查看: 3232|回復(fù): 1
51單片機4行6列矩陣按鍵源代碼(注釋很全)
ID:492417 發(fā)表于 2019-3-17 10:52 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
這是一個4行6列矩陣按鍵原代碼
  1. #include <reg52.h>
  2. sbit KEY_IN_0 = P1^0;
  3. sbit KEY_IN_1 = P1^1;
  4. sbit KEY_IN_2 = P1^2;
  5. sbit KEY_IN_3 = P1^3;
  6. sbit KEY_IN_4 = P1^4;
  7. sbit KEY_IN_5 = P1^5;
  8. sbit KEY_OUT_1 = P3^0;
  9. sbit KEY_OUT_2 = P3^1;
  10. sbit KEY_OUT_3 = P3^2;
  11. sbit KEY_OUT_4 = P3^6;
  12. unsigned char code KeyCodeMap[4][6] = { //矩陣按鍵編號到標(biāo)準(zhǔn)鍵盤鍵碼的映射表
  13. { 0x1B,'1', '2', '3', 0x2A, 0x27 }, //ESC 鍵、數(shù)字鍵 1、數(shù)字鍵 2、數(shù)字鍵 3、向上鍵
  14. { 0x1A,'4', '5', '6', 0x2B, 0x26 }, //開關(guān)屏、數(shù)字鍵 4、數(shù)字鍵 5、數(shù)字鍵 6、向左鍵
  15. { 0x1C,'7', '8', '9', 0x2D, 0x25 }, //電機開、數(shù)字鍵 7、數(shù)字鍵 8、數(shù)字鍵 9、向下鍵
  16. { 0x1D,0X06,'0',0x2F, 0x0D, 0x28 }  //功能鍵、DEL 鍵、  數(shù)字鍵 0、回車鍵、  向右鍵
  17. };
  18. unsigned char pdata KeySta[4][6] = { //全部矩陣按鍵的當(dāng)前狀態(tài)
  19. {1, 1, 1, 1, 1, 1}, {1, 1, 1, 1, 1, 1}, {1, 1, 1, 1, 1, 1}, {1, 1, 1, 1, 1, 1}
  20. };
  21. extern void KeyAction(unsigned char keycode);
  22. /* 按鍵驅(qū)動函數(shù),檢測按鍵動作,調(diào)度相應(yīng)動作函數(shù),需在主循環(huán)中調(diào)用 */
  23. void KeyDriver()
  24. {
  25.    unsigned char i, j;
  26.    static unsigned char pdata backup[4][6] = { //按鍵值備份,保存前一次的值
  27.    {1, 1, 1, 1, 1, 1}, {1, 1, 1, 1, 1, 1}, {1, 1, 1, 1, 1, 1}, {1, 1, 1, 1, 1, 1}
  28.    };
  29.    for (i=0; i<4; i++) //循環(huán)檢測 4*4 的矩陣按鍵
  30.    {
  31.       for (j=0; j<6; j++)
  32.       {
  33.          if (backup[i][j] != KeySta[i][j]) //檢測按鍵動作
  34.          {
  35.             if (backup[i][j] != 0) //按鍵按下時執(zhí)行動作
  36.             {
  37.                 KeyAction(KeyCodeMap[i][j]); //調(diào)用按鍵動作函數(shù)
  38.             }
  39.             backup[i][j] = KeySta[i][j]; //刷新前一次的備份值
  40.          }
  41.       }
  42.    }
  43. }
  44. /* 按鍵掃描函數(shù),需在定時中斷中調(diào)用,推薦調(diào)用間隔 1ms */
  45. void KeyScan()
  46. {
  47.    unsigned char i;
  48.    static unsigned char keyout = 0; //矩陣按鍵掃描輸出索引
  49.    static unsigned char keybuf[4][6] = { //矩陣按鍵掃描緩沖區(qū)
  50.    {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF}, {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF},
  51.    {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF}, {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF}
  52.    };
  53. //將一行的 4 個按鍵值移入緩沖區(qū)
  54.    keybuf[keyout][0] = (keybuf[keyout][0] << 1) | KEY_IN_0;
  55.    keybuf[keyout][1] = (keybuf[keyout][1] << 1) | KEY_IN_1;
  56.    keybuf[keyout][2] = (keybuf[keyout][2] << 1) | KEY_IN_2;
  57.    keybuf[keyout][3] = (keybuf[keyout][3] << 1) | KEY_IN_3;
  58.    keybuf[keyout][4] = (keybuf[keyout][4] << 1) | KEY_IN_4;
  59.    keybuf[keyout][5] = (keybuf[keyout][5] << 1) | KEY_IN_5;
  60. //消抖后更新按鍵狀態(tài)
  61.    for (i=0; i<6; i++) //每行 4 個按鍵,所以循環(huán) 4 次
  62.    {
  63.       if ((keybuf[keyout][i] & 0x0F) == 0x00)
  64.       { //連續(xù) 4 次掃描值為 0,即 4*4ms 內(nèi)都是按下狀態(tài)時,可認(rèn)為按鍵已穩(wěn)定的按下
  65.          KeySta[keyout][i] = 0;
  66.       }
  67.       else if ((keybuf[keyout][i] & 0x0F) == 0x0F)
  68.       { //連續(xù) 4 次掃描值為 1,即 4*4ms 內(nèi)都是彈起狀態(tài)時,可認(rèn)為按鍵已穩(wěn)定的彈起
  69.          KeySta[keyout][i] = 1;
  70.       }
  71.    }
  72. //執(zhí)行下一次的掃描輸出
  73.     keyout++; //輸出索引遞增
  74.     keyout &= 0x03; //索引值加到 4 即歸零
  75.     switch (keyout) //根據(jù)索引,釋放當(dāng)前輸出引腳,拉低下次的輸出引腳
  76.     {
  77.         case 0: KEY_OUT_4 = 1; KEY_OUT_1 = 0; break;
  78.         case 1: KEY_OUT_1 = 1; KEY_OUT_2 = 0; break;
  79.         case 2: KEY_OUT_2 = 1; KEY_OUT_3 = 0; break;
  80.         case 3: KEY_OUT_3 = 1; KEY_OUT_4 = 0; break;
  81.         default: break;
  82.     }
  83. }
參與人數(shù) 1黑幣 +50 收起 理由
ID:328014 發(fā)表于 2019-3-20 19:45 | 只看該作者
樓主能分享下原理圖嗎?
