查看: 3264|回復(fù): 2
單片機(jī)客車空調(diào)分區(qū)控制系統(tǒng)程序+仿真設(shè)計(jì) LM35溫感+LM358+PCF8591+電機(jī)
LCD1602屏幕顯示的51單片機(jī)客車空調(diào)分區(qū)控制系統(tǒng)仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
LM35溫度傳感器經(jīng)過LM358+PCF8591 AD轉(zhuǎn)換后送給單片機(jī)處理
L298驅(qū)動(dòng)3個(gè)電機(jī)動(dòng)作
單片機(jī)源程序如下:
  1. #include<reg52.h>
  2. #include"delay.h"
  3. #include"lcd602.h"
  4. #include"iic.h"
  5. #include"pwm.h"
  6. #include"pwm1.h"
  7. #include"pwm2.h"
  8. /*******************數(shù)組定義********************/
  9. uchar tab1[] = {"T1:     T2:    "}; //3 12
  10. uchar tab2[] = {"T3:    "}; //3
  11. /*******************端口定義********************/
  12. /*******************變量定義********************/
  13. double dianya1 = 0; //電壓1
  14. double dianya2 = 0; //電壓2
  15. double dianya3 = 0; //電壓2
  16. /*******************主函數(shù)********************/
  17. void main()
  18. {
  19.    chushihua(); //液晶初始化
  20.    iic_init(); //IIC初始化
  21.    write_string(1,0,tab1);
  22.    write_string(2,0,tab2);
  23.    init_t0();
  24.    init_t1();
  25.    init_t2();
  26.    while(1)
  27.    {
  28.                      /*電壓采集*/
  29.                   dianya1=read_add(0x90,0x40)*5.0/255*10/3/0.01; //計(jì)算電壓,進(jìn)而計(jì)算溫度
  30.                   dianya1=read_add(0x90,0x40)*5.0/255*10/3/0.01; //計(jì)算電壓,進(jìn)而計(jì)算溫度
  31.                   dianya2=read_add(0x90,0x41)*5.0/255*10/3/0.01; //計(jì)算電壓,進(jìn)而計(jì)算溫度
  32.                   dianya2=read_add(0x90,0x41)*5.0/255*10/3/0.01; //計(jì)算電壓,進(jìn)而計(jì)算溫度
  33.                   dianya3=read_add(0x90,0x42)*5.0/255*10/3/0.01; //計(jì)算電壓,進(jìn)而計(jì)算溫度
  34.                   dianya3=read_add(0x90,0x42)*5.0/255*10/3/0.01; //計(jì)算電壓,進(jìn)而計(jì)算溫度
  35.                   write_num31(1,3,dianya1); //顯示溫度1
  36.                   write_num31(1,12,dianya2); //顯示溫度2
  37.                   write_num31(2,3,dianya3); //顯示溫度3
  38.                   /*溫度1控制*/
  39.                   if(dianya1/10<18)
  40.                   {pwm(0);}
  41.                   else if(dianya1/10>=18 && dianya1/10<=22)
  42.                   {pwm(50);}
  43.                   else
  44.                   {pwm(100);}
  45.                   /*溫度2控制*/
  46.                   if(dianya2/10<22)
  47.                   {pwm1(0);}
  48.                   else if(dianya2/10>=22 && dianya2/10<=25)
  49.                   {pwm1(50);}
  50.                   else
  51.                   {pwm1(100);}
  52.                   /*溫度3控制*/
  53.                   if(dianya3/10<22)
  54.                   {pwm2(0);}
  55.                   else if(dianya3/10>=20 && dianya3/10<=23)
  56.                   {pwm2(50);}
  57.                   else
  58.                   {pwm2(100);}
  59.    }
  60. }
基于單片機(jī)客車空調(diào)分區(qū)控制系統(tǒng).rar (143.19 KB, 下載次數(shù): 91)
收藏收藏2 分享淘帖 頂 踩
ID:635901 發(fā)表于 2019-11-26 20:35 | 只看該作者
你好 樓主,我想問一下你的實(shí)物用的lcd是什么型號(hào)
ID:393103 發(fā)表于 2020-4-10 10:51 | 只看該作者
qinbozhou 發(fā)表于 2019-11-26 20:35
LCD1602
