#include<reg51.h>
int i=0,s=0,f=0,z=0;ri=21,k=0,n=0;//最多只能調(diào)到日月年我沒加上去
sbit E=P2^7;
sbit RW=P2^5;
sbit RS=P2^6;
sbit k1=P2^0;
sbit k2=P2^1;
sbit k3=P2^2;
sbit k4=P2^3;
sbit k5=P2^4;
sbit beep=P1^5;
//uchar sz[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar sz[]="TIME ";
uchar table2[]="DATE 2019-4-";
void Lcd1602_Delay1ms(int c) //誤差 0us
uchar a,b;
for (; c>0; c--)
for (b=199;b>0;b--)
for(a=1;a>0;a--);
LCDWriteCom(uchar com)
E=0;
RW=0;
RS=0;
P0=com;
E=1;
Lcd1602_Delay1ms(1);
E=0;
Lcd1602_Delay1ms(5);
LCDWriteDat(uchar dat)
E=0;
RW=0;
RS=1;
P0=dat;
E=1;
E=0;
LCDInit()
LCDWriteCom(0x38);
LCDWriteCom(0x0c);
LCDWriteCom(0x06);
LCDWriteCom(0x01);
zd() interrupt 1
TH0=0x3c;
TL0=0xb0;
i++;
if(i==20)
i=0;
s++;
if(s==60) //秒
s=0;
f++;
if(f==60) //分
f=0;
z++;
if(z==24) //時
z=0;ri++;//日
main()
TMOD=0x01; //定時器T0中斷
TH0=0x3c;
TL0=0xb0;
ET0=1;
EA=1;
TR0=1;
LCDInit();
LCDWriteCom(0xc0);
for(i=0;i<13;i++)
LCDWriteDat(table2[i]);
LCDWriteCom(0x80);
for(i=0;i<6;i++)
LCDWriteDat(sz[i]);
if(k1==0)//按鈕k1 小時+1
Lcd1602_Delay1ms(100);
if(k1==0)
z++;
if(z==24)
z=0;
if(k2==0)
Lcd1602_Delay1ms(100);//按鈕k2 分+1
if(k2==0)
f++;
if(f==60)
f=0;z++;
if(k3==0)
Lcd1602_Delay1ms(100); //按鈕k3 秒+1
if(k3==0)
s++;
if(s==60)
s=0;f++;
if(k4==0)
Lcd1602_Delay1ms(10);
if(k4==0)
k++;
if(k==24)
k=0;
LCDWriteCom(0x85);
LCDWriteDat(0x30+(k/10));
LCDWriteCom(0x86);
LCDWriteDat(0x30+(k%10));
Lcd1602_Delay1ms(500);
if(k5==0)
if(k5==0)
n++;
if(n==60)
n=0;
LCDWriteCom(0x88);
LCDWriteDat(0x30+(n/10));
LCDWriteCom(0x89);
LCDWriteDat(0x30+(n%10));
if((z==k)&&(f==n))
beep=~beep;
LCDWriteCom(0x85);
LCDWriteDat(0x30+(z/10));
LCDWriteCom(0x86);
LCDWriteDat(0x30+(z%10));
LCDWriteCom(0x87);
LCDWriteDat(':');
LCDWriteCom(0x88);
LCDWriteDat(0x30+(f/10));
LCDWriteCom(0x89);
LCDWriteDat(0x30+(f%10));
LCDWriteCom(0x8a);
LCDWriteDat(':');
LCDWriteCom(0x8b);
LCDWriteDat(0x30+(s/10));
LCDWriteCom(0x8c);
LCDWriteDat(0x30+(s%10));
LCDWriteCom(0xcc);
LCDWriteDat(0x30+(ri/10));
LCDWriteDat(0x30+(ri%10));
