //有鍵被按下;
                        delay(10);
                        if(KEY1==0)                    //如果第一個鍵被按下,分鐘個位加一;
                                minute=minute%10+1;
                                if(minute==60)      //分鐘滿60清零
                                        minute=0;
                        else if(KEY2==0)        //如果第二個鍵被按下,小時個位加一;
                                hour=hour%10+1;
                                if(hour==60)        //小時滿60清零
                                        hour=0;
                        while(P1!=0xff);             //判斷抬起;
void job4() _task_ 4                    //計時數碼管掃描程序
                LA=1,LB=1;                            //P2口前兩個管腳輸入
                P0=DSY_DUAN[minute%10];                //分個
                delay(500);
                LA=1,LB=0;
                P0=DSY_DUAN[hour%10];           //時個
                delay(500);
                LA=0,LB=1;
                P0=DSY_DUAN[minute/10];
                delay(500);
                LA=0,LB=0;
                P0=DSY_DUAN[hour/10];
                delay(500);
void job5() _task_ 5               //南北方向交通燈
            snr=0;sng=1;sny=1;                                                           //南北紅,東西綠
         ewr=1;ewg=0;ewy=1;
         os_wait(K_IVL,150,0);
         snr=0;sng=1;sny=1;                                                           //南北紅,東西黃
         ewr=1;ewg=1;ewy=0;
         ewr=1;ewg=1;ewy=1;
         ewr=1;ewg=1;ewy=0;
         ewr=1;ewg=1;ewy=1;
         snr=1;sng=0;sny=1;                                                           //南北綠,東西紅
         ewr=0;ewg=1;ewy=1;
         snr=1;sng=1;sny=0;                                                           //南北黃,東西紅
         ewr=0;ewg=1;ewy=1;
         snr=1;sng=1;sny=1;                                                           //南北黃,東西紅
         ewr=0;ewg=1;ewy=1;
         ewr=0;ewg=1;ewy=1;
         ewr=0;ewg=1;ewy=1;
