查看: 1935|回復: 1
求大佬幫忙:sct12c5a60s2的AD采樣電壓信號并用LCD12864進行顯示該怎么寫程序?
ID:508203 發表于 2019-4-14 20:31 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
ID:467275 發表于 2019-4-24 22:07 | 只看該作者
#include<STC12C5A60S2.H>
#define uint   unsigned int
sbit CS=P2^0;         //LCD12864串行通信片選
sbit SID=P2^1;         //LCD12864串行通信數據口
sbit SCLK=P2^2;         //LCD12864串行通信同步時鐘信號
sbit PSB=P2^5;         //LCD12864并/串選擇:H并行 L串行
unsigned int temp1,sh1,ge1,n1,m1;
unsigned char ad_result_data[10];   //AD轉換高八位
unsigned char ad_result_low2[10];   //AD轉換低八位
unsigned char ad_result_total[10];   //AD轉換總十位
unsigned char ad_average_result;   //AD轉換十次的平均值
unsigned char Ain,Vin;
unsigned char b,t,R;
char tp=0;
unsigned char code ma1[6]={0xb5,0xe7,0xd1,0xb9,0xa1,0xc3}; //電壓:
unsigned char code ma2[]={"."};
uchar code disp1[]={"提示: 按1 鍵進入"};
uchar code disp2[]={"功能選擇界面. "};
unsigned char code num0[]={0xa3,0xb0};
unsigned char code num1[]={0xa3,0xb1};
unsigned char code num2[]={0xa3,0xb2};
unsigned char code num3[]={0xa3,0xb3};
unsigned char code num4[]={0xa3,0xb4};
unsigned char code num5[]={0xa3,0xb5};
unsigned char code num6[]={0xa3,0xb6};
unsigned char code num7[]={0xa3,0xb7};
unsigned char code num8[]={0xa3,0xb8};
unsigned char code num9[]={0xa3,0xb9};
//-------模塊延時程序---------------------------- 1ms
void delay1ms(uint delay1ms) //STC11F60XE,22.1184M,延時1ms
uint i,j;
for(;delay1ms>0;delay1ms--)
   for(i=0;i<7;i++)
     for(j=0;j<210;j++);
void delay(uint delay) //STC11F60XE,22.1184M,延時170us
uint i,j;
for(;delay>0;delay--)
   for(i=0;i<124;i++);
     for(j=0;j<124;j++);
                  AD轉換程序
void AD_initiate() //初始化函數
ES=0;
TMOD=0x21; //定時計數器方式控制寄存器,"自動重裝,16位計數器".
SCON=0x50; //串行控制寄存器,方便在串口助手那觀察
TH1=0xfa;
TL1=0xfa;
TR1=1;
void ADC_Power_On()      //AD轉換電
ADC_CONTR|=0x80;
delay(5);     //必要的延時
void get_ad_result() //取AD結果函數,它是十位AD轉換,每十次平均,最后取低八位作為AD采樣數據
uint i,q=0;
for(i=0;i<10;i++)
       tp=0;
       ADC_RES=0;     //高八位數據清零,STC12C5A60S2 AD數據寄存名與STC12C54××系列不同
    ADC_RESL=0;    //低兩位清零
       ADC_CONTR|=0x08; //啟動AD轉換
       while(!tp)     //判斷AD轉換是否完成
           tp=0x10;
           tp&=ADC_CONTR;
      ADC_CONTR&=0xe7;
   ad_average_result=ADC_RES;
   q=q+ad_average_result;
   ad_average_result=q/10;
   //ad_average_result=ad_average_result*4*5000/1024;
/************************AD轉換結束***********************/
void send_ad_result() //取AD結果函數發送到串口,方便調試
   SBUF=n1;
   while(TI==0) ;
    TI=0;
   delay1ms(100);
   //SBUF=R>>4;
//---------------------電壓采樣程序-------------------------
void caiyangP10()     //測電壓
P1M0|=0x01;         //設P1_0為開漏模式 如: P1_0= #00000000B
P1M1|=0x01;
ADC_CONTR=0xe0;   //設置P1.0為輸入AD轉換口
delay(2);
get_ad_result();        //取轉換數據
Vin=ad_average_result;
R=Vin;
/*-----------寫控制字到LCD12864------------*/
void write_cmd(uchar cmd)
uchar i;
uchar i_data;
i_data=0xf8;          //命令控制字:11111000寫指令 11111010寫數據 11111100讀狀態 11111110讀數據
CS=1;          //片選置高,才能進行讀寫操作
SCLK=0;
/*----------寫命令控制字-----------------*/
for(i=0;i<8;i++)       //循環八次,每次讀取一位數據
   SID=(bit)(i_data&0x80);     //bit表示取其最高位
   SCLK=0;
   SCLK=1;         //正跳變寫入指令
   i_data=i_data<<1;      //左移一位
/*----------寫指令高四位-----------------*/
i_data=cmd;
i_data=i_data&0xf0;       //把低四位置0
   SCLK=0;
   SCLK=1;         //正跳變寫入指令
/*----------寫指令低四位-----------------*/
i_data=cmd;
i_data=i_data<<4;       //左移四位,把低四位的數據移到高四位,再把低四位置0
   SCLK=0;
   SCLK=1;        //正跳變寫入指令
CS=0;         //把片選置低
delay1ms(5);       //延時是因為沒有進行忙檢測,適當的延時可以不進行忙檢測
/*------------寫數據到LCD12864-------------*/
void write_dat(uchar dat)
uchar i;
uchar i_data;
i_data=0xfa;
CS=1;
for(i=0;i<8;i++)
   SCLK=0;
   SCLK=1;
   i_data=i_data<<1;
i_data=dat;
i_data=i_data&0xf0;
for(i=0;i<8;i++)
   SCLK=0;
   SCLK=1;
   i_data=i_data<<1;
i_data=dat;
i_data=i_data<<4;
for(i=0;i<8;i++)
   SCLK=0;
   SCLK=1;
   i_data=i_data<<1;
CS=0;
delay1ms(5);
/*--------------顯示坐標-------------------*/
void lcd_pos(uchar x,uchar y)      //漢字顯示坐標,x為哪一行,y為哪一列
uchar pos;
if(x==0)
   x=0x80;         //第一行
else if(x==1)
   x=0x90;         //第二行
else if(x==2)
   x=0x88;         //第三行
else if(x==3)
   x=0x98;         //第四行
pos=x+y;         //顯示哪一行(總共有4行)哪一豎(總共有8豎,每16列為1豎)
write_cmd(pos);
/*--------------顯示8個漢字-------------------*/
void disp_hanzi(uchar code *chn)
   uchar i;
   write_cmd(0x30);    //基本指令操作方式
   for(i=0;i<16;i++)   //16列*8個漢字=128(剛好)
       write_dat(chn[i]);
/*--------------顯示數字-------------------*/
void disp_num(uchar code *chn)
uchar i;
   for(i=0;i<2;i++)      //1個數字
       write_dat(chn[i]);
void disp_number(uchar num)
   switch(num)
case 0: disp_num(num0);break;
case 1: disp_num(num1);break;
case 2: disp_num(num2);break;
case 3: disp_num(num3);break;
case 4: disp_num(num4);break;
case 5: disp_num(num5);break;
     case 6: disp_num(num6);break;
case 7: disp_num(num7);break;
case 8: disp_num(num8);break;
case 9: disp_num(num9);break;
default: break;
/*----------- --LCD初始化------------------*/
void lcd_init()
PSB=0;
write_cmd(0x02);       //地址歸位
write_cmd(0x06);       //游標右移
write_cmd(0x0c);       //整體顯示
write_cmd(0x01);       //清屏
void displayP10()
float ad1;
//unsigned int temp1,sh1,ge1,n1,m1;
//uchar code dis2[]={0x01,0x02,0x00};
//ad1=x*7.8125;   //電壓修正
uchar i;
ad1=Vin*3.9608;   //具體線性參數由輸入電壓值調整,該值的測量范圍為0-10.00V,5V左右的測量比較準確,
                      //兩端的最大誤差為70mv,其他一般在40mv以內
temp1=(int)ad1;
sh1=temp1/1000;    //十位
ge1=(temp1%1000)/100;   //個位
n1=((temp1%1000)%100)/10; //小數點后一位
m1=((temp1%1000)%100)%10; //小數點后二位
//write_cmd(0x01);
lcd_pos(0,0);
   for(i=0;i<6;i++)        write_dat(ma1[i]);
lcd_pos(0,3);
disp_number(sh1);
lcd_pos(0,4);
disp_number(ge1);
lcd_pos(0,5);
for(i=0;i<2;i++)    write_dat(ma2[i]);
lcd_pos(0,6);
disp_number(n1);
lcd_pos(0,7);
disp_number(m1);
/*lcd_pos(2,0);
disp_hanzi(disp1);
lcd_pos(3,0);
disp_hanzi(disp2);*/
     EA=1;
AD_initiate();   //初始化
ADC_Power_On();     //開AD電源
//init();
lcd_init();
delay(10);
     caiyangP10();    //測電壓
     send_ad_result();
   //Vin=Vin*4007;
   displayP10();
   delay(10);
