查看: 10296|回復: 0
用HAL庫寫的stm32按鍵控制LED燈亮滅源程序
ID:438796 發表于 2019-4-18 10:34 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
用stm32cubemx配置的,單片機是stm32f103v8t6,采用普通i/o模式判斷按鍵,一個按鍵控制LED亮,一個控制滅,我就貼上主要的代碼,供學習HAL庫的朋友學習,我也剛開始學,stm32cubemx的配置文件也在這個文件里面
void MX_GPIO_Init(void)
  GPIO_InitTypeDef GPIO_InitStruct;
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOD_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(LED_GPIO_Port, LED_Pin, GPIO_PIN_RESET);
  /*Configure GPIO pin : PtPin */
  GPIO_InitStruct.Pin = KEY1_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  HAL_GPIO_Init(KEY1_GPIO_Port, &GPIO_InitStruct);
  GPIO_InitStruct.Pin = LED_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(LED_GPIO_Port, &GPIO_InitStruct);
  GPIO_InitStruct.Pin = KEY0_Pin;
  HAL_GPIO_Init(KEY0_GPIO_Port, &GPIO_InitStruct);
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration----------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
  /* USER CODE END WHILE */
        if( HAL_GPIO_ReadPin(KEY0_GPIO_Port, KEY0_Pin)==0)//讀一個引腳的電平,判斷key0是否按下
                HAL_GPIO_WritePin(LED_GPIO_Port,LED_Pin,GPIO_PIN_RESET);//LED滅
                while(!HAL_GPIO_ReadPin(KEY0_GPIO_Port, KEY0_Pin));//松手檢測
//                HAL_GPIO_TogglePin (LED_GPIO_Port, LED_Pin );
        if( HAL_GPIO_ReadPin(KEY1_GPIO_Port, KEY1_Pin)==0)//判斷key0是否按下
                HAL_GPIO_WritePin(LED_GPIO_Port,LED_Pin,GPIO_PIN_SET);//LED亮
                while(!HAL_GPIO_ReadPin(KEY1_GPIO_Port, KEY1_Pin));//松手檢測
  /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
全部資料51hei下載地址:
KEY.7z (602.91 KB, 下載次數: 42)
