查看: 5753|回復: 8
nrf24l01無線芯片的開發板范例-AVR(已驗證通過)
ID:465246 發表于 2019-4-2 19:25 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "main.h"
#include "nRF24L01.h"
/*Bit field operations*/
#define SetBit( Byte, Bit )  ( Byte ) |= ( 1<<( Bit ) )
#define ClrBit( Byte, Bit )  ( Byte ) &= ~( 1<<( Bit ) )
#define GetBit( Byte, Bit )  ( ( Byte ) & ( 1<<( Bit ) ) )
#define ComBit( Byte, Bit )  ( Bytes ) ^= ( 1<<( Bit ) )
#define SetBits( Byte, Bits ) ( Byte ) |= ( Bits )
#define ClrBits( Byte, Bits ) ( Byte ) &= ~( Bits )
#define GetBits( Byte, Bits ) ( ( Byte ) & ( Bits ) )
#define ComBits( Byte, Bits ) ( Byte ) ^= ( Bits )
#define M32_MOSI   PB5
#define M32_MISO   PB6
#define M32_SCK    PB7
Function   : USART_SendChar( )
Description: Send a single byte via the USART
InPut      : -dt, The value you want to send
Output     : None
void USART_SendChar( unsigned char dt )
                UCSRA |= ( 1<<TXC );
                UDR = dt;
                while( !( UCSRA & ( 1<<TXC ) ) );
Function   : USART_SendArray( )
Description: Send a array of data via the USART port
InPut      : -pBuff, The buffer to store the data
             -nBytes, How many bytes do you want to send ?
Output     : None
void USART_SendArray( unsigned char* pBuff, unsigned char nBytes )
        unsigned char btmp;
        for( btmp = 0; btmp < nBytes; btmp ++ )
                USART_SendChar( *( pBuff + btmp ) );
Function   : USART_SendStr( )
Description: Send a string of data via the USART port
InPut      : pstr->the string to be sent
Output     : None
void USART_SendStr( char *pstr )
    while( *pstr )
        USART_SendChar( *pstr++ );
Function   : USART_Init( ),
Description: Initialize the USART port
InPut      : None
Output     : None
#define Bandrate    9600
#define F_CPU       12000000
void USART_Init( void )
        UCSRB = 0x00; //disable while setting baud rate
        UCSRA = 0x00;
        UCSRC = 0x86;
        UBRRL = ( F_CPU / 16 / Bandrate - 1 ) % 256;
        UBRRH = ( F_CPU / 16 / Bandrate - 1 ) >> 8;
        UCSRB = 0x98;
Function : SPI_Init( )
Description : Initialize the SPI bus
Input : None
Output: None
/*void SPI_Init( void )
    //IO config
    PORTB |= ( 1<<0 ) | ( 1<<5 ) | ( 1<<3 ) | ( 1<<2 ) | ( 1<<4 );
    DDRB |= ( 1<<0 ) | ( 1<<2 ) | ( 1<<3 ) | ( 1<<5 );
    DDRB &= ~( 1<<4 );
    SPCR = (1<<SPE) | (1<<MSTR);
    /*IO config*/
    PORTB |= ( 1<<0 ) | ( 1<<5 ) | ( 1<<6 ) | ( 1<<7 ) | ( 1<<4 );
    DDRB |= ( 1<<7 ) | ( 1<<5 ) | ( 1<<0 ) | ( 1<<4 );
    DDRB &= ~( 1<<6 );
Function : SPI_ExchangeByte( )
Description : Exchange a byte via the SPI bus
Input : -value, The byte sent
Output: The byte read.
INT8U SPI_ExchangeByte( INT8U value )
    SPDR = value;
        while ( !(SPSR & (1<<SPIF)) );
        return SPDR;
INT8U testbuffer[32];
int main( void )
    INT8U tmp;
        unsigned char ReplayData[] = {"我很好!\r\n"};
        SPI_Init( );
        USART_Init( );
        L01_Init( );
                L01_SetRXMode( );
L01_WriteHoppingPoint( 0 );
USART_SendStr( "nRF24L01P接收測試開始!\r\n" );
        while( 1 )
        for( tmp = 0; tmp < 32; tmp ++ )
            testbuffer[tmp] = tmp+0x20;
                L01_FlushRX( );
                L01_FlushTX( );
                L01_WriteRXPayload_InAck( ReplayData, sizeof( ReplayData ) );
                while( 1 )
                        tmp = L01_ReadStatusReg( );
//                        USART_SendChar(tmp);  //for test
                        tmp &= ( 1<<TX_DS ) | ( 1<<MAX_RT ) | ( 1<<RX_DR );
                        if( tmp != 0 )
                                break;
        if( tmp & ( 1<<TX_DS ) )
         //   USART_SendStr( "發送成功\r\n" );
        else if( tmp & ( 1<<MAX_RT ) )
         //   USART_SendStr( "發送失敗\r\n" );
        else if( tmp & ( 1<<RX_DR )  )
                        L01_WriteRXPayload_InAck( testbuffer, 32 );
            USART_SendStr( "收到數據:" );
                        tmp = L01_ReadRXPayload( testbuffer );
                        USART_SendArray( testbuffer, tmp );
                        USART_SendStr( "回復數據:" );
                        USART_SendStr( ( char*) ReplayData );
        L01_ClearIRQ( IRQ_ALL );
        return 0;
AVR_M16(ICC).rar
161.42 KB, 下載次數: 32, 下載積分: 黑幣 -5
ID:120111 發表于 2019-4-29 09:53 來自觸屏版 | 只看該作者
買了這個模塊還沒開始用,正好學習一下
ID:6428 發表于 2019-6-29 13:49 | 只看該作者
不錯學習下
不錯學習下
ID:574631 發表于 2019-6-29 16:31 來自觸屏版 | 只看該作者
太好了正找這個 謝謝
ID:552794 發表于 2019-6-30 13:38 | 只看該作者
版主:這是Nordic的RFID產品,該公司還有BLE4.0的nRF51822產品,版主是否也用了?很想同版主交流。
ID:6428 發表于 2019-9-6 13:43 | 只看該作者
謝謝分享0
ID:633275 發表于 2019-12-3 11:16 | 只看該作者
AVR才開始學習,之前用PIC搞過,謝謝分享
ID:702817 發表于 2020-3-5 12:35 | 只看該作者
喜歡的內容
