想知道其他頭文件。
2019-4-18 16:50 上傳
單片機(jī)源程序如下:
- #include<reg52.h>
- #include<stdio.h>
- #include<intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit rs=P2^0;
- sbit rw=P2^1;
- sbit e=P2^2;
- sbit buz=P2^4;//鬧鈴位
- sbit dat=P2^7;
- sbit clk=P2^6;
- sbit rst=P2^5;
- sbit set=P1^0;//按鍵
- sbit up=P1^1;
- sbit down=P1^2;
- sbit fn=P1^3;
- uchar station=0;//按鍵狀態(tài)
- bit flag=0;//50ms標(biāo)志位
- bit flag_c=0;//鬧鐘啟動(dòng)標(biāo)志位
- bit flag_clock=1;//鬧鐘開(kāi),鬧鐘關(guān)
- uchar counter_c=0;//鬧鐘時(shí)長(zhǎng)計(jì)數(shù)器
- uchar counter_c1=0;
- uchar week=0;
- char str[16]="Gzy 20 - - ";
- char str1[16]="c- : :";
- //以下為1602函數(shù)
- void delay_us(uchar us);//延時(shí)微秒
- void delay_ms(uchar ms);//延時(shí)毫秒
- void write_com(uchar c);//寫(xiě)指令
- void write_data(uchar c);//寫(xiě)數(shù)據(jù)
- void show_char(uchar pos,uchar c);//顯示單個(gè)字符
- void show_str(uchar line,char *str);//顯示字符串
- void ini_lcd();//初始化LCD
- //以下為DS1302函數(shù)
- void write_byte(uchar temp);//寫(xiě)
- void write_1302(uchar add,uchar dat);//寫(xiě)1302
- uchar read_1302(uchar add);//讀1302數(shù)據(jù)
- void update_time();//更新時(shí)間
- void clock();//鬧鐘啟動(dòng)標(biāo)志置1
- void alarm();//鬧鈴
- void key_scan();//按鍵掃描
- void InitTimer1(void);
- void main()
- ini_lcd();
- InitTimer1();
- buz=0;
- show_str(0,str);
- show_str(1,str1);
- while(1){
- if(flag==1){
- flag=0;
- clock();
- alarm();
- key_scan();
- void Timer1Interrupt(void) interrupt 3
- TH1 = 0x3C;
- TL1 = 0x0B0;
- flag=1;
- if((flag_c==1)&&(flag_clock==1)){
- counter_c++;
- if(counter_c==19)
- buz=~buz;
- //以下為函數(shù)實(shí)體
- TMOD = 0x10;
- TH1 = 0x3C;
- TL1 = 0x0B0;
- EA = 1;
- ET1 = 1;
- TR1 = 1;
- uchar c_us;
- c_us=us>>1;
- while(--c_us);
- while(--ms){
- delay_us(250);
- delay_us(250);
- delay_us(250);
- delay_us(250);
- delay_ms(5);
- e=0;
- rs=0;
- rw=0;
- _nop_();
- e=1;
- P0=c;
- e=0;
- delay_ms(5);
- e=0;
- rs=1;
- rw=0;
- _nop_();
- e=1;
- P0=c;
- e=0;
- rs=0;
- uchar p;
- if(pos>=0x10)
- p=pos+0xb0;
- else
- p=pos+0x80;
- write_com(p);
- write_data(c);
- uchar l,i;
- l=line<<4;
- for(i=0;i<16;i++)
- show_char(l++,*(str+i));
- void ini_lcd()
- delay_ms(15);
- write_com(0x38);
- write_com(0x06);//顯示光標(biāo)移動(dòng)位置
- write_com(0x0c);
- write_com(0x01);//顯示清屏
- uchar i;
- for(i=0;i<8;i++){
- clk=0;
- dat=temp&0x01;
- temp>>=1;
- clk=1;
- rst=0;
- _nop_();
- clk=0;
- _nop_();
- rst=1;
- _nop_();
- write_byte(add);
- write_byte(dat);
- rst=0;
- //_nop_();
- uchar i,temp=0x00;
- rst=0;
- //_nop_();
- clk=0;
- //_nop_();
- rst=1;
- //_nop_();
- write_byte(add);
- for(i=0;i<8;i++){
- if(dat)
- temp|=0x80; //每次傳輸?shù)妥止?jié)
- //clk=0;
- temp>>=1;
- clk=1;
- clk=0;
- clk=1;
- rst=0;
- /*_nop_(); //以下為DS1302復(fù)位的穩(wěn)定時(shí)間
- rst=0;
- clk=0;
- _nop_();
- clk=1;
- _nop_();
- dat=0;
- _nop_();
- dat=1;
- _nop_();*/
- return (temp);
- uchar temp;
- temp=read_1302(0x81);//秒
- if(str1[15]!=temp%16+0x30){
- str1[15]=temp%16+0x30;
- str1[14]=temp/16+0x30;
- show_char(0x1f,str1[15]);
- show_char(0x1e,str1[14]);
- temp=read_1302(0x83);//分
- if(str1[12]!=temp%16+0x30){
- str1[12]=temp%16+0x30;
- str1[11]=temp/16+0x30;
- show_char(0x1c,str1[12]);
- show_char(0x1b,str1[11]);
- temp=read_1302(0x85);//時(shí)
- if(str1[9]!=temp%16+0x30){
- str1[9]=temp%16+0x30;
- str1[8]=temp/16+0x30;
- show_char(0x19,str1[9]);
- show_char(0x18,str1[8]);
- temp=read_1302(0x8b);//星期
- if(week!=temp){
- week=temp;
- switch (temp){
- case 2:week=2;str[14]='M';str[15]='o';break;
- case 3:week=3;str[14]='T';str[15]='u';break;
- case 4:week=4;str[14]='W';str[15]='e';break;
- case 5:week=5;str[14]='T';str[15]='h';break;
- case 6:week=6;str[14]='F';str[15]='r';break;
- case 7:week=7;str[14]='S';str[15]='a';break;
- case 1:week=7;str[14]='S';str[15]='u';break;
- show_char(0x0f,str[15]);
- show_char(0x0e,str[14]);
- temp=read_1302(0x8d);//年
- if(str[7]!=temp%16+0x30){
- str[6]=temp/16+0x30;
- str[7]=temp%16+0x30;
- show_char(0x06,str[6]);
- show_char(0x07,str[7]);
- temp=read_1302(0x89);//月
- if(str[10]!=temp%16+0x30){
- str[9]=temp/16+0x30;
- str[10]=temp%16+0x30;
- show_char(0x09,str[9]);
- show_char(0x0a,str[10]);
- temp=read_1302(0x87);//日
- if(str[13]!=temp%16+0x30){
- str[12]=temp/16+0x30;
- str[13]=temp%16+0x30;
- show_char(0x0c,str[12]);
- show_char(0x0d,str[13]);
- if(flag_clock==0){
- if(str1[2]!='o'){
- str1[2]='o';
- str1[3]='f';
- str1[4]='f';
- str1[5]=' ';
- str1[6]=' ';
- show_char(0x12,str1[2]);
- show_char(0x13,str1[3]);
- show_char(0x14,str1[4]);
- show_char(0x15,str1[5]);
- show_char(0x16,str1[6]);
- else{
- temp=read_1302(0xc1);//鬧鐘時(shí)
- if(str1[3]!=temp%16+0x30){
- str1[2]=temp/16+0x30;
- str1[3]=temp%16+0x30;
- str1[4]=':';
- temp=read_1302(0xc3);//鬧鐘分
- if(str1[6]!=temp%16+0x30){
- str1[5]=temp/16+0x30;
- str1[6]=temp%16+0x30;
- //顯示2行
- //show_str(1,str1);
- //show_str(0,str);
- void clock()
- uchar h,m,temp1,temp2;
- h=read_1302(0x85);//時(shí)
- m=read_1302(0x83);//分
- temp1=read_1302(0xc1);//讀RAM數(shù)據(jù)0,存鬧鐘時(shí)數(shù)據(jù)
- temp2=read_1302(0xc3);//讀RAM數(shù)據(jù)2,存鬧鐘分?jǐn)?shù)據(jù)
- if((temp1==h)&&(temp2==m))
- flag_c=1;
- void alarm()
- if(flag_c==1){
- if(counter_c>=20)//鬧鐘響20*50ms=1s
- counter_c=0;
- counter_c1++;
- if(counter_c1>=60){//60*1s=60s
- counter_c1=0;
- flag_c=0;
- counter_c=0;
- buz=0;
- void key_scan()
- uchar temp;
- if(set==0){
- delay_ms(10);
- if(set==0){
- while(set==0);
- station++;
- if(station>11)
- station=0;
- if(fn==0){
- delay_ms(10);
- if(fn==0){
- while(fn==0);
- station--;
- if(station>11)
- station=1;
- if(station==0)
- station=1;
- switch (station){
- case 0:
- //temp=read_1302(0x81);
- //if(temp>>7)
- //if((temp&0x80)==0x80)
- //write_1302(0x80,temp&0x7f);
- //write_com(0x38);
- //write_com(0x06);//顯示光標(biāo)移動(dòng)位置
- //write_com(0x0c);
- if(str[0]!='G'){
- str[0]='G';
- str[1]='z';
- str[2]='y';
- show_char(0x00,str[0]);
- show_char(0x01,str[1]);
- show_char(0x02,str[2]);
- update_time();
- break;
- case 1: //調(diào)年
- if(str[0]!='S'){
- str[0]='S';
- str[1]='e';
- str[2]='t';
- write_1302(0x80,temp|0x80);
- write_com(0x0e); //光標(biāo)顯示
- write_com(0x80+7);//光標(biāo)位置
- if(up==0){
- delay_ms(10);
- if(up==0){
- while(up==0);
- temp++;
- if(temp%16>9)
- temp=(temp&0xf0)+16;//個(gè)位數(shù)清零,十位數(shù)進(jìn)一
- if(temp>0x79)
- temp=0x79;
- write_1302(0x8c,temp);
- update_time();
- if(down==0){
- delay_ms(10);
- if(down==0){
- while(down==0);
- temp--;
- if(temp%16>9)
- temp=temp&0xf0+9;
- if(temp>79)
- temp=0;
- update_time();
- break;
- case 2: //調(diào)月
- write_com(0x80+10);
- if(up==0){
- delay_ms(10);
- if(up==0){
- while(up==0);
- temp++;
- if(temp%16>9)
- if(temp>0x12)
- temp=0x12;
- write_1302(0x88,temp);
- update_time();
- if(down==0){
- delay_ms(10);
- if(down==0){
- while(down==0);
- temp--;
- if(temp%16>9)
- temp=temp&0xf0+9;
- if(temp>0x12)
- temp=0x01;
- if(temp==0)
- temp=0x01;
- update_time();
- break;
- case 3: //調(diào)日
- write_com(0x80+13);
- if(up==0){
- delay_ms(10);
- if(up==0){
- while(up==0);
- temp++;
- if(temp%16>9)
- switch (read_1302(0x89)){
- case 0x01:
- case 0x03:
- case 0x05:
- case 0x07:
- case 0x08:
- case 0x10:
- case 0x12:
- if(temp>0x31)
- temp=0x31;
- break;
- case 2:
- switch (read_1302(0x8d)%4){
- case 0:
- if(temp>0x29)
- temp=0x29;
- break;
- default :
- if(temp>0x28)
- temp=0x28;
- break;
- case 0x04:
- case 0x06:
- case 0x11:
- if(temp>0x30)
- temp=0x30;
- break;
- write_1302(0x86,temp);
- update_time();
- if(down==0){
- delay_ms(10);
- if(down==0){
- while(down==0);
- temp--;
- if(temp%16>9)
- temp=temp&0xf0+9;
- if(temp>0x31)
- temp=0x01;
- if(temp==0)
- temp=0x01;
- update_time();
- break;
- case 4: //調(diào)星期
- write_com(0x80+15);
- if(up==0){
- delay_ms(10);
- if(up==0){
- while(up==0);
- temp++;
- if(temp>0x07)
- temp=0x07;
- write_1302(0x8a,temp);
- update_time();
- if(down==0){
- delay_ms(10);
- if(down==0){
- while(down==0);
- temp--;
- if(temp==0)
- temp=0x01;
- update_time();
- break;
- case 5: //鬧鐘開(kāi)關(guān)
- write_com(0x80+0x40);
- if(up==0){
- delay_ms(10);
- if(up==0){
- while(up==0);
- flag_clock=~flag_clock;
- update_time();
- if(down==0){
- delay_ms(10);
- if(down==0){
- while(down==0);
- update_time();
- break;
- case 6: //調(diào)鬧鐘時(shí)
- if(flag_clock==1){
- write_com(0x80+0x40+3);
- if(up==0){
- delay_ms(10);
- if(up==0){
- while(up==0);
- temp++;
- if(temp%16>9)
- if(temp>0x23)
- temp=0x23;
- write_1302(0xc0,temp);
- update_time();
- if(down==0){
- delay_ms(10);
- if(down==0){
- while(down==0);
- temp--;
- if(temp%16>9)
- temp=temp&0xf0+9;
- if(temp>0x23)
- temp=0;
- if(temp==0x00)
- temp=0x00;
- update_time();
- else station=8;
- break;
- case 7: //調(diào)鬧鐘分
- write_com(0x80+0x40+6);
- if(up==0){
- delay_ms(10);
- if(up==0){
- while(up==0);
- temp++;
- if(temp%16>9)
- if(temp>0x59)
- temp=0x59;
- write_1302(0xc2,temp);
- update_time();
- if(down==0){
- delay_ms(10);
- if(down==0){
- while(down==0);
- temp--;
- if(temp%16>9)
- temp=temp&0xf0+9;
- if(temp==0x00)
- temp=0;
- if(temp>0x59)
- temp=0x00;
- update_time();
- else station=8;
- break;
- case 8: //調(diào)時(shí)
- write_com(0x80+0x40+9);
- if(up==0){
- delay_ms(10);
- if(up==0){
- while(up==0);
- temp++;
- if(temp%16>9)
- if(temp>0x23)
- temp=0x23;
- write_1302(0x84,temp);
- update_time();
- if(down==0){
- delay_ms(10);
- if(down==0){
- while(down==0);
- temp--;
- if(temp%16>9)
- temp=temp&0xf0+9;
- if(temp>0x23)
- temp=0;
- if(temp==0x00)
- temp=0;
- update_time();
- break;
- case 9: //調(diào)分
- write_com(0x80+0x40+12);
- if(up==0){
- delay_ms(10);
- if(up==0){
- while(up==0);
- temp++;
- if(temp%16>9)
- if(temp>0x59)
- temp=0x59;
- write_1302(0x82,temp);
- update_time();
- …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
1602 DS1302.rar
(66.87 KB, 下載次數(shù): 22)
2019-4-18 16:24 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
