查看: 10612|回復(fù): 12
51hei單片機(jī),MQ-5天然氣傳感器,1602顯示
ID:42637 發(fā)表于 2012-7-24 22:09 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
用51hei板,買了個(gè)MQ-5天然氣傳感器,做了個(gè)燃?xì)饴┬箞?bào)警器兼讀數(shù)。
用打火機(jī)檢驗(yàn),靈敏,滿足要求
#include <reg52.h>
#include <intrins.h>
#define lcd P0
sbit adc_cs=P2^0;
sbit adc_rd=P3^7;
sbit adc_wr=P3^6;
sbit en=P3^4;
sbit rw=P2^7;
sbit rs=P3^5;
sbit busybit=P0^7;
sbit beep=P2^2;
sbit P26=P2^6;
sbit P27=P2^7;
sbit P24=P2^4;
bit beep_flag;
bit adc_flag;
bit adc_start;
uchar tab[]="0123456789";
void lcd_init(void);
void delay(uint temp)
 while(temp--);
void init(void)
 P24=0;
 P27=1;
 P0=0xff;
 P27=0;
 P26=1;
 P0=0x00;
 P26=0;
 lcd_init();
 TMOD=0x01;
 TH0=0x3c;
 TL0=0xb0;
 ET0=1;
 TR0=1;
 IT1=0;
 EX1=1;
 IT0=1;
 EX0=1;
 EA=1;
void  int0_srv() interrupt 0
 adc_flag=1;
void int1_srv() interrupt 2
 beep_flag=1;
void timer0_srv() interrupt 1
 uchar temp;
 TH0=0x3c;
 TL0=0xb0;
 temp++;
 if(temp==20)
  temp=0;
  adc_start=1;
void testbusy(void)//read com
 busybit=1;
 en=0;
 rs=0;
 rw=1;
 delay(5);
 en=1;
 delay(5);
 while (busybit);
 en=0;
void wr_dat(uchar dat,busyflag)
 if(busyflag)
 testbusy();
 en=0;
 rs=1;
 rw=0;
 lcd=dat;
 delay(5);
 en=1;
 delay(5);
 en=0;
void wr_com(uchar com,busyflag)
 if(busyflag)
 testbusy();
 en=0;
 rs=0;
 rw=0;
 lcd=com;
 delay(5);
 en=1;
 delay(5);
 en=0;
void lcd_init(void)
 delay(1650);//time
 wr_com(0x38,0);
 delay(550);//time
 wr_com(0x38,0);
 delay(550);
 wr_com(0x38,0);
 wr_com(0x38,1);
 wr_com(0x08,1);
 wr_com(0x01,1);
 wr_com(0x06,1);
 wr_com(0x0c,1);
uchar adc_change(void)
 uchar value;
 adc_cs=1;
 adc_wr=1;
 delay(2);
 adc_cs=0;
 delay(2);
 adc_wr=0;
 delay(10);
 adc_wr=1;
 delay(2);
 adc_cs=1;
 while(!adc_flag);
 adc_flag=0;
 adc_rd=1;
 _nop_();
 adc_cs=0;
 delay(2);
 adc_rd=0;
 _nop_();
 value=P1;
 _nop_();
 adc_rd=1;
 delay(2);
 adc_cs=1;
 return value;
 uchar adc_value;
 uchar ge,shi,bei;
 init();
  if(beep_flag)
   beep_flag=0;
   beep=0;
   delay(10000);
   beep=1;
   delay(10000);
  if(adc_start)
   adc_start=0;
   adc_value=adc_change();
   bei=adc_value/100;
   adc_value=adc_value%100;
   shi=adc_value/10;
   ge=adc_value%10;
  wr_com(0x80,1);
  wr_dat('M',1);
  delay(3);
  wr_dat('Q',1);
  delay(3);
  wr_dat('-',1);
  delay(3);
     wr_dat('5',1);
  delay(3);
  wr_dat(':',1);
  delay(3);
     wr_com(0xc0,1);
  wr_dat(tab[bei],1);
  delay(3);
  wr_dat(tab[shi],1);
  delay(3);
  wr_dat(tab[ge],1);
  delay(3);
評(píng)分
參與人數(shù) 1黑幣 +5 收起 理由
ssfc + 5 贊一個(gè)!
查看全部評(píng)分
收藏收藏2 分享淘帖 頂 踩
ID:42637 發(fā)表于 2012-7-24 23:01 | 只看該作者
上電3小時(shí),MQ-5有點(diǎn)燙,靈敏度沒有降低
ID:42637 發(fā)表于 2012-7-24 23:09 | 只看該作者
去掉USB接口線顯示暗淡,加上USB線顯示正常,供電要考慮
ID:1 發(fā)表于 2012-7-25 04:38 | 只看該作者
牛人啊  期待更多 精彩分享
ID:29947 發(fā)表于 2012-7-26 15:21 | 只看該作者
提示: 作者被禁止或刪除 內(nèi)容自動(dòng)屏蔽
ID:42637 發(fā)表于 2012-7-26 20:51 | 只看該作者
用hei51板上的ADC0804是為了量化漏泄?jié)舛?/p>
MQ-5模塊有4個(gè)引腳,DOUT#就是你說的直接IO測(cè),我也用到了。
而AOUT腳,就是量化濃度。
另外這個(gè)程序有漏洞,我已經(jīng)作了完善處理。
[此貼子已經(jīng)被作者于2012-7-26 20:55:59編輯過]
ID:61997 發(fā)表于 2014-7-6 15:11 | 只看該作者
學(xué)習(xí)學(xué)習(xí)
ID:102765 發(fā)表于 2016-1-17 09:18 | 只看該作者
MQ-4可不可以用這個(gè)
ID:106437 發(fā)表于 2016-2-26 15:13 | 只看該作者
請(qǐng)問有沒有MQ5和單片機(jī)的連接電路圖啊
ID:106804 發(fā)表于 2016-3-1 11:25 | 只看該作者
牛人啊,程序先收藏私,待我的單片機(jī)到貨了來驗(yàn)證.
ID:119416 發(fā)表于 2016-5-9 01:57 | 只看該作者
請(qǐng)問有沒有基于DM430-A ,MQ-5可燃?xì)怏w傳感器,lcd1602 顯示器的編程,求答,畢業(yè)論文用
ID:162555 發(fā)表于 2017-1-20 16:14 | 只看該作者
傳感器接到單片機(jī)I/O口?怎么掃描?
ID:183779 發(fā)表于 2017-8-10 15:01 | 只看該作者
程序都沒有注釋,看著費(fèi)力不懂
