查看: 2850|回復: 1
想做一個智能汽車雨刷器,網上買的散件已經焊接好,想再加點功能,求大神看下
做了一個智能雨刷器,有手動和自動兩種模式,想在手動模式下加一些功能:在手動模式下(想在此模式下也用到雨滴傳感器,同時加上蜂鳴器),駕駛員需手動操作雨刷器。當檢測到濕度處于上下限之間時(此時若未打開雨刷器,電機未轉動 ),報警器報警提示駕駛員打開雨刷器;當檢測到濕度大于上限時(此時若雨刷器低速運行),報警器報警提示駕駛員切換檔位(高速檔)。請問下面這個程序要怎么修改???
#include <REGX52.H>
#include <ADC0832.H>
#include <LCD1602.H>
#include <eeprom52.H>
uchar i=0;
uint dat;
uint dat1=0;
uint dat2=0;
uint dat_value=0;
uint DJ_dat=0,ms=0,ms_1=0;
uchar loop=0;
sbit key_1=P3^1;
sbit key_2=P3^2;
sbit key_3=P3^3;
sbit key_4=P3^4;
sbit led0=P2^0;
sbit led1=P2^1;
bit key_1_flag=0;
bit key_2_flag=0;
bit key_3_flag=0;
bit key_4_flag=0;
bit A_M=1;
uchar speed_flag=0;
uint Value=1000;
uint water_h=0;
uint water_l=0;
uchar state=0;
bit  star_off=1,zheng_fan=1,s0=0,ir_on=0;
  uchar zz[]=                                   //正轉數據
                0x01,0x03,0x02,0x06,0x04,0x0c,0x08,0x09
  uchar fz[]=                                   //反轉數據
                0x09,0x08,0x0c,0x04,0x06,0x02,0x03,0x01
void display()
        void LCD1602_Write_Cmd(uchar cmd)
        Read_Busy();         //判斷忙,忙則等待
        LCD1602_RS = 0;
        LCD1602_RW = 0;        //拉低RS、RW操作時序情況1602課件下中文使用說明基本操作時序章節
        LCD1602_DB = cmd;//寫入命令
        LCD1602_EN = 1;         //拉高使能端 數據被傳輸到LCD1602內
        LCD1602_EN = 0;         //拉低使能以便于下一次產生上升沿
*函數名稱:LCD1602_Write_Dat
*函數功能:寫LCD1602數據
*調用:Read_Busy();
*輸入:dat:需要寫入的數據
void LCD1602_Write_Dat(uchar dat)
        Read_Busy();
        LCD1602_RS = 1;
        LCD1602_RW = 0;
        LCD1602_DB = dat;
        LCD1602_EN = 1;
        LCD1602_EN = 0;
*函數名稱:LCD1602_Dis_OneChar
*函數功能:在指定位置顯示一個字符
*調用:LCD1602_Write_Cmd(); LCD1602_Write_Dat();
*輸入:x:要顯示的橫坐標取值0-40,y:要顯示的行坐標取值0-1(0為第一行,1為第二行)
                dat:需要顯示的數據以ASCLL形式顯示
void LCD1602_Dis_OneChar(uchar x, uchar y,uchar dat)
        if(y)        x |= 0x40;
        x |= 0x80;
        LCD1602_Write_Cmd(x);
        LCD1602_Write_Dat(dat);
                   LCD1602_write(0,0x80);
               LCD1602_writebyte("Water:");
                   if(dat>99) LCD1602_write(1,0x30+dat/100%10);
                        else             LCD1602_write(1,' ');
                   if(dat>9)  LCD1602_write(1,0x30+dat/10%10);
                   LCD1602_write(1,0x30+dat%10);
               LCD1602_writebyte("% ");
                   if(A_M==0) LCD1602_writebyte("A ");
                   else       LCD1602_writebyte("M ");
                   if(star_off==0) LCD1602_writebyte("K ");
                   else       LCD1602_writebyte("G ");
                   LCD1602_write(1,0x30+speed_flag%10);
                   LCD1602_writebyte(" ");
                   dat_value=dat;
                   LCD1602_write(0,0xC0);
               LCD1602_writebyte("H:");
                   if(state==1&&s0) LCD1602_writebyte("   ");
                           if(water_h>99) LCD1602_write(1,0x30+water_h/100%10);
                            if(water_h>9)  LCD1602_write(1,0x30+water_h/10%10);
                           LCD1602_write(1,0x30+water_h%10);
               LCD1602_writebyte("L:");
                   if(state==2&&s0) LCD1602_writebyte("   ");
                           if(water_l>99) LCD1602_write(1,0x30+water_l/100%10);
                            if(water_l>9)  LCD1602_write(1,0x30+water_l/10%10);
                           LCD1602_write(1,0x30+water_l%10);
                         LCD1602_writebyte("%");
void key_dispose()
   if(key_1==0)
            LCD1602_delay(20);
      if(key_1_flag)
                           key_1_flag=0;
                         state=(state+1)%3;
         else key_1_flag=1;
   if(key_2==0)
              LCD1602_delay(20);
           if(key_2_flag)
                          key_2_flag=0;
                        if(state==1)
                           if(water_h<100)       water_h++;
                            SectorErase(0x2000);
                            byte_write(0x2000,water_h);
                        if(state==2)
                           if(water_l<water_h-1) water_l++;
                            SectorErase(0x2200);
                            byte_write(0x2200,water_l);
                        if(state==0)
                           A_M=~A_M;   star_off=1;
         else           key_2_flag=1;
   if(key_3==0)
           LCD1602_delay(20);
           if(key_3_flag)
                          key_3_flag=0;
                        if(state==1)
                           if(water_h>water_l+1) water_h--;
                        if(state==2)
                           if(water_l>0)         water_l--;
                        if(state==0)
                           if(A_M==1)
                                  star_off=~star_off;
                                  if(star_off==0) speed_flag=1;
                                  else                           speed_flag=0;
         else key_3_flag=1;
   if(key_4==0)
           LCD1602_delay(20);
           if(key_4_flag)
                  key_4_flag=0;
                  if(A_M)
                     speed_flag=(speed_flag+1)%3;
         else key_4_flag=1;
         if(A_M==0)
            led0=0;
                led1=1;
            led1=0;
                led0=1;
          if(speed_flag==2)
             Value=260;
          else  if(speed_flag==1||speed_flag==0)
             Value=500;
void police_dispose()
{        ir_on=0;
    if(dat_value>water_h)
                  star_off=0; speed_flag=2;
        else  if(dat_value>=water_l&&dat_value<=water_h)
                   star_off=0; speed_flag=1;
    else if(dat_value<water_l)
                  star_off=1;         speed_flag=0;
   water_h=byte_read(0x2000);
   water_l=byte_read(0x2200);
   if(water_h<water_l||water_h>100||water_l<0)
          water_h=60;
          water_l=10;
   TMOD=0x11;
   TH1=0x3c;
   TL1=0xb0;
   TH0=0x3c;
   TL0=0xb0;
   ET1=1;
    ET0=1;
   EA=1;
   TR0=1;
   TR1=1;
   LCD1602_cls();
           if(A_M==0)
            { police_dispose();
                  if(star_off==0)
                                      if(DJ_dat==0) loop=0;
                                 while(DJ_dat<180)
                                                        P1=P1&0xf0|zz[loop];
                                                        loop=(loop+1)%8;
                                                        if(loop==0) DJ_dat++;
                                                        LCD1602_delay(Value);
                                         if(DJ_dat==120)loop=0;
                                         while(DJ_dat!=0)
                                                        P1=P1&0xf0|fz[loop];
                                                        loop=(loop+1)%8;
                                                        if(loop==0) DJ_dat--;
                        if(speed_flag!=0)
                                  if(star_off==0)
                                                 while(DJ_dat<180)
        loop=(loop+1)%8;
                                                         while(DJ_dat!=0)
        loop=(loop+1)%8;
                              loop=0;  DJ_dat=0;
          //1毫秒定時
void time_1(void) interrupt 1
   TH0=0x3c;
   TL0=0xb0;
   ms_1++;
        if(i<10)
                i++;
                dat1+=A_D(0);               //滿量程0-255   實際完全浸入水中是255-36= 219     0-219
          i=0;
                  dat1=dat1/10;
                  if(dat1<=36)   dat1=36;
                  dat1=dat1-36;
                  dat=100-(dat1/2.19);                           dat1=0;
   if(ms_1>=10)
          ms_1=0;
          s0=~s0;
void time_0(void) interrupt 3
   TH1=0x3c;
   TL1=0xb0;
         display();
         key_dispose();
ID:757752 發表于 2020-5-21 20:50 來自觸屏版 | 只看該作者
你好,樓主,單片機大作業想借鑒一下你的這個作品,可以嗎?
