一個51單片機的項目提供源碼 供參考
#include <reg52.h>
sbit DS=P2^4; //define interface
uint temp; // variable of temperature
uchar flag1; // sign of the result positive or negative
sbit dula=P2^0; //段選信號的鎖存器控制
sbit wela=P2^1; //位選信號的鎖存器控制
sbit cs88=P2^2; //點陣管的鎖存器控制 cs88=0;//關點陣管
sbit LCD1602=P2^5; //定義LCD1602使能端,用于HJ-C52實驗板復位,與本實驗無關
sbit DS1302=P1^2; //定義DS1302時鐘使能端,用于HJ-C52實驗板復位,與本實驗無關
sbit SD=P2^6; //定義SD卡使能端,用于HJ-C52實驗板復位,與本實驗無關
void cmg88()//關數碼管,點陣函數 cmg88();//關數碼管,點陣函數
dula=1;
P0=0x00;
dula=0;
cs88=0x00;
P0=0x00;
cs88=1;
sbit beep=P1^3; // 定義高溫時L3 點亮
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
unsigned char code table1[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,
0x87,0xff,0xef};
void delay(uint count) //delay
uint i;
while(count)
i=200;
while(i>0)
i--;
count--;
void dsreset(void) //send reset and initialization command
uint i;
DS=0;
i=103;
while(i>0)i--;
DS=1;
i=4;
while(i>0)i--;
bit tmpreadbit(void) //read a bit
uint i;
bit dat;
DS=0;i++; //i++ for delay
DS=1;i++;i++;
dat=DS;
i=8;while(i>0)i--;
return (dat);
uchar tmpread(void) //read a byte date
uchar i,j,dat;
dat=0;
for(i=1;i<=8;i++)
j=tmpreadbit();
dat=(j<<7)|(dat>>1); //讀出的數據最低位在最前面,這樣剛好一個字節在DAT里
return(dat);
void tmpwritebyte(uchar dat) //write a byte to ds18b20
uint i;
uchar j;
bit testb;
for(j=1;j<=8;j++)
testb=dat&0x01;
dat=dat>>1;
if(testb) //write 1
DS=0;
i++;i++;
DS=1;
i=8;while(i>0)i--;
DS=0; //write 0
i=8;while(i>0)i--;
DS=1;
i++;i++;
void tmpchange(void) //DS18B20 begin change
dsreset();
delay(1);
tmpwritebyte(0xcc); // address all drivers on bus
tmpwritebyte(0x44); // initiates a single temperature conversion
uint tmp() //get the temperature
float tt;
uchar a,b;
dsreset();
delay(1);
tmpwritebyte(0xcc);
tmpwritebyte(0xbe);
a=tmpread();
b=tmpread();
temp=b;
temp<<=8; //two byte compose a int variable
temp=temp|a;
tt=temp*0.0625;
temp=tt*10+0.5;
return temp;
void display(uint temp) //顯示程序
uchar A1,A2,A2t,A3;
A1=temp/100;
A2t=temp%100;
A2=A2t/10;
A3=A2t%10;
dula=0;
P0=table[A1]; //顯示百位
dula=1;
dula=0;
wela=0;
P0=0x7e;
wela=1;
wela=0;
delay(1);
dula=0;
P0=table1[A2]; //顯示十位
dula=1;
dula=0;
wela=0;
P0=0x7d;
wela=1;
wela=0;
delay(1);
P0=table[A3]; //顯示個位
dula=1;
dula=0;
P0=0x7b;
wela=1;
wela=0;
delay(1);
uchar a;
//主板初始化 因51單片機芯片開機時各個IO口輸出為高電平,加上以下源代碼是為了防止各種外部模塊誤動作
//DS1302=0; //關DS1302模塊,與本實驗無關
SD=0;//關SD卡模塊,與本實驗無關
LCD1602=0;//關LCD1602模塊,與本實驗無關
cs88=0;//關點陣管
do
tmpchange();
for(a=10;a>0;a--)
display(tmp());
if(temp>=310) //當溫度超過31度(僅作試驗用,實際可設為其他更高的值),L3發光管便會發光。
P1=0xFE;
beep=0;
beep=1;
P1=0xfE;
} while(1);
超溫報警項目.7z
2019-5-8 02:14 上傳
下載積分: 黑幣 -5
10.17 KB, 下載次數: 4, 下載積分: 黑幣 -5
51單片機 超溫警報
