查看: 1249|回復: 1
51單片機燒錄,數碼管只顯示00
ID:516297 發表于 2019-4-19 13:17 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最后由 4564897 于 2019-4-19 20:19 編輯
#include  <REG52.H>
#define   uchar unsigned char
#define   uint unsigned int
sbit DATA=P1^2;
sbit weixuan=P1^6;
sbit duxuan=P1^5;
sbit SCL=P1^3;
sbit SDA=P1^4;
uchar bai,shi,ge;
uchar code seg7[]={0x3f,0x06,0x5b,0x4f,
                   0x66,0x6d,0x7d,0x07,
                   0x7f,0x6f,0x77,0x7c,
                   0x39,0x5e,0x79,0x71};
void delay(uchar us)
   while(us--);
void init_ds18b20()
  uchar init_resu;
  DATA=1;
  delay(10);
  DATA=0;
  delay(80);
  DATA=1;
  delay(20);
  init_resu=DATA;
  delay(30);
  DATA=1;
uchar readonechar()
  uchar i;
  uchar readresult;
  for(i=8;i>0;i--)
     readresult>>=1;
     DATA=1;
     delay(1);
     DATA=0;
     delay(1);
     DATA=1;
     delay(1);
     if(DATA)
     readresult|=0x80;
     readresult=0x7f;
     delay(8);
  return readresult;
writeonechar(uchar dat)
  uchar i;
  for(i=8;i>0;i--)
    DATA=0;
    delay(1);
    DATA=dat&0x01;
    delay(10);
    DATA=1;
    dat>>=1;
  delay(8);
void display(uchar bai,uchar shi,uchar ge)
  weixuan=1;
  P0=0xfe;
  weixuan=0;
  P0=0xff;
  duxuan=1;
  P0=seg7[bai];
  duxuan=0;
  delay(30);
  weixuan=1;
  P0=0xfd;
  weixuan=0;
  P0=0xff;
  duxuan=1;
  //P0=(seg7[shi]|0x80);
  P0=seg7[shi];
  duxuan=0;
  delay(30);
  weixuan=1;
  P0=0xfb;
  weixuan=0;
  P0=0xff;
  duxuan=1;
  P0=seg7[ge];
  duxuan=0;
  delay(30);
int readtemp()
  uchar a,b;
  int t;
  float tt;
  init_ds18b20();
  writeonechar(0xcc);
  writeonechar(0x44);
  init_ds18b20();
  writeonechar(0xcc);
  writeonechar(0xbe);
  a=readonechar();
  b=readonechar();
  t=b;
  t<<=8;
  t|=a;
  tt=t*0.0625;
  t=tt*10+0.5;
  return t;
void startlic()
  SDA=1;
  delay(1);
  SCL=1;
  delay(1);
  SDA=0;
  delay(1);
void stoplic()
  SDA=0;
  delay(1);
  SCL=1;
  delay(1);
  SDA=1;
  delay(1);
void responselic()
   uchar i;
   SCL=1;
   delay(1);
   while((SDA==1)&&(i<200))
   i++;
   SCL=0;
   delay(1);
void lnitlic()
  SDA=1;
  delay(1);
  SCL=1;
  delay(1);
void write_bytelic(uchar date)
   uchar i,temp;
   temp=date;
   for(i=0;i<8;i++)
     temp<<=1;
     SCL=0;
     delay(1);
     SDA=CY;
     delay(1);
     SCL=1;
     delay(1);
   SCL=0;
   delay(1);
   SDA=1;
   delay(1);
void writeaddressdatelic(uchar address,uchar date)
  startlic();
  write_bytelic(0xa0);
  responselic();
  write_bytelic(address);
  responselic();
  write_bytelic(date);
  responselic();
  stoplic();
  int temp;
  lnitlic();
    display(bai,shi,ge);
    temp=readtemp();
    bai=temp%1000/100;
    shi=temp%100/10;
    ge=temp%10;
ID:1 發表于 2019-4-19 16:23 | 只看該作者
您這個問題給的信息不全,估計是沒人能回答得了的,先轉移到冷門區了,自行點擊編輯按鈕補充一下吧,審核員會幫你重新轉到熱門問答區的
