查看: 1222|回復: 0
大佬們,這個單片機代碼怎么實現不了燈的漸變呢?
ID:521620 發表于 2019-4-25 18:33 來自觸屏版 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#define unit unsigned int
#define shudu 30
#define dengji 1
sbit B1=P1^0;
sbit G1=P1^1;
sbit R1=P1^2;
uchar Rout,Gout,Bout;
void delay(unit z)
        unit x,y;
        for(x=0;x<5;x++)
        for(y=0;y<z;y++);
void RGBpwm(uchar Rou,uchar Gou,uchar Bou)
        if(Rou!=0)
                R1=0;
                delay(Rou);
                R1=1;
        if(Bou!=0)
                B1=0;
                delay(Bou);
                B1=1;
        if(Gou!=0)
                G1=0;
                delay(Gou);
                G1=1;
        TMOD=0x01;
        EA=1;
        ET0=1;
        TR0=1;
        R1=1;
        G1=1;
        B1=1;
        TH0=(65536-256)/256;
        TL0=(65536-256)%256;
                RGBpwm(Rout,Gout,Bout);
void zhong() interrupt 1
        unit num;
        unit ji;
        num++;
        if(num==shudu)
                num=0;
                ji++;
                if((ji>0)&&(ji<100))
                        Rout=240;
                        Gout=0;
                        Bout=0;
                if((ji>100)&&(ji<240))
                        Rout-=dengji;
                        Gout=0;
                        Bout=0;
                if((ji>340)&&(ji<580))
                        Rout=0;
                        Gout+=dengji;
                        Bout=0;
                if((ji>580)&&(ji<680))
                        Rout=0;
                        Gout=240;
                        Bout=0;
                if((ji>680)&&(ji<920))
                        Rout=0;
                        Gout-=dengji;
                        Bout=0;
                if((ji>920)&&(ji<1160))
                        Rout=0;
                        Gout=0;
                        Bout+=dengji;
                if((ji>1160)&&(ji<1260))
                        Rout=0;
                        Gout=0;
                        Bout=240;
                if((ji>1260)&&(ji<1500))
                        Rout=0;
                        Gout=0;
                        Bout-=dengji;
                if(ji>1500)
                        ji=0;
