查看: 3615|回復(fù): 3
51單片機LCD1602驅(qū)動代碼 視頻 仿真
ID:46381 發(fā)表于 2019-3-14 10:24 | 只看該作者 |只看大圖 回帖獎勵 |正序瀏覽 |閱讀模式
#include "Config.h"
#include <intrins.h>
sbit RS = P2^0;
sbit RW = P2^1;
sbit E= P2^2;
void LCD1602_delay_10us(unsigned char i)
        unsigned char j;
        while(i--)
        for(j=0;j<10; j++)
void LCD1602_delay_1ms(unsigned char i)
        unsigned char j;
        while(i--)
        for(j=0;j<125;j++)
void LCD1602_Write_Cmd(unsigned char cmd)
        LCD1602_delay_10us(5);
        E=0;
        RS=0;
        RW=0;
        LCD_PORT=cmd;
        LCD1602_delay_10us(5); //>40us
        E=1;
        LCD1602_delay_1ms(2); //>150us
        E=0;
        LCD1602_delay_10us(4); //>25+10us?
void LCD1602_Write_Dat(unsigned char dat)
        E=0;
        RS=1;
        RW=0;
        LCD_PORT = dat;
        E=1;
        E=0;
void LCD1602_Addr_x_y(unsigned char x,bit y)
        unsigned char temp=0x80;
        if(y)
                temp|=0x40;
        temp|=x;
        LCD1602_Write_Cmd(temp);
void LCD1602_Show_Char(unsigned char x,bit y,unsigned char p)
        LCD1602_Addr_x_y(x,y);
        LCD1602_Write_Dat(p);
void LCD1602_Show_String(unsigned char x,bit y,char *ptr,unsigned char data_len)
        unsigned char i;
        for (i=0;i<data_len;i++)
                LCD1602_Show_Char(x++,y,*(ptr+i));
void LCD1602_Init(void)
        LCD1602_delay_1ms(1500);
        LCD1602_Write_Cmd(0x38);
        LCD1602_delay_1ms(5);
        LCD1602_Write_Cmd(0x08);
        LCD1602_Write_Cmd(0x06);
        LCD1602_Write_Cmd(0x0c);
        LCD1602_Write_Cmd(0x01);
實錄視頻連接
鏈接:https://pan.baidu.com/s/1c1lEja-Kx6IEvJIS74ZpPQ
提取碼:m66j
復(fù)制這段內(nèi)容后打開百度網(wǎng)盤手機App,操作更方便哦
仿真電路圖
仿真電路圖
參與人數(shù) 1黑幣 +50 收起 理由
收藏收藏2 分享淘帖 頂 踩
ID:520954 發(fā)表于 2019-4-24 23:04 來自觸屏版 | 只看該作者
這是輸出什么的
ID:516331 發(fā)表于 2019-4-19 15:01 | 只看該作者
好資料,大佬
ID:47652 發(fā)表于 2019-4-18 20:21 | 只看該作者
好資料,收藏了,
