前幾日從某寶平臺購得一nrf24l01據悉為臺產芯片
使用單片機為STC5A60S2
代碼如下,僅供參考
- #include "STC5A60S2.H"
- #include <intrins.h>
- #include <string.h>
- #include "NRF_24L01.h"
- #include "UART.H"
- #define uchar unsigned char
- uchar const TX_ADDRESS[TX_ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01}; // Define a static TX address
- uchar rx_buf[TX_PLOAD_WIDTH];
- uchar tx_buf[TX_PLOAD_WIDTH];
- uchar flag;
- //sbit LED1= P3^7;
- unsigned char bdata sta;
- sbit RX_DR =sta^6;
- sbit TX_DS =sta^5;
- sbit MAX_RT =sta^4;
- Function: init_io();
- Description:
- flash led one time,chip enable(ready to TX or RX Mode),
- Spi disable,Spi clock line init high
- #define KEY 0xaa
- void init_nrf24l01_io(void)
- CE=0; // chip enable
- CSN=1; // Spi disable
- SCK=0; // Spi clock line init high
- Function: Inituart();
- Description:
- set uart working mode
- void delay_ms(unsigned int _ms)
- for(_ms;_ms;_ms--)
- _delay_us(1000);
- Function: SPI_RW();
- Description:
- Writes one byte to nRF24L01, and return the byte read
- from nRF24L01 during write, according to SPI protocol
- bdata unsigned char st=0;
- sbit st_1=st^0;
- sbit st_2=st^1;
- sbit st_3=st^2;
- sbit st_4=st^3;
- sbit st_5=st^4;
- sbit st_6=st^5;
- sbit st_7=st^6;
- sbit st_8=st^7;
- bdata unsigned char st1=0;
- sbit st_11=st1^0;
- sbit st_12=st1^1;
- sbit st_13=st1^2;
- sbit st_14=st1^3;
- sbit st_15=st1^4;
- sbit st_16=st1^5;
- sbit st_17=st1^6;
- sbit st_18=st1^7;
- uchar SPI_RW(uchar byte)
- uchar bit_ctr;
- for(bit_ctr=0;bit_ctr<8;bit_ctr++) // output 8-bit
- MOSI = (byte & 0x80); // output 'byte', MSB to MOSI
- byte = (byte << 1); // shift next bit into MSB..
- SCK = 1; // Set SCK high..
- MISO=1;
- byte |= MISO; // capture current MISO bit
- SCK = 0; // ..then set SCK low again
- return(byte); // return read byte
- //uchar bit_ctr;
- st=byte;
- MOSI=st_8;
- SCK = 1;
- st_18=MISO;
- SCK = 0;
- MOSI=st_7;
- SCK = 1;
- st_17=MISO;
- SCK = 0;
- MOSI=st_6;
- SCK = 1;
- st_16=MISO;
- SCK = 0;
- MOSI=st_5;
- SCK = 1;
- st_15=MISO;
- SCK = 0;
- MOSI=st_4;
- SCK = 1;
- st_14=MISO;
- SCK = 0;
- MOSI=st_3;
- SCK = 1;
- st_13=MISO;
- SCK = 0;
- MOSI=st_2;
- SCK = 1;
- st_12=MISO;
- SCK = 0;
- MOSI=st_1;
- SCK = 1;
- st_11=MISO;
- SCK = 0;
- return(st1); // return read byte
- Function: SPI_RW_Reg();
- Description:
- Writes value 'value' to register 'reg'
- uchar SPI_RW_Reg(BYTE reg, BYTE value)
- uchar status;
- CSN = 0; // CSN low, init SPI transaction
- status = SPI_RW(reg); // select register
- SPI_RW(value); // ..and write value to it..
- CSN = 1; // CSN high again
- return(status); // return nRF24L01 status byte
- Function: SPI_Read();
- Description:
- Read one byte from nRF24L01 register, 'reg'
- BYTE SPI_Read(BYTE reg)
- BYTE reg_val;
- CSN = 0; // CSN low, initialize SPI communication...
- SPI_RW(reg); // Select register to read from..
- reg_val = SPI_RW(0); // ..then read registervalue
- CSN = 1; // CSN high, terminate SPI communication
- return(reg_val); // return register value
- Function: SPI_Read_Buf();
- Description:
- Reads 'bytes' #of bytes from register 'reg'
- Typically used to read RX payload, Rx/Tx address
- uchar SPI_Read_Buf(BYTE reg, BYTE *pBuf, BYTE bytes)
- uchar status,byte_ctr;
- CSN = 0; // Set CSN low, init SPI tranaction
- status = SPI_RW(reg); // Select register to write to and read status byte
- for(byte_ctr=0;byte_ctr<bytes;byte_ctr++)
- pBuf[byte_ctr] = SPI_RW(0); // Perform SPI_RW to read byte from nRF24L01
- CSN = 1; // Set CSN high again
- Function: SPI_Write_Buf();
- Description:
- Writes contents of buffer '*pBuf' to nRF24L01
- Typically used to write TX payload, Rx/Tx address
- uchar SPI_Write_Buf(BYTE reg, BYTE *pBuf, BYTE bytes)
- for(byte_ctr=0; byte_ctr<bytes; byte_ctr++) // then write all byte in buffer(*pBuf)
- SPI_RW(*pBuf++);
- Function: RX_Mode();
- Description:
- This function initializes one nRF24L01 device to
- RX Mode, set RX address, writes RX payload width,
- select RF channel, datarate & LNA HCURR.
- After init, CE is toggled high, which means that
- this device is now ready to receive a datapacket.
- void power_off()
- CE=0;
- SPI_RW_Reg(WRITE_REG + CONFIG, 0x0D);
- CE=1;
- _delay_us(20);
- void ifnnrf_rx_mode(void)
- power_off();
- CE=0;
- SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // Use the same address on the RX device as the TX device
- SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // Enable Auto.Ack:Pipe0
- SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // Enable Pipe0
- SPI_RW_Reg(WRITE_REG + RF_CH, 40); // Select RF channel 40
- SPI_RW_Reg(WRITE_REG + RX_PW_P0, TX_PLOAD_WIDTH); // Select same RX payload width as TX Payload width
- SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); // TX_PWR:0dBm, Datarate:2Mbps, LNA:HCURR
- SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // Set PWR_UP bit, enable CRC(2 bytes) & Prim:RX. RX_DR enabled..
- CE = 1; // Set CE pin high to enable RX device
- // This device is now ready to receive one packet of 16 bytes payload from a TX device sending to address
- // '3443101001', with auto acknowledgment, retransmit count of 10, RF channel 40 and datarate = 2Mbps.
- Function: TX_Mode();
- Description:
- TX mode, set TX address, set RX address for auto.ack,
- fill TX payload, select RF channel, datarate & TX pwr.
- PWR_UP is set, CRC(2 bytes) is enabled, & PRIM:TX.
- ToDo: One high pulse(>10us) on CE will now send this
- packet and expext an acknowledgment from the RX device.
- void ifnnrf_tx_mode(void)
- power_off();
- CE=0;
- SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH); // Writes TX_Address to nRF24L01
- SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // RX_Addr0 same as TX_Adr for Auto.Ack
- SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH); // Writes data to TX payload
- SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x1a); // 500us + 86us, 10 retrans...
- SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); // Set PWR_UP bit, enable CRC(2 bytes) & Prim:TX. MAX_RT & TX_DS enabled..
- CE=1;
- void SPI_CLR_Reg(BYTE R_T)
- CSN = 0;
- if(R_T==1) // CSN low, init SPI transaction
- SPI_RW(FLUSH_TX); // ..and write value to it..
- else
- SPI_RW(FLUSH_RX); // ..and write value to it..
- void ifnnrf_CLERN_ALL()
- SPI_CLR_Reg(0);
- SPI_CLR_Reg(1);
- SPI_RW_Reg(WRITE_REG+STATUS,0xff);
- IRQ=1;
24L01_20KB_PS.rar
2019-3-14 20:45 上傳
下載積分: 黑幣 -5
112.64 KB, 下載次數: 8, 下載積分: 黑幣 -5
全部程序
