原理圖
#include <REG52.H>
#include <math.h>
#include <stdio.h>
#include <INTRINS.H>
typedef unsigned char uchar;
typedef unsigned short ushort;
typedef unsigned int uint;
#define DataPort P0
sbit SCL=P2^6;
sbit SDA=P2^5;
sbit LCM_RS = P3^7;
sbit LCM_RW = P3^6;
sbit LCM_EN = P3^5;
sbit LCD12864_PSB = P1^5;
sbit LCD12864_RSET = P1^3;
// 定義MPU6050內部地址
#define SMPLRT_DIV 0x19 //陀螺儀采樣率,典型值:0x07(125Hz)
#define CONFIG 0x1A //低通濾波頻率,典型值:0x06(5Hz)
#define GYRO_CONFIG 0x1B //陀螺儀自檢及測量范圍,典型值:0x18(不自檢,2000deg/s)
#define ACCEL_CONFIG 0x1C //加速計自檢、測量范圍及高通濾波頻率,典型值:0x01(不自檢,2G,5Hz)
#define ACCEL_XOUT_H 0x3B
#define ACCEL_XOUT_L 0x3C
#define ACCEL_YOUT_H 0x3D
#define ACCEL_YOUT_L 0x3E
#define ACCEL_ZOUT_H 0x3F
#define ACCEL_ZOUT_L 0x40
#define TEMP_OUT_H 0x41
#define TEMP_OUT_L 0x42
#define GYRO_XOUT_H 0x43
#define GYRO_XOUT_L 0x44
#define GYRO_YOUT_H 0x45
#define GYRO_YOUT_L 0x46
#define GYRO_ZOUT_H 0x47
#define GYRO_ZOUT_L 0x48
#define PWR_MGMT_1 0x6B //電源管理,典型值:0x00(正常啟用)
#define WHO_AM_I 0x75 //IIC地址寄存器(默認數值0x68,只讀)
#define SlaveAddress 0xD0 //IIC寫入時的地址字節數據,+1為讀取
uchar dis[4];
int dis_data;
//整數轉字符串
void lcd_printf(uchar *s,int temp_data)
if(temp_data<0)
temp_data=-temp_data;
*s='-';
else *s=' ';
*++s =temp_data/100+0x30;
temp_data=temp_data%100; //取余運算
*++s =temp_data/10+0x30;
temp_data=temp_data%10; //取余運算
*++s =temp_data+0x30;
void delay(unsigned int k)
unsigned int i,j;
for(i=0;i<k;i++)
for(j=0;j<121;j++);
void WaitForEnable(void)
DataPort=0xff;
LCM_RS=0;LCM_RW=1;_nop_();
LCM_EN=1;_nop_();_nop_();
while(DataPort&0x80);
LCM_EN=0;
void WriteCommandLCM(uchar CMD)
WaitForEnable();
LCM_RS=0;LCM_RW=0;_nop_();
DataPort=CMD;_nop_();
LCM_EN=1;_nop_();_nop_();LCM_EN=0;
void WriteDataLCM(uchar dataW)
WaitForEnable();
LCM_EN=0;LCM_RS=1;LCM_RW=0;_nop_();
DataPort=dataW;_nop_();
LCM_EN=1;_nop_();LCM_EN=0;_nop_();
void LcdPos_xy(unsigned char x,unsigned char y)
unsigned char pos;
switch(x)
case 1:pos=0x80+y-1;break;
case 2:pos=0x90+y-1;break;
case 3:pos=0x88+y-1;break;
case 4:pos=0x98+y-1;break;
default:pos=0x80+y-1;break;
WriteCommandLCM(pos|0x80);
void DisplayListChar(uchar X,uchar Y,uchar *DData)
LcdPos_xy(X,Y);
while(*DData)
WriteDataLCM(*DData++);
void InitLcd()
LCD12864_PSB = 1;//并行通信
LCD12864_RSET = 0;
delay(10);
LCD12864_RSET = 1;
WriteCommandLCM(0x30);
delay(5);
delay(5);
WriteCommandLCM(0x18);
delay(5);
WriteCommandLCM(0x10);
delay(5);
WriteCommandLCM(0x01);
delay(5);
WriteCommandLCM(0x06);
delay(5);
WriteCommandLCM(0x0c);
delay(5);
DisplayListChar(1,2,"加速度");
DisplayListChar(1,6,"角速度");
DisplayListChar(2,1,"X:");
DisplayListChar(3,1,"Y:");
DisplayListChar(4,1,"Z:");
void Delay5us()
_nop_();_nop_();_nop_();_nop_();
//I2C起始信號
void I2C_Start()
SDA = 1; //拉高數據線
SCL = 1; //拉高時鐘線
Delay5us(); //延時
SDA = 0; //產生下降沿
Delay5us(); //延時
SCL = 0; //拉低時鐘線
//I2C停止信號
void I2C_Stop()
SDA = 0; //拉低數據線
SCL = 1; //拉高時鐘線
Delay5us(); //延時
SDA = 1; //產生上升沿
Delay5us(); //延時
//I2C發送應答信號
//入口參數:ack (0:ACK 1:NAK)
void I2C_SendACK(bit ack)
SDA = ack; //寫應答信號
SCL = 1; //拉高時鐘線
Delay5us(); //延時
SCL = 0; //拉低時鐘線
Delay5us(); //延時
//I2C接收應答信號
bit I2C_RecvACK()
SCL = 1; //拉高時鐘線
Delay5us(); //延時
CY = SDA; //讀應答信號
SCL = 0; //拉低時鐘線
Delay5us(); //延時
return CY;
//向I2C總線發送一個字節數據
void I2C_SendByte(uchar dat)
uchar i;
for (i=0; i<8; i++) //8位計數器
dat <<= 1; //移出數據的最高位
SDA = CY; //送數據口
SCL = 1; //拉高時鐘線
Delay5us(); //延時
SCL = 0; //拉低時鐘線
Delay5us(); //延時
I2C_RecvACK();
//從I2C總線接收一個字節數據
uchar I2C_RecvByte()
uchar i;
uchar dat = 0;
SDA = 1; //使能內部上拉,準備讀取數據,
dat <<= 1;
SCL = 1; //拉高時鐘線
Delay5us(); //延時
dat |= SDA; //讀數據
SCL = 0; //拉低時鐘線
Delay5us(); //延時
return dat;
//向I2C設備寫入一個字節數據
void Single_WriteI2C(uchar REG_Address,uchar REG_data)
I2C_Start(); //起始信號
I2C_SendByte(SlaveAddress); //發送設備地址+寫信號
I2C_SendByte(REG_Address); //內部寄存器地址,
I2C_SendByte(REG_data); //內部寄存器數據,
I2C_Stop(); //發送停止信號
//從I2C設備讀取一個字節數據
uchar Single_ReadI2C(uchar REG_Address)
uchar REG_data;
I2C_Start(); //起始信號
I2C_SendByte(REG_Address); //發送存儲單元地址,從0開始
I2C_Start(); //起始信號
I2C_SendByte(SlaveAddress+1); //發送設備地址+讀信號
REG_data=I2C_RecvByte(); //讀出寄存器數據
I2C_SendACK(1); //接收應答信號
I2C_Stop(); //停止信號
return REG_data;
//初始化MPU6050
void InitMPU6050()
Single_WriteI2C(PWR_MGMT_1, 0x00); //解除休眠狀態
Single_WriteI2C(SMPLRT_DIV, 0x07);
Single_WriteI2C(CONFIG, 0x06);
Single_WriteI2C(GYRO_CONFIG, 0x18);
Single_WriteI2C(ACCEL_CONFIG, 0x01);
//合成數據
int GetData(uchar REG_Address)
char H,L;
H=Single_ReadI2C(REG_Address);
L=Single_ReadI2C(REG_Address+1);
return (H<<8)+L; //合成數據
//在12864上顯示10位數據
void Display10BitData(uchar x,uchar y,int value)
value/=64; //轉換為10位數據
lcd_printf(dis, value); //轉換數據顯示
DisplayListChar(x,y,dis);
delay(500); //上電延時
InitLcd(); //lcd12864液晶初始化
InitMPU6050(); //初始化MPU6050
delay(150);
Display10BitData(2,2,GetData(ACCEL_XOUT_H)); //顯示X軸加速度
Display10BitData(3,2,GetData(ACCEL_YOUT_H)); //顯示Y軸加速度
Display10BitData(4,2,GetData(ACCEL_ZOUT_H)); //顯示Z軸加速度
Display10BitData(2,6,GetData(GYRO_XOUT_H)); //顯示X軸角速度
Display10BitData(3,6,GetData(GYRO_YOUT_H)); //顯示Y軸角速度
Display10BitData(4,6,GetData(GYRO_ZOUT_H)); //顯示Z軸角速度
delay(500);
希望老貼們喜歡!!!!!
