查看: 6268|回復: 7
[原創]剛寫的程序,提下建議
ID:38029 發表于 2012-7-11 23:53 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
/*************************************/ /*功能:溫度檢測,溫度調節,自動控溫*/ /***********************************/ /********* IR_T.c ***********/ #include #define uint unsigned int #define uchar unsigned char sbit RS = P1^0; //1602數據,命令端 sbit RW = P1^1; //讀寫端 sbit E = P1^2; //使能端 sbit DS = P1^4; //DS18B20 sbit Hot = P2^0; //加熱 sbit Feng = P2^7; //風扇降溫 sbit Light = P3^1; sbit IR = P3^2; //紅外 sbit Alarm = P1^3; //報警 uchar table[4]; //存儲解碼數據 uchar flag = 0; uchar n = 1; uchar t = 0; #include "DS18B20.h" //DS18B20溫度轉化 #include "1602_display.h" //1602顯示 #include "IR.h" //紅外線 void Init() { TMOD = 0x11; TH1 = (65536 - 1500) / 256; TL1 = (65536 - 1500) % 256; TR1 = 0; ET1 = 1; TH0 = 0x00; TL0 = 0x00; TR0 = 0; ET0 = 1; EA = 1; Hot = 0; Init_1602(); //1602初始化 } void main () { Init(); while (1) { Decode(); //紅外線解碼 Light = 1; } } void time1() interrupt 3 { TH1 = (65536 - 1500) / 256; TL1 = (65536 - 1500) % 256; t++; if (t >= 10) { t = 0; Write_tem(DS_average());//溫度顯示 Control(); } } /*************************************/ /******功能:1602液晶控制函數*********/ /******* 1602_display.h ************/ /*************************************/ uchar code table0[] = {"Range:25.0-090.0"}; uchar code table1[] = {"tempe:"}; void delay(uchar z) { uchar x = 0; uchar y = 0; for (x=z; x>0; x--) for (y=110; y>0; y--); } bit Test() //檢忙 { bit STA7 = 0; RS = 0; RW = 1; E = 1; STA7 = (bit)(P0&0x80); delay(5); E = 0; return STA7; } void Write_order(uchar order) //寫指令 { while (Test()); //不忙檢測 RS = 0; RW = 0; P0 = order; delay(5); E = 1; delay(5); E = 0; } void Write_data(uchar dat) //寫數據 { while (Test()); //不忙檢測 RS = 1; RW = 0; P0 = dat; delay(5); E = 1; delay(5); E = 0; } uchar Read_order() //讀指令 { uchar order = 0; while (Test()); //不忙檢測 P0 = 0xff; RS = 0; RW = 1; delay(5); E = 1; delay(5); order = P0; E = 0; return order; } uchar Read_data() //讀數據 { uchar dat = 0; while (Test()); //不忙檢測 RS = 1; RW = 1; delay(5); E = 1; delay(5); dat = P0; E = 0; return dat; } void Init_1602() { uchar i = 0; Write_order(0x38); Write_order(0x0f); Write_order(0x80); //地址 i = 0; while (table0 != '\0') { Write_data(table0); i++; } Write_order(0x80 + 0x40); //地址 i = 0; while (table1 != '\0') { Write_data(table1); i++; } } void Write_tem(float tem) //寫溫度 { Write_order(0x80 + 0x46); Write_data(0x30 + (uint)tem / 100); Write_data(0x30 + (uint)tem / 10 % 10); Write_data(0x30 + (uint)tem % 10); Write_data('.'); Write_data(0x30 + (uint)(tem * 10) % 10); Write_data(0x30 + (uint)(tem * 100) % 10); Write_data(0xdf);//. Write_data('C'); Write_order(0x0c); } float Read_rang_low() //讀最小溫度范圍 { uchar num0 = 0; uchar num1 = 0; uchar num2 = 0; Write_order(0x80 + 6); Read_order(); num0 = Read_data() % 16; Write_order(0x80 + 7); Read_order(); num1 = Read_data() % 16; Write_order(0x80 + 9); Read_order(); num2 = Read_data() % 16; return (num0 * 10 + num1 + num2 * 0.1); } float Read_rang_high() //讀最大溫度范圍 { uchar num0 = 0; uchar num1 = 0; uchar num2 = 0; uchar num3 = 0; Write_order(0x80 + 11); Read_order(); num0 = Read_data() % 16; Write_order(0x80 + 12); Read_order(); num1 = Read_data() % 16; Write_order(0x80 + 13); Read_order(); num2 = Read_data() % 16; Write_order(0x80 + 15); Read_order(); num3 = Read_data() % 16; return (num0 * 100 + num1 * 10 + num2 + num3 * 0.1); } void Control() //對溫度做相應處理 { if (Get_DS() <= Read_rang_high() && Get_DS() >= Read_rang_low()) { Hot = 0; Feng = 1; Alarm = 1; } if (Get_DS() >= Read_rang_high())//溫度高,開降溫 { Feng = 0; Hot = 0; Alarm = 0; delay(100); Alarm = 1; delay(100); } if (Get_DS() <= Read_rang_low())//溫度低,開加熱 { Feng = 1; Hot = 1; Alarm = 0; delay(100); Alarm = 1; delay(100); } } /*************************************/ /*******功能:DS128B20溫度讀取*******/ /******** DS18B20.h ***********/ /**********************************/ void delayms(uchar x) { while (x--); //x=0,14.11us,x=1,20.62us,x=n,14.11+6.51n us } uchar Init_DS() { uchar x = 0; DS = 1; delayms(0); DS = 0; delayms(110); //730us DS = 1; delayms(6); //50us x = DS; delayms(67); //480us DS = 1; return x; } void Write_data_DS(uchar dat) { uchar i = 0; for (i=0; i<8; i++) { DS = 0; DS = dat&0x01; //送低位 delayms(5); //45us DS = 1; dat >>= 1; } } uchar Read_data_DS() { uchar i = 0; uchar dat = 0; for (i=0;i<8;i++) { DS = 0; dat >>= 1; DS = 1; delayms(0); //4us if (DS) dat=dat|0x80; delayms(1); } return dat; } float Get_DS() { float temp = 0; while (Init_DS()); Write_data_DS(0xcc); Write_data_DS(0x44); delayms(120); //800us while (Init_DS()); Write_data_DS(0xcc); Write_data_DS(0xbe); temp = Read_data_DS(); temp = (Read_data_DS() << 8)|(uint)temp; temp = temp * 0.0625 + 0.005; return temp; } float DS_average() //十次平均溫度值 { uchar i = 0; float temp = 0; for (i=10; i>0; i--) { temp = temp + Get_DS(); } temp = temp / 10.0; return temp; } /*************************************/ /******功能:紅外控制解碼************/ /******* IR.h *************/ /**********************************/ void Function(uchar num) //紅外控制 { switch (num) { case 11:EA = 0; //設定范圍 Alarm = 1; //關警報 n = 1; //游標定位 Write_order(0x86); Write_order(0x0f); flag = 1; break; case 12:Write_order(0x0c); //確定 flag = 0; EA=1; break; } if (flag == 1) { switch (num) { case 15:Write_order(0x86+n);//光標右移 n++; if (n == 2) n = 3; if (n == 4) n = 5; if (n == 8) n = 9; if (n == 10) n = 0; break; case 14:if (n <= 1) //光標左移 n = 11; if(n == 10) n = 9; if (n == 6) n = 5; if (n == 4) n = 3; Write_order(0x86+n-2); n--; break; case 0: case 1: case 2: //數字0—9 case 3: case 4: case 5: case 6: case 7: case 8: case 9: Write_data(0x30+num); Write_order(0x86+n); n++; if (n == 2) n = 3; if (n == 4) n = 5; if (n == 8) n = 9; if (n == 10) n = 0; break; } } } void Decode() //解碼 { uchar i = 0; uchar j = 0; uchar temp = 0; uint hightime = 0; uint lowtime = 0; uchar num = 0; TH0 = 0x00; TL0 = 0x00; TR0 = 1; while (IR == 0); TR0 = 0; lowtime = TH0 * 256 + TL0; TH0 = 0x00; TL0 = 0x00; TR0 = 1; while (IR == 1); TR0 = 0; hightime = TH0 * 256 + TL0; if (hightime > 3600 && hightime < 4600 && lowtime > 7800 && lowtime < 8800)//引導嗎 { for (i=0; i<4; i++) { for (j=0; j<8; j++) { temp >>= 1; TH0 = 0; TL0 = 0; TR0 = 1; while (IR == 0); TR0 = 0; lowtime = TH0 * 256 + TL0; TH0 = 0; TL0 = 0; TR0 = 1; while (IR == 1); TR0 = 0; hightime = TH0 * 256 + TL0; if (lowtime > 370 && lowtime < 640) { if (hightime > 420 && hightime < 640)//0 { temp = temp&0x7f; } if (hightime > 1250 && hightime < 1850)//1 { temp = temp|0x80; } } } table = temp; } if (table[2] ==~table[3]) { switch (table[2]) //用戶碼編碼 { case 22:num = 0;break; case 12:num = 1;break; case 24:num = 2;break; case 94:num = 3;break; case 8:num = 4;break; case 28:num = 5;break; case 90:num = 6;break; case 66:num = 7;break; case 82:num = 8;break; case 74:num = 9;break; case 69:num = 10;break; case 70:num = 11;break; case 71:num = 12;break; case 68:num = 13;break; case 64:num = 14;break; case 67:num = 15;break; case 7:num = 16;break; case 21:num = 17;break; case 9:num = 18;break; case 25:num = 19;break; case 13:num = 20;break; } } Light = 0; Function(num); //調用功能函數 } }
ID:38029 發表于 2012-7-11 23:59 | 只看該作者
#include<reg52.h>
sbit Light = P3^1;
uchar flag = 0;
uchar   n  = 1;
uchar   t  = 0;
void Init()
       TMOD = 0x11;
       TR1 = 0;
       ET1 = 1;
       TH0 = 0x00;
       TL0 = 0x00;
       TR0 = 0;
       ET0 = 1;
       EA = 1;
       Hot = 0;
void main ()
       Init();
       while (1)
              Decode();                   //紅外線解碼
              Light = 1;
       t++;
       if (t >= 10)
              t = 0;
              Control();
ID:38029 發表于 2012-7-12 00:00 | 只看該作者
void delay(uchar z)
       uchar x = 0;
       uchar y = 0;
       for (x=z; x>0; x--)
bit Test()                                          //檢忙
       bit STA7 = 0;
       RS = 0;
       RW = 1;
       E  = 1;
       delay(5);
       E  = 0;
       return STA7;
       RS = 0;
       RW = 0;
       P0 = order;
       delay(5);
       E = 1;
       delay(5);
       E = 0;
       RS = 1;
       RW = 0;
       P0 = dat;
       delay(5);
       E = 1;
       delay(5);
       E = 0;
       uchar order = 0;
       P0 = 0xff;
       RS = 0;
       RW = 1;
       delay(5);
       E = 1;
       delay(5);
       order = P0;
       E = 0;
       return order;
       uchar dat = 0;
       RS = 1;
       RW = 1;
       delay(5);
       E = 1;
       delay(5);
       dat = P0;
       E = 0;
       return dat;
void Init_1602()
       uchar i = 0;
       Write_order(0x38);
       Write_order(0x0f);
       i = 0;
              Write_data(table0);
              i++;
       i = 0;
              Write_data(table1);
              i++;
       Write_data('.');
       Write_data('C');
       Write_order(0x0c);
       uchar num0 = 0;
       uchar num1 = 0;
       uchar num2 = 0;
       Read_order();
       Read_order();
       Read_order();
       uchar num0 = 0;
       uchar num1 = 0;
       uchar num2 = 0;
       uchar num3 = 0;
       Read_order();
       Read_order();
       Read_order();
       Read_order();
              Hot = 0;
              Feng = 1;
              Alarm = 1;
              Feng = 0;
              Hot = 0;
              Alarm = 0;
              delay(100);
              Alarm = 1;
              delay(100);
              Feng = 1;
              Hot = 1;
              Alarm = 0;
              delay(100);
              Alarm = 1;
              delay(100);
uchar Init_DS()
       uchar x = 0;
       DS = 1;
       delayms(0);
       DS = 0;
       DS = 1;
       delayms(6);                //50us
       x = DS;
       DS = 1;
       return x;
       uchar i = 0;
       for (i=0; i<8; i++)
              DS = 0;
              delayms(5);         //45us
              DS = 1;
              dat >>= 1;
       uchar i = 0;
       uchar dat = 0;
       for (i=0;i<8;i++)
              DS = 0;
              dat >>= 1;
              DS = 1;
              delayms(0);                //4us
              if (DS)
                     dat=dat|0x80;
              delayms(1);
       return dat;
float Get_DS()
       float temp = 0;
       while (Init_DS());
       while (Init_DS());
       return temp;
       uchar i = 0;
       float temp = 0;
       temp = temp / 10.0;
       return temp;
ID:38029 發表于 2012-7-12 00:01 | 只看該作者
       switch (num)
                            Alarm = 1;                         //關警報
                            n = 1;                                 //游標定位
                            Write_order(0x86);
                            Write_order(0x0f);
                            flag = 1;
                            break;
                            flag = 0;
                            EA=1;
                            break;
       if (flag == 1)
              switch (num)
                                   n++;
                                   if (n == 2)
                                   n = 3;
                                   if (n == 4)
                                   n = 5;
                                   if (n == 8)
                                   n = 9;
                                   if (n == 10)
                                   n = 0;
                                   break;
                                   n = 11;
                                   if(n == 10)
                                   n = 9;
                                   if (n == 6)
                                   n = 5;
                                   if (n == 4)
                                   n = 3;
                                   n--;
                                   break;
                     case 9:
                                   n++;
                                   if (n == 2)
                                   n = 3;
                                   if (n == 4)
                                   n = 5;
                                   if (n == 8)
                                   n = 9;
                                   if (n == 10)
                                   n = 0;
                                   break;
void Decode()                                               //解碼
       uchar i = 0;
       uchar j = 0;
       uchar temp = 0;
       uint hightime = 0;
       uint lowtime = 0;
       uchar num = 0;
       TH0 = 0x00;
       TL0 = 0x00;
       TR0 = 1;
       while (IR == 0);
       TR0 = 0;
       TH0 = 0x00;
       TL0 = 0x00;
       TR0 = 1;
       while (IR == 1);
       TR0 = 0;
              for (i=0; i<4; i++)
                     for (j=0; j<8; j++)
                            temp >>= 1;
                            TH0 = 0;
                            TL0 = 0;
                            TR0 = 1;
                            while (IR == 0);
                            TR0 = 0;
                            TH0 = 0;
                            TL0 = 0;
                            TR0 = 1;
                            while (IR == 1);
                            TR0 = 0;
                                          temp = temp&0x7f;
                                          temp = temp|0x80;
              table = temp;
              Light = 0;
ID:42770 發表于 2012-7-12 20:06 | 只看該作者
你能幫我解釋一下關于定時計數器的意義嗎
