只需一步,快速開(kāi)始
查看: 3098|回復(fù): 1
STM32與兩片MSP430實(shí)現(xiàn)通信源程序
ID:510379 發(fā)表于 2019-4-12 15:26 | 顯示全部樓層 |閱讀模式
這是關(guān)于串口通信的程序,可以實(shí)現(xiàn)三方通信(只用一個(gè)串口)STM32與兩片MSP430實(shí)現(xiàn)通信
單片機(jī)源程序如下:
  1. #include  <msp430x14x.h>
  2. #include "RF.h"
  3.   void delay_100ms(unsigned int i)
  4.   {
  5.           unsigned long j;
  6.           for(;i>0;i--)
  7.           {
  8.                   for(j=0;j<144200;j++);
  9.           }
  10.   }
  11.
  12.
  13. //unsigned char RXData[4]={0};
  14. unsigned char TxBuf[5]={0};
  15. unsigned char RxBuf[5]={0};
  16. unsigned char a,b,c;
  17. unsigned char PaTabel[8] = {0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60};
  18. //unsigned char rxBuffer;
  19. void main(void)
  20. {
  21.
  22. unsigned char leng = 2;
  23.   //   P5DIR |= BIT3;
  24.   //P5OUT |= BIT3;
  25.
  26.
  27.
  28.
  29.
  30.     CpuInit();  //包括看門(mén)狗,時(shí)鐘,I/O口,SPI
  31.     POWER_UP_RESET_CC1100();
  32.     halRfWriteRfSettings();
  33.     halSpiWriteBurstReg(CCxxx0_PATABLE, PaTabel, 8,1);
  34.     halSpiWriteBurstReg(CCxxx0_PATABLE, PaTabel, 8,2);
  35.     delay(100);
  36.
  37.
  38.     P3SEL |= 0x30;            //P3.4 P3.5 ????????????
  39.     ME1 |= UTXE0 + URXE0;                     // Enable USART0 TXD/RXD
  40.     UCTL0 |= CHAR;                            // 8-bit character
  41.     UTCTL0 |= SSEL1;                          // UCLK = SMCLK
  42.     UBR00 = 0x45;                             // 8MHz 115200
  43.     UBR10 = 0x00;                             // 8MHz 115200
  44.     UMCTL0 = 0x00;                            // 8MHz 115200 modulation
  45.     UCTL0 &= ~SWRST;                          // Initialize USART state machine
  46.     IE1 |= URXIE0;
  47.     delay(100);
  48.
  49.     P1DIR &= ~(BIT0+BIT1+BIT2+BIT3);
  50.     P2DIR |= BIT7+BIT6+BIT5+BIT4;    //控制led燈
  51.     P2OUT |=BIT7+BIT6+BIT5+BIT4;
  52.     for(;;)
  53.     {
  54.        /**********************************開(kāi)機(jī)************************************************/
  55.       if(0==(P1IN&0X01))
  56.        {
  57.          P2OUT^=BIT7;
  58.          delay_100ms(1);
  59.
  60.          TxBuf[0]=0x01;
  61.          TxBuf[1]=0x02;
  62.
  63.             while(0==(P1IN&0X01));
  64.          halRfSendPacket(TxBuf,leng,1); // Transmit Tx buffer data
  65.
  66.        }
  67.
  68.        /********************************關(guān)機(jī)**************************************************/
  69.       if(0==(P1IN&0X02))
  70.        {
  71.          P2OUT^=BIT6;
  72.          delay_100ms(1);
  73.
  74.          TxBuf[0]=0x01;
  75.          TxBuf[1]=0x03;
  76.            while(0==(P1IN&0X2));
  77.          halRfSendPacket(TxBuf,leng,1); // Transmit Tx buffer data
  78.
  79.        }
  80.    /***********************************溫度加***********************************************/
  81.       if(0==(P1IN&0X04))
  82.        {
  83.          P2OUT^=BIT5;
  84.          delay_100ms(1);
  85.
  86.          TxBuf[0]=0x01;
  87.          TxBuf[1]=0x04;
  88.
  89.           while(0==(P1IN&0X04));
  90.          halRfSendPacket(TxBuf,leng,1); // Transmit Tx buffer data
  91.
  92.        }
  93.      /**********************************溫度減************************************************/
  94.       if(0==(P1IN&0X08))
  95. ……………………
  96. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
stm32和msp430通信.7z (349.06 KB, 下載次數(shù): 20)
ID:1 發(fā)表于 2019-4-12 17:01 | 顯示全部樓層
本帖需要重新編輯補(bǔ)全電路原理圖,源碼,詳細(xì)說(shuō)明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
