自己在第一次使用溫度傳感器DHT11時(shí),想不用正點(diǎn)原子的源程序的那個(gè)引腳,就自己改了,但是一直沒(méi)有成功,自己也移植很多次,但是都沒(méi)有成功,今天我來(lái)回給大家說(shuō)說(shuō)怎么改吧首先
//#define DHT11_IO_IN() {GPIOA->CRL&=0XFFFFFFF0;GPIOA->CRL|=8<<0;}
//#define DHT11_IO_OUT() {GPIOA->CRL&=0XFFFFFFF0;GPIOA->CRL|=3<<0;}
#define DHT11_IO_IN() {GPIOA->CRL&=0xFFFFF0FF;GPIOA->CRL|=0x00000800;}
#define DHT11_IO_OUT() {GPIOA->CRL&=0XFFFF0FF;GPIOA->CRL|=0x00000300;}
在這里一定要改,因?yàn)槟氵@里一旦沒(méi)有改變,就算后面你改了引腳那些,都不會(huì)起作用,所以還請(qǐng)多注意
其次這里的寫法使用的時(shí)寄存器,需要對(duì)著寄存器一步步的來(lái)改
單片機(jī)源程序如下:
- #include "led.h"
- #include "delay.h"
- #include "sys.h"
- #include "usart.h"
- #include "lcd.h"
- #include "ds18b20.h"
- #include "dht11.h"
- int main(void)
- u8 t=0;
- u8 temperature;
- u8 humidity;
- u8 key = 0;
- SystemInit();
- delay_init(); //延時(shí)初始化
- // NVIC_Configuration();
- uart_init(9600);
- LED_Init();
- KEY_Init();
- LCD_Init();
- TIM3_PWM_Init(899,0); //不分頻。PWM頻率=72000000/900=80Khz
- POINT_COLOR=RED;//設(shè)置字體為紅色
- LCD_ShowString(60,50,200,16,16,"Mini STM32");
- LCD_ShowString(60,70,200,16,16,"DHT11 TEST");
- LCD_ShowString(60,90,200,16,16,"ATOM@ALIENTEK");
- LCD_ShowString(60,200,200,16,16,"modified by Leon");
- LCD_ShowString(60,110,200,16,16,"2018/7/22");
- while(DHT11_Init()) //DHT11初始化
- LCD_ShowString(60,130,200,16,16,"DHT11 Error");
- delay_ms(200);
- LCD_Fill(60,130,239,130+16,WHITE);
- delay_ms(200);
- LCD_ShowString(60,130,200,16,16,"DHT11 OK");
- POINT_COLOR=BLUE;//設(shè)置字體為藍(lán)色
- LCD_ShowString(60,150,200,16,16,"Temp: . C");
- LCD_ShowString(60,170,200,16,16,"Humi: %");
- while(1)
- if(t%10==0)//每100ms讀取一次
- DHT11_Read_Data(&temperature,&humidity); //讀取溫濕度值
- LCD_ShowNum(60+40,150,temperature,2,16); //顯示溫度
- LCD_ShowNum(60+40,170,humidity,2,16); //顯示濕度
- key=KEY_Scan(0); //得到鍵值
- switch(key)
- case KEY0_PRES:
- LED0=!LED0;
- break;
- case KEY1_PRES:
- LED1=!LED1;
- break;
- case WKUP_PRES:
- LED0=!LED0;
- LED1=!LED1;
- break;
- default:
- delay_ms(10);
mini stm32 f103rDHT11溫濕度實(shí)驗(yàn).7z
(229.45 KB, 下載次數(shù): 109)
2019-3-24 01:35 上傳
點(diǎn)擊文件名下載附件
評(píng)分
查看全部評(píng)分
