#include<msp430g2553.h>
#include <stdio.h>
int count=0;
int LED[4];
long fre;
//頻率部分
unsigned char LED_0F[] =
{0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x8C,0xBF,0xC6,0xA1,0x86,0xFF,0xbf};
// 0 1 2 3 4 5 6 7 8 9 A b C d E F -
/*************延時(shí)函數(shù)************/
void delay(int t)
int i,j;
for(i=0;i<t;i++)
for(j=0;j<10;j++);
//1s延時(shí)的計(jì)數(shù)閘門(mén)
void delay1(void)
unsigned long i;
for(i=0;i<119000;i++)
_NOP(); // 該函數(shù)用來(lái)產(chǎn)生一個(gè) MSP430 系統(tǒng)時(shí)鐘周期的延時(shí)
/*************430初始化函數(shù)************/
void LED_OUT(char X)
char i;
for(i=8;i>=1;i--)
if (X&0x80) P2OUT |= 0x01; else P2OUT &= ~0x01;
X<<=1;
P2OUT &= ~0x04;
P2OUT |= 0x04; // SCK 上升沿操作 數(shù)據(jù)寫(xiě)入寄出去
void display(void)
{ // 聲明計(jì)數(shù)數(shù)據(jù)變量
unsigned char *led;
char i;
led=LED_0F+LED[0];
i=*led;
LED_OUT(i); // 段選
LED_OUT(0x01); // 位選
P2OUT &= ~0x02;
P2OUT |= 0x02; // RCK上升沿操作 寄出去輸出到數(shù)碼
led=LED_0F+LED[1];
i=*led;
LED_OUT(i); // 段選
LED_OUT(0x02); // 位選
P2OUT &= ~0x02;
led=LED_0F+LED[2];
i=*led;
LED_OUT(i); // 段選
LED_OUT(0x04); // 位選
P2OUT &= ~0x02;
led=LED_0F+LED[3];
i=*led;
LED_OUT(i); // 段選
LED_OUT(0x08); // 位選
P2OUT &= ~0x02;
/*************主函數(shù)************/
void init(void)
//Time0初始化
TA1CTL = TASSEL_1 + MC_1 + TAIE;
TA1CCTL0 = CCIE;
TA1CCR0 = 32768;
//Time1初始化
TA0CCTL1 = CM_1 + CCIS_0 + CAP + CCIE;
P1DIR &= ~BIT2;//p2.0output others input
P1SEL |= BIT2;
_EINT();
void main(void)
WDTCTL=WDTPW+WDTHOLD; // 關(guān)閉看門(mén)狗
P2DIR =BIT0+BIT1+BIT2;
P1DIR=BIT6;
init();
LED[0]=0; //
LED[1]=0;
LED[2]=0;
LED[3]=0;
display();
#pragma vector=TIMER1_A0_VECTOR
__interrupt void Timer1(void)
_DINT();
fre=count;
count=0;
if(fre>=10000)
LED[0]=fre/10000;
LED[1]=fre%10000/1000;
LED[2]=fre%10000%1000/100;
LED[3]=10;
LED[0]=fre/1000;
LED[1]=fre%1000/100;
LED[2]=fre%1000%100/10;
LED[3]=fre%1000%100%10;
P1OUT ^= BIT6;
_EINT();
#pragma vector=TIMER0_A1_VECTOR
__interrupt void Timer0(void)
_DINT();
switch(TAIV)//向量查詢(xún)
case 2:count++; //捕獲中斷
break;//CCR1
case 4:break;//CCR2
case 10:
break;
_EINT();
