查看: 2311|回復: 1
基于QX-mini51的超聲測距程序,希望能幫到你們 單片機源程序如下:
ID:514733 發表于 2019-5-2 15:15 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
* 【實驗平臺】: QX-MINI51 單片機開發板
* 【外部晶振】: 11.0592mhz
* 【主控芯片】: STC89C52
* 【編譯環境】: Keil μVisio3
* 【程序功能】: LCD1602顯示超聲波測距
* 【使用說明】: 見下文
SMC1602A(16*2)模擬口線接線方式
連接線圖:
       |LCM-----51   |        LCM-----51   |        LCM------51      |
       |DB0-----P2.0 |        DB4-----P2.4 |        RW-------P0.6    |
       |DB1-----P2.1 |        DB5-----P2.5 |        RS-------P0.7    |
       |DB2-----P2.2 |        DB6-----P2.6 |        E--------P0.5    |
       |DB3-----P2.3 |        DB7-----P2.7 |        VLCD接1K電阻到GND|
接線:模塊TRIG接 P1.2  ECH0 接P1.1
本程序源碼只供學習參考,不得應用于商業用途,如有需要請聯系作者。
[注:AT89x51使用12M或11.0592M晶振,實測使用11.0592M]
#include <AT89x51.H>                //器件配置文件
#include <intrins.h>
#define  RX  P1_1
#define  TX  P1_2
#define LCM_RW  P0_6 //定義LCD引腳
#define LCM_RS  P0_7
#define LCM_E   P0_5
#define LCM_Data  P2
#define Busy    0x80 //用于檢測LCM狀態字中的Busy標識
void LCMInit(void);
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);
void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);
void Delay5Ms(void);
void Delay400Ms(void);
void Decode(unsigned char ScanCode);
void WriteDataLCM(unsigned char WDLCM);
void WriteCommandLCM(unsigned char WCLCM,BuysC);
unsigned char ReadDataLCM(void);
unsigned char ReadStatusLCM(void);
unsigned char code mcustudio[] ={" WWW*QXMCU*COM  "};
unsigned char code email[] =    {"***@QQ.COM"};
unsigned char code Cls[] =      {"                "};
unsigned char code ASCII[15] =    {'0','1','2','3','4','5','6','7','8','9','.','-','M'};
static unsigned char DisNum = 0; //顯示用指針
       unsigned int  time=0;
           unsigned long S=0;
           bit      flag =0;
           unsigned char disbuff[4]           ={ 0,0,0,0,};
//寫數據
        ReadStatusLCM(); //檢測忙
        LCM_Data = WDLCM;
        LCM_RS = 1;
        LCM_RW = 0;
        LCM_E = 0; //若晶振速度太高可以在這后加小的延時
        LCM_E = 0; //延時
        LCM_E = 1;
//寫指令
void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC為0時忽略忙檢測
        if (BuysC) ReadStatusLCM(); //根據需要檢測忙
        LCM_Data = WCLCM;
        LCM_RS = 0;
        LCM_RW = 0;
        LCM_E = 0;
        LCM_E = 0;
        LCM_E = 1;
//讀數據
        LCM_RS = 1;
        LCM_RW = 1;
        LCM_E = 0;
        LCM_E = 0;
        LCM_E = 1;
        return(LCM_Data);
//讀狀態
        LCM_Data = 0xFF;
        LCM_RS = 0;
        LCM_RW = 1;
        LCM_E = 0;
        LCM_E = 0;
        LCM_E = 1;
        while (LCM_Data & Busy); //檢測忙信號
        return(LCM_Data);
void LCMInit(void) //LCM初始化
        LCM_Data = 0;
        WriteCommandLCM(0x38,0); //三次顯示模式設置,不檢測忙信號
        Delay5Ms();
        Delay5Ms();
        Delay5Ms();
        WriteCommandLCM(0x38,1); //顯示模式設置,開始要求每次檢測忙信號
        WriteCommandLCM(0x08,1); //關閉顯示
        WriteCommandLCM(0x01,1); //顯示清屏
        WriteCommandLCM(0x06,1); // 顯示光標移動設置
        WriteCommandLCM(0x0F,1); // 顯示開及光標設置
//按指定位置顯示一個字符
        Y &= 0x1;
        X &= 0xF; //限制X不能大于15,Y不能大于1
        if (Y) X |= 0x40; //當要顯示第二行時地址碼+0x40;
        X |= 0x80; //算出指令碼
        WriteCommandLCM(X, 1); //發命令字
        WriteDataLCM(DData); //發數據
//按指定位置顯示一串字符
        unsigned char ListLength;
  ListLength = 0;
        Y &= 0x1;
        while (DData[ListLength]>0x19) //若到達字串尾則退出
                        if (X <= 0xF) //X坐標應小于0xF
                                        DisplayOneChar(X, Y, DData[ListLength]); //顯示單個字符
                                        ListLength++;
                                        X++;
//5ms延時
void Delay5Ms(void)
        unsigned int TempCyc = 5552;
        while(TempCyc--);
//400ms延時
        unsigned char TempCycA = 5;
        unsigned int TempCycB;
        while(TempCycA--)
                        TempCycB=7269;
                        while(TempCycB--);
    void Conut(void)
         time=TH0*256+TL0;
         TH0=0;
         TL0=0;
         S=(time*1.7)/100;     //算出來是CM
         if((S>=700)||flag==1) //超出測量范圍顯示“-”
          flag=0;
          DisplayOneChar(0, 1, ASCII[11]);
          DisplayOneChar(1, 1, ASCII[10]);        //顯示點
          DisplayOneChar(2, 1, ASCII[11]);
          DisplayOneChar(3, 1, ASCII[11]);
          DisplayOneChar(4, 1, ASCII[12]);        //顯示M
          disbuff[0]=S%1000/100;
          disbuff[1]=S%1000%100/10;
          disbuff[2]=S%1000%10 %10;
          DisplayOneChar(0, 1, ASCII[disbuff[0]]);
          DisplayOneChar(2, 1, ASCII[disbuff[1]]);
          DisplayOneChar(3, 1, ASCII[disbuff[2]]);
     void zd0() interrupt 1                  //T0中斷用來計數器溢出,超過測距范圍
    flag=1;                                                         //中斷溢出標志
     void  StartModule()                          //啟動模塊
          TX=1;                                             //啟動一次模塊
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          TX=0;
void delayms(unsigned int ms)
        unsigned char i=100,j;
        for(;ms;ms--)
                while(--i)
                        j=10;
                        while(--j);
void main(void)
        unsigned char TempCyc;
        Delay400Ms(); //啟動等待,等LCM講入工作狀態
        LCMInit(); //LCM初始化
        Delay5Ms(); //延時片刻(可不要)
        DisplayListChar(0, 0, mcustudio);
        DisplayListChar(0, 1, email);
        ReadDataLCM();//測試用句無意義
        for (TempCyc=0; TempCyc<10; TempCyc++)
        Delay400Ms(); //延時
        DisplayListChar(0, 1, Cls);
         TMOD=0x01;                   //設T0為方式1,GATE=1;
         TH0=0;
         TL0=0;
         ET0=1;             //允許T0中斷
         EA=1;                           //開啟總中斷
             StartModule();
                // DisplayOneChar(0, 1, ASCII[0]);
             while(!RX);                //當RX為零時等待
             TR0=1;                            //開啟計數
             while(RX);                        //當RX為1計數并等待
             TR0=0;                                //關閉計數
         Conut();                        //計算
                 delayms(80);                //80MS
ID:661764 發表于 2019-12-11 17:53 | 只看該作者
看起來不錯,一會在板子上試試
