查看: 1425|回復: 2
我的單片機小車總程序,但1602最多只能顯示4CM,求指點
ID:494908 發表于 2019-4-18 12:52 | 顯示全部樓層 |閱讀模式
#include<reg51.h>
#include <intrins.h>
#define ulong unsigned long
sbit IN1=P3^0;
sbit IN2=P3^1;
sbit IN3=P3^2;
sbit IN4=P3^3;
sbit RS=P2^6;
sbit RW=P2^5;
sbit E=P2^7;
sbit trig=P3^4;
sbit echo=P3^5;
sbit BELL=P2^4;
sbit PWM=P2^1;
bit  flag = 0;
long SL,SR,S3;
uchar count,time=0;
unsigned long S = 0;
unsigned char code ASCII[13] = "0123456789.-M";
unsigned char disbuff[4] = { 0,0,0,0};
void delayms(zms)
uint x,y;
for(x=zms;x>0;x--)
  for(y=110;y>0;y--);
void wc(com,com1)
E=0;
  RS=0;
  RW=0;
  P0=com;
  delayms(2);
  E=1;
  delayms(2);
  E=0;
  void wd(dat)
  E=0;
  RS=1;
  RW=0;
  P0=dat;
  delayms(2);
  E=1;
  delayms(2);
  E=0;
  delayms(2);
  void init(void)
  wc(0x38,0);
delayms(5);
  wc(0x38,0);
delayms(5);
  wc(0x38,0);
delayms(5);
  wc(0x38,1);
  wc(0x01,1);
  wc(0x06,1);
  wc(0x0E,1);
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
        Y &= 0x1;
        X &= 0xF;
        if (Y) X |= 0x40;
        X |= 0x80;
        wc(X, 1);
    wd(DData);
void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData)
        unsigned char ListLength;
  ListLength = 0;
        Y &= 0x1;
        X &= 0xF;
        while (DData[ListLength]>0x19)
                        if (X <= 0xF)
                                        DisplayOneChar(X, Y, DData[ListLength]);
                                        ListLength++;
                                        X++;
void measure(void)
                time=TH0*256+TL0;
     TH0=0;
     TL0=0;
     S=(time*1.7)/100;
     if((S>=7000)||flag==1)
      flag=0;
          DisplayOneChar(0, 1, ASCII[11]);
      DisplayOneChar(1, 1, ASCII[10]);
      DisplayOneChar(2, 1, ASCII[11]);
      DisplayOneChar(3, 1, ASCII[11]);
      DisplayOneChar(4, 1, ASCII[12]);
      disbuff[0]=S%1000/100;
      disbuff[1]=S%1000%100/10;
      disbuff[2]=S%1000%10%10;
      DisplayOneChar(0, 1, ASCII[disbuff[0]]);
      DisplayOneChar(2, 1, ASCII[disbuff[1]]);
      DisplayOneChar(3, 1, ASCII[disbuff[2]]);
void zd0() interrupt 2
    flag=1;
void StartModule()
      trig = 1;
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
     trig=0;
void timer0() interrupt        1
  TH0=(65536-100)/256;
  TL0=(65536-100)%256;
  time++;
  if(time<count)  //5 左轉90度,15歸中,25右轉90度
  PWM=1;
  else  PWM=0;
   if(time==200)
  time=0;
              void run(void)
   IN1=0; IN2=1; IN3=1; IN4=0;
        void back(void)
  IN1=1; IN2=0; IN3=0; IN4=1;
        void stop(void)
   IN1=0; IN2=0; IN3=0; IN4=0;
        void right(void)
  IN1=0; IN2=1; IN3=0; IN4=1;
        void left(void)
  IN1=1; IN2=0; IN3=1; IN4=0;
void avoid()
  count=5;
  delayms(400);
  StartModule();
  measure();
  SL=S;
  count=25;
  delayms(400);
  StartModule();
  measure();
  SR=S;
  count=15;
  delayms(100);
  StartModule();
  measure();
  S3=S;
  if(SL<20||SR<20||S3<20)
   back();
   delayms(500);
   if(SL<20&&SR<20&&S3<20)
    back();
        delayms(500);
        if(SL<SR)
         right();
         delayms(400);
          left();
          delayms(400);
   init();
   TMOD=0x01;
    TH0=0;
    TL0=0;
    ET0=1;
    EA=1;
   StartModule();
   while(!echo);
   TR0=1;
   while(echo);
   TR0=0;
  measure();
        delayms(50);
          if(S<300)
           stop();
           avoid();
           if(S>400)
           run();
ID:308437 發表于 2019-4-18 15:46 | 顯示全部樓層
“1602最多只能顯示4CM”請問這句是什么意思?
請說清楚哈,真的看不懂
ID:280876 發表于 2019-4-25 20:56 | 顯示全部樓層
兄dei,你是拿尺子量出4CM的嗎
