查看: 3230|回復: 4
求教max30100在網上找的Arduino代碼不行
幫忙看下哪里有問題(在網上找的代碼),運行后燈不亮,串口只顯示Beat
#include <Wire.h>
#include "MAX30100_PulseOximeter.h"
#define REPORTING_PERIOD_MS     1000
// PulseOximeter is the higher level interface to the sensor
// it offers:
//  * beat detection reporting
//  * heart rate calculation
//  * SpO2 (oxidation level) calculation
PulseOximeter pox;
uint32_t tsLastReport = 0;
// Callback (registered below) fired when a pulse is detected
void onBeatDetected()
    Serial.println("Beat!");
void setup()
    Serial.begin(115200);
    // Initialize the PulseOximeter instance and register a beat-detected callback
    pox.begin();
    pox.setOnBeatDetectedCallback(onBeatDetected);
void loop()
    // Make sure to call update as fast as possible
    pox.update();
    // Asynchronously dump heart rate and oxidation levels to the serial
    // For both, a value of 0 means "invalid"
    if (millis() - tsLastReport > REPORTING_PERIOD_MS) {
        Serial.print("Heart rate:");
        Serial.print(pox.getHeartRate());
        Serial.print("bpm / SpO2:");
        Serial.print(pox.getSpO2());
        Serial.println("%");
        tsLastReport = millis();
ID:750420 發表于 2020-10-20 19:20 | 只看該作者
解決了,參考這篇博文https://blog.csdn.net/JaLLs/article/details/99708019,包括需要下載的zip庫都有再評論區給你
ID:712072 發表于 2020-7-15 09:15 | 只看該作者
請問你解決了嗎?我也碰到了這個問題
ID:712072 發表于 2020-7-15 09:14 | 只看該作者
請問你解決了嗎?我也碰到了同樣的問題
ID:528780 發表于 2019-5-6 17:32 | 只看該作者
我用30102也遇到同樣問題
