基于STM32F103單片機通過藍牙發送獲取的GPS信息到手機上 主函數怎么寫??各位大佬用 的藍牙是HC-06 GPS是 ATK-S1216
- #include "sys.h"
- #include "delay.h"
- #include "usart.h"
- #include "led.h"
- #include "lcd.h"
- #include "key.h"
- #include "usmart.h"
- #include "gps.h"
- #include "string.h"
- #include "usart2.h"
- #include "hc06.h"
- u8 USART1_TX_BUF[USART2_MAX_RECV_LEN]; //串口1,發送緩存區
- nmea_msg gpsx; //GPS信息
- __align(4) u8 dtbuf[50]; //打印緩存器
- const u8*fixmode_tbl[4]={"Fail","Fail"," 2D "," 3D "}; //fix mode字符串
- //顯示GPS定位信息
- //void HC06_Role_Show(void)
- // if(HC06_Get_Role()==1)LCD_ShowString(30,140,200,16,16,"ROLE:Master"); //主機
- // else LCD_ShowString(30,140,200,16,16,"ROLE:Slave "); //從機
- ////顯示ATK-hc06模塊的連接狀態
- //void HC06_Sta_Show(void)
- // if(HC06_STATE)LCD_ShowString(120,140,120,16,16,"STA:Connected "); //連接成功
- // else LCD_ShowString(120,140,120,16,16,"STA:Disconnect"); //未連接
- //void Gps_Msg_Show(void)
- // float tp;
- // POINT_COLOR=BLUE;
- // tp=gpsx.longitude;
- // sprintf((char *)dtbuf,"Longitude:%.5f %1c ",tp/=100000,gpsx.ewhemi); //得到經度字符串
- // LCD_ShowString(30,120,200,16,16,dtbuf);
- // tp=gpsx.latitude;
- // sprintf((char *)dtbuf,"Latitude:%.5f %1c ",tp/=100000,gpsx.nshemi); //得到緯度字符串
- // LCD_ShowString(30,140,200,16,16,dtbuf);
- // tp=gpsx.altitude;
- // sprintf((char *)dtbuf,"Altitude:%.1fm ",tp/=10); //得到高度字符串
- // LCD_ShowString(30,160,200,16,16,dtbuf);
- // tp=gpsx.speed;
- // sprintf((char *)dtbuf,"Speed:%.3fkm/h ",tp/=1000); //得到速度字符串
- // LCD_ShowString(30,180,200,16,16,dtbuf);
- // if(gpsx.fixmode<=3) //定位狀態
- // sprintf((char *)dtbuf,"Fix Mode:%s",fixmode_tbl[gpsx.fixmode]);
- // LCD_ShowString(30,200,200,16,16,dtbuf);
- // sprintf((char *)dtbuf,"GPS+BD Valid satellite:%02d",gpsx.posslnum); //用于定位的GPS衛星數
- // LCD_ShowString(30,220,200,16,16,dtbuf);
- // sprintf((char *)dtbuf,"GPS Visible satellite:%02d",gpsx.svnum%100); //可見GPS衛星數
- // LCD_ShowString(30,240,200,16,16,dtbuf);
- // sprintf((char *)dtbuf,"BD Visible satellite:%02d",gpsx.beidou_svnum%100); //可見北斗衛星數
- // LCD_ShowString(30,260,200,16,16,dtbuf);
- // sprintf((char *)dtbuf,"UTC Date:%04d/%02d/%02d ",gpsx.utc.year,gpsx.utc.month,gpsx.utc.date); //顯示UTC日期
- // LCD_ShowString(30,280,200,16,16,dtbuf);
- // sprintf((char *)dtbuf,"UTC Time:%02d:%02d:%02d ",gpsx.utc.hour,gpsx.utc.min,gpsx.utc.sec); //顯示UTC時間
- // LCD_ShowString(30,300,200,16,16,dtbuf);
- int main(void)
- u8 t;
- u8 sendmask=0;
- u8 sendcnt=0;
- u8 sendbuf[20];
- // u8 reclen=0;
- u16 i,rxlen;
- u16 lenx;
- u8 key=0XFF;
- u8 upload=0;
- POINT_COLOR=RED;
- delay_init(); //延時函數初始化
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //設置NVIC中斷分組2:2位搶占優先級,2位響應優先級
- uart_init(115200); //串口初始化為9600
- USART2_Init(38400); //初始化串口2波特率為115200
- LCD_Init(); //初始化液晶
- LED_Init(); //LED初始化
- KEY_Init(); //按鍵初始化
- usmart_dev.init(72); //usmart初始化 CHUAN KOU
- if(SkyTra_Cfg_Rate(5)!=0) //設置定位信息更新速度為5Hz,順便判斷GPS模塊是否在位.
- //LCD_ShowString(30,120,200,16,16,"S1216F8-BD Setting...");
- do
- USART2_Init(9600); //初始化串口3波特率為9600
- SkyTra_Cfg_Prt(3); //重新設置模塊的波特率為38400
- USART2_Init(38400); //初始化串口3波特率為38400
- key=SkyTra_Cfg_Tp(100000); //脈沖寬度為100ms
- while(SkyTra_Cfg_Rate(5)!=0&&key!=0);//配置SkyTraF8-BD的更新速率為5Hz
- //LCD_ShowString(30,120,200,16,16,"S1216F8-BD Set Done!!");
- delay_ms(500);
- //LCD_Fill(30,120,30+200,120+16,WHITE);//清除顯示
- while(1)
- delay_ms(1);
- if(USART2_RX_STA&0X8000) //接收到一次數據了
- rxlen=USART2_RX_STA&0X7FFF; //得到數據長度
- for(i=0;i<rxlen;i++)USART1_TX_BUF[i]=USART2_RX_BUF[i];
- USART2_RX_STA=0; //啟動下一次接收
- USART1_TX_BUF[i]=0; //自動添加結束符
- GPS_Analysis(&gpsx,(u8*)USART1_TX_BUF);//分析字符串
- //Gps_Msg_Show(); //顯示信息
- if(upload)printf("\r\n%s\r\n",USART1_TX_BUF);//發送接收到的數據到串口1
- // key=KEY_Scan(0);
- // if(key==KEY0_PRES)
- // upload=!upload;
- // POINT_COLOR=RED;
- // if(upload)LCD_ShowString(30,100,200,16,16,"NMEA Data Upload:ON ");
- // else LCD_ShowString(30,100,200,16,16,"NMEA Data Upload:OFF");
- if((lenx%500)==0)
- LED0=!LED0;
- lenx++;
- while(HC06_Init()) //初始化ATK-hc06模塊
- // LCD_ShowString(30,90,200,16,16,"ATK-hc06 Error!");
- // delay_ms(500);
- // LCD_ShowString(30,90,200,16,16,"Please Check!!!");
- POINT_COLOR=BLUE;
- delay_ms(100);
- // LCD_ShowString(30,90,200,16,16,"WK_UP:ROLE KEY0:SEND/STOP");
- // LCD_ShowString(30,110,200,16,16,"ATK-hc06 Standby!");
- // LCD_ShowString(30,160,200,16,16,"Send:");
- // LCD_ShowString(30,180,200,16,16,"Receive:");
- // HC06_Role_Show();
- while(1)
- // if(key==WKUP_PRES) //切換模塊主從設置
- // key=HC06_Get_Role();
- // if(key!=0XFF)
- // key=!key; //狀態取反
- // if(key==0)HC06_Set_Cmd("AT+ROLE=0");
- // else HC06_Set_Cmd("AT+ROLE=1");
- // HC06_Set_Cmd("AT+RESET"); //復位ATK-hc06模塊
- // }else
- if(key==KEY0_PRES)
- sendmask=!sendmask; //發送/停止發送
- if(sendmask==0)LCD_Fill(30+40,160,240,160+16,WHITE);//清除顯示
- }else delay_ms(10);
- if(t==50)
- if(sendmask) //定時發送
- sprintf((char*)sendbuf,"ALIENTEK hc06 %d\r\n",sendcnt);
- LCD_ShowString(30+40,160,200,16,16,sendbuf); //顯示發送數據
- u2_printf("ALIENTEK hc06 %d\r\n",sendcnt); //發送到藍牙模塊
- sendcnt++;
- if(sendcnt>99)sendcnt=0;
- // HC06_Sta_Show();
- // t=0;
- // LED0=!LED0;
- // if(USART2_RX_STA&0X8000) //接收到一次數據了
- // LCD_Fill(30,200,240,320,WHITE); //清除顯示
- // reclen=USART2_RX_STA&0X7FFF; //得到數據長度
- // USART2_RX_BUF[reclen]=0; //加入結束符
- // if(reclen==9||reclen==8) //控制DS1檢測
- // if(strcmp((const char*)USART2_RX_BUF,"+LED1 ON")==0)LED1=0; //打開LED1
- // if(strcmp((const char*)USART2_RX_BUF,"+LED1 OFF")==0)LED1=1;//關閉LED1
- // LCD_ShowString(30,200,209,119,16,USART2_RX_BUF);//顯示接收到的數據
- // USART2_RX_STA=0;
- // t++;
