心率計可以將連接到板子上的心率傳感器數據采集下來并使用算法計算心率值,并通過串口傳輸到指定的終端設備。可以直接接USB-TLL模塊傳輸到PC端或者通過藍牙模塊傳輸到手機端。
- //******************************說明********************************/
- #include "stdio.h"
- #include "common.h"
- #include "heartRateProcess.h"
- #define false 0
- #define true 1
- #define FOSC 11059200L //系統時鐘
- #define BAUD 115200 //波特率
- #define T0MS (65536-FOSC/12/500) //500HZ in 12T MODE
- #define BUFFER_SIZE 10
- #define ADC_POWER 0x80 //ADC POWER CONTROL BIT
- #define ADC_FLAG 0x10 //ADC COMPLETE FLAG
- #define ADC_START 0x08; //ADC START CONTROL BIT
- #define ADC_SPEEDLL 0x00 //540 CLOCKS
- #define ADC_SPEEDL 0x20 //360 CLOCKS
- #define ADC_SPEEDH 0x40 //180 CLOCKS
- #define ADC_SPEEDHH 0x60 //90 CLOCKS
- #define ADC_MASK 0x01
- #define BLUE_SHIFT (1U << 5)
- #define BLUE_ON (GPIOD_PCOR = BLUE_SHIFT)
- #define BLUE_OFF (GPIOD_PSOR = BLUE_SHIFT)
- #define BLUE_TOGGLE (GPIOD_PTOR = BLUE_SHIFT)
- unsigned int BPM; // 用于保存脈沖速率
- unsigned int Signal; // 持有傳入的原始數據
- unsigned int IBI = 600; // 保持心跳之間的空隙,必須種子!
- unsigned char Pulse = false; // 當脈沖波高時真,低為假
- int rate[10]; // 數組來保存最后十IBI值
- unsigned long sampleCounter = 0; // used to determine pulse timing用于確定脈沖定時
- unsigned long lastBeatTime = 0; // used to find IBI
- int Peak =255; // used to find peak in pulse wave, seeded用來尋找峰值脈沖波,播種
- int Trough = 10; // used to find trough in pulse wave, seededsed中找到谷底脈搏波,播種
- int thresh = 60; // used to find instant moment of heart beat, seeded查找心跳的瞬間
- int amp = 100; // used to hold amplitude of pulse waveform, seeded用于保存脈沖波形的振幅,接種
- unsigned char firstBeat = true; // used to seed rate array so we startup with reasonable BPM用于種子率陣列,所以我們啟動與合理的BPM
- unsigned char secondBeat = false; // used to seed rate array so we startup with reasonable BPM用于種子率陣列,所以我們啟動與合理的BPM
- // Timer 0中斷子程序,每2MS中斷一次,讀取AD值,計算心率值
- //采樣率500Hz
- unsigned char heartRateCalc(unsigned char buf,uint16* ratte)
- int N;
- unsigned char i,j;
- unsigned char QS = false; // becomes true when 51 finds a beat.
- char cmd[100];
- uint16 len;
- // keep a running total of the last 10 IBI values保持過去10 個心跳間隙值運行總數
- unsigned int runningTotal = 0; // clear the runningTotal variable 清除正在運行的總變量
- j=0;
- Signal = buf; // read the Pulse Sensor 讀取脈搏傳感器
- sampleCounter += 2; // keep track of the time in mS with this variable追蹤這個變量在毫秒級
- N = sampleCounter - lastBeatTime; // monitor the time since the last beat to avoid noise因為最后一次心跳監測時間可避免噪音
- // 找到脈搏波的波谷
- if(Signal < thresh && N > (IBI/5)*3)
- { // 避免重脈噪聲最后IBI等待4/5
- if (Signal < Trough)
- { // T is the trough;T是波谷
- Trough = Signal; // 跟蹤最低點的脈沖波
- // 找到脈搏波的波峰
- if(Signal > thresh && Signal > Peak)
- { // thresh condition helps avoid noise閾值條件有助于避免噪音
- Peak = Signal; // P is the peak; P是峰
- } // keep track of highest point in pulse wave跟蹤最高點的脈沖波
- // NOW IT'S TIME TO LOOK FOR THE HEART BEAT 現在是時候去尋找心跳
- // signal surges up in value every time there is a pulse每次有一個脈沖信號涌起的價值
- if (N > 250)
- { // avoid high frequency noise 避免了高頻噪音
- if ( (Signal > thresh) && (Pulse == false) && (N > (IBI)*0.6) )
- Pulse = true; // set the Pulse flag when we think there is a pulse當我們認為有脈沖時設置脈沖標志
- // blinkPin=0; // turn on pin 13 打開LED引腳
- IBI = sampleCounter - lastBeatTime; // measure time between beats in mS
- lastBeatTime = sampleCounter; // keep track of time for next pulse
- if(secondBeat)
- { // if this is the second beat, if secondBeat == TRUE
- secondBeat = false; // clear secondBeat flag清零第二拍標志
- // for(i=0; i<=9; i++)
- // { // seed the running total to get a realisitic BPM at startup在啟動時獲得真實BPM運行總數
- // rate[9] = IBI;
- if(firstBeat)
- { // if it's the first time we found a beat, if firstBeat == TRUE
- firstBeat = false; // clear firstBeat flag 清零第一拍標志
- secondBeat = true; // set the second beat flag設置第二拍標志
- // EA=1; // enable interrupts again再次啟用中斷
- Pulse = false;
- return QS; // IBI value is unreliable so discard itIBI值是不可靠的,所以將其丟棄
- BLUE_ON;
- //程序運行到這里表示已經找到第二個節拍
- //存放節拍的數組依次往前移位,留下最后一個來裝新得到的節拍周期
- for(i=0; i<=8; i++)
- { // shift data in the rate array移動數組中的數據
- rate[i]= rate[i+1]; // and drop the oldest IBI value 并刪除最舊的IBI值
- runningTotal += rate[i]; // add up the 9 oldest IBI values將9個最古老的IBI值加起來
- //存放最新的節拍周期
- rate[9] = IBI; // add the latest IBI to the rate array添加最新IBI的速度陣列
- runningTotal += rate[9]; // add the latest IBI to runningTotal加上最新的IBI運行數
- runningTotal /= 10; // average the last 10 IBI values 平均最近10個IBI值
- BPM = 60000/runningTotal; // how many beats can fit into a minute? that's BPM!有多少心跳可以放入一分鐘?這是BPM的!
- if(BPM>200)BPM=200; //限制BPM最高顯示值
- if(BPM<30)BPM=30; //限制BPM最低顯示值
- QS = true; // set Quantified Self flag 設置量化自我標志
- len=sprintf(cmd,"Peak=%d,thresh=%d,Trough=%d,amp=%d,IBI=%d,N=%d,BPM=%d\r\n",Peak,thresh,Trough,amp,IBI,N,BPM);
- // IntfWrite(0,cmd,len);
- // QS FLAG IS NOT CLEARED INSIDE THIS ISR; QS標志不會被清除這里面中斷服務程序
- //檢測下降
- if (Signal < thresh && Pulse == true) // when the values are going down, the beat is over當值正在下降,節拍結束
- BLUE_OFF;// turn off pin 13 LED
- Pulse = false; // reset the Pulse flag so we can do it again復位脈沖標志,所以我們可以再做一次
- amp = Peak - Trough; // get amplitude of the pulse wave得到的脈搏波的振幅
- thresh = amp/2 + Trough; // set thresh at 50% of the amplitude設定閾值的幅度的50%
- Peak = thresh; // reset these for next time為下一次復位
- Trough = thresh;
- len=sprintf(cmd,"fall edge:Peak=%d,thresh=%d,Trough=%d,amp=%d,IBI=%d,N=%d,BPM=%d\r\n",Peak,thresh,Trough,amp,IBI,N,BPM);
- //重新初始化
- if (N > 2500) // if 2.5 seconds go by without a beat 如果2.5秒去,沒有一個節拍
- thresh = 50; // set thresh default設置默認的閾值
- Peak = 155; // set P default默認設置P
- Trough = 10; // set T default默認設置T
- lastBeatTime = sampleCounter; // bring the lastBeatTime up to date 最后一拍的時間
- firstBeat = true; // set these to avoid noise
- secondBeat = false; // when we get the heartbeat back
- Pulse = false;
- //EA=1; // enable interrupts when youre done!允許中斷時,大功告成!
- *ratte=BPM;
- return QS;
- }// end isr
- void filter(uint8* buf,unsigned char len)
- static uint8 x0=50,x1=50;
- uint8 i,temp;
- uint8 k=1,throd=10;
- uint8 Buff[BUFFER_SIZE+2];
- uint8 buffback[BUFFER_SIZE];
- memcpy(Buff+2,buf,len);
- //for(i=0;i<len;len++)
- // Buff[i+2]=buf[i];
- Buff[0]=x0;
- Buff[1]=x1;
- for(i=0;i<len;len++)
- if(abs(Buff[i+1]-Buff[i])>throd)
- buffback[i]=(Buff[i+2]+Buff[i])/2;
- else
- buffback[i]=Buff[i+1];
- x0=Buff[BUFFER_SIZE];
- x1=Buff[BUFFER_SIZE+1];
HeartRateTestPrj.7z
(428.99 KB, 下載次數: 9)
2019-4-5 03:44 上傳
下載積分: 黑幣 -5
