只需一步,快速開(kāi)始
查看: 1206|回復(fù): 0
單片機(jī)程序改了好久了,還是有問(wèn)題,真的看不出來(lái)了 求幫助
ID:506327 發(fā)表于 2019-4-24 22:01 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
有哪位大佬幫忙看看的
#include<reg51.h>
#include<intrins.h>
sbit ds=P2^7;
sbit CS=P3^4;
sbit SID=P3^5;
sbit SCLK=P3^6;
sbit PSB=P3^7;
char code table[]={"temperature:"};
char data disdate[8];
uchar tflag;          //溫度正負(fù)標(biāo)志
uchar value=0;          //溫度
/******************************液晶顯示程序******************************/
void delay(uchar z)
     uchar i,j;
        for(i=z;i>0;i--)
         for(j=110;j>0;j--);
void sendbyte(uchar byte)
        uchar i;
        for(i=0;i<8;i++)
                SCLK=1;
                if(byte&0x80)
                   SID=1;
                   SID=0;
                SCLK=0;
                byte<<=1;
void write_cmd(uchar cmd)
     CS=1;
        sendbyte(0xf8);
        sendbyte(cmd&0xf0);
        sendbyte(cmd<<4&0xf0);
        CS=0;
        delay(10);
void write_data(uchar date)
     CS=1;
        sendbyte(0xfa);
        sendbyte(date&0xf0);
        sendbyte(date<<4&0xf0);
        CS=0;
        delay(10);
void dizhi(uchar x,uchar y)
        uchar address;
        switch(x)
                case 1:address=0x80+y;break;
                case 2:address=0x90+y;break;
                case 3:address=0x88+y;break;
                case 4:address=0x98+y;break;
        write_cmd(address);
void guding(uchar l,uchar k,uchar *s)
        dizhi(l,k);
        while(*s)
             write_data(*s);
                s++;
void init()
     PSB=0;
        write_cmd(0x30);
        write_cmd(0x01);
        write_cmd(0x02);
        write_cmd(0x06);
        write_cmd(0x0e);
/******************************傳感器ds1802程序*******************************/
void yanshi(uint i)           //延時(shí)1微秒
    while(i--);
uchar fuwei()         //復(fù)位
     bit ok;
     ds=1;
        yanshi(4);
        ds=0;
        yanshi(200);
        yanshi(300);     //延時(shí)時(shí)間在480us~960us
        ds=1;
        yanshi(50);          //延時(shí)等待,確定傳感器的存在
        ok=ds;
        yanshi(25);
        return ok;
uchar read_date()           //讀數(shù)據(jù)
     uchar i=0;
        uchar date=0;
        for(i=0;i<8;i++)
                ds=0;
                date>>=1;
                ds=1;
                if(ds)            //執(zhí)行到這電平已經(jīng)穩(wěn)定,不用再加延時(shí)
                  date|=0x80;
                yanshi(30);
        return(date);
void write_date(uchar wdata)        //寫(xiě)數(shù)據(jù)
     uchar i=0;
        for(i=0;i>8;i++)
                ds=0;
                yanshi(15);        //區(qū)分讀寫(xiě),讓讀的時(shí)間過(guò)去
                ds=wdata&0x01;
                yanshi(45);    //讓有效數(shù)據(jù)穩(wěn)定
                ds=1;        //電平穩(wěn)定后,釋放總線
                wdata>>=1;
int read_temp()           //讀取溫度并轉(zhuǎn)換
        uchar a,b;
        fuwei();
        write_date(0xcc);   //跳過(guò)讀序列號(hào)
        write_date(0x44);   //啟動(dòng)溫度轉(zhuǎn)換
        yanshi(10);         //給芯片轉(zhuǎn)換溫度的時(shí)間
        fuwei();
        write_date(0xcc);
        write_date(0xbe);   //讀溫度
        a=read_date();            //低八位
        b=read_date();            //高八位
        value=b;
        value<<=8;
        value=value|a;
        if(value<0x0fff)
             tflag=0;
          value=~value+1;
          tflag=1;
        value=value*(0.625)+0.5;
        return value;
void display()
         disdate[0]=0x30;          //正負(fù)號(hào)位
         disdate[1]=value/1000+0x30;           //百位
         disdate[2]=value%1000/100+0x30;  //十位
         disdate[3]=value%100/10+0x30;   //個(gè)位
         disdate[4]=0x2e;                           //小數(shù)點(diǎn)
         disdate[5]=value%10+0x30;           //小數(shù)
         if(tflag==0)
           disdate[0]=0x2b;                  //如果溫度為正,不顯示
           disdate[0]=0x2d;
         if(disdate[1]==0x30)          //如果百位為零不顯示
            disdate[1]=0x20;
            if(disdate[2]==0x30)           //如果百位,個(gè)位為零,也不顯示
               disdate[2]=0x20;
/******************************主程序*****************************/
        init();
        delay(5);
        guding(1,0,table);
                read_temp();          //讀溫度
                display();       //顯示溫度
                guding(2,1,disdate);
