使用Silicon laboratories IDE(編譯器采用KEIL破解版)編譯時(shí),出現(xiàn)提示如下:
Invoking project defined compiler. C:\Keil\C51\BIN\C51.exe "www.c" DB OE
C51 COMPILER V7.06 - SN: K1DZP-5IUSHE COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2003
C51 COMPILATION COMPLETE. 0 WARNING(S), 0 ERROR(S) Link in progress... C:\Keil\C51\BIN\BL51.EXE @"D:\c8051\cyglink.txt"
BL51 BANKED LINKER/LOCATER V5.03 - SN: K1DZP-5IUSHE COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2002 "D:\c8051\www.obj" TO( "D:\c8051\www" ) RS(256) PL(68) PW(78)
*** FATAL ERROR L201: INVALID COMMAND LINE SYNTAX POS: 40 C:\KEIL\C51\BIN\BL51.EXE D:\c8051\www.obj TO (D:\c8051\www)#
好像是連接器有問題,請(qǐng)高人指教!!!多謝!
