查看: 2131|回復(fù): 0
10s的秒表單片機(jī)程序+電路圖
ID:520474 發(fā)表于 2019-4-24 14:58 | 顯示全部樓層 |閱讀模式
#include<reg51.h>
sbit K1=P3^7;
uchar
i,Second_Counts,Key_Flag_Idx;
bit Key_State;
uchar
DSY_CODE[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
//延時
void DelayMS(uint ms)
uchar t;
while(ms--) for(t=0;t<120;t++);
//處理按鍵事件
void Key_Event_Handle()
if(Key_State==0)
Key_Flag_Idx=(Key_Flag_Idx+1)%3;
switch(Key_Flag_Idx)
case 1:EA=1;ET0=1;TR0=1;break;
case 2:EA=0;ET0=0;TR0=0;break;
case 0:P0=0x3f;P2=0x3f;i=0;Second_Counts=0;
//主程序
P0=0x3f;            //顯示 00
P2=0x3f;
i=0;
Second_Counts=0;
Key_Flag_Idx=0;          //按鍵次數(shù)(取值 0,1,2,3)
Key_State=1;      //按鍵狀態(tài)
TMOD=0x01;    //定時器 0 方式 1
TH0=(65536-40000)/256;    //定時器 0:15ms
TL0=(65536-40000)%256;
if(Key_State!=K1)
DelayMS(10);
Key_State=K1;
Key_Event_Handle();
//T0 中斷函數(shù)
void DSY_Refresh() interrupt 1
TH0=(65536-40000)/256;   //恢復(fù)定時器 0 初值
if(++i==2)
i=0;
Second_Counts++;   //50ms*2=0.1s 轉(zhuǎn)換狀態(tài)
P0=DSY_CODE[Second_Counts/10];
P2=DSY_CODE[Second_Counts%10];
if(Second_Counts==100) Second_Counts=0; //滿 100(10s)后顯示 00
參與人數(shù) 1黑幣 +50 收起 理由
