查看: 3740|回復: 0
STM8L051F3 寄存器版 串口驅動
ID:46381 發表于 2019-3-9 20:25 | 顯示全部樓層 |閱讀模式
#include "Config.h"
u8 Uart_Receive_Flag=0;
u8 Uart_Send_len=0;
u16 Uart_Receive_len=0;
u8 Uart_Receive_Ack_len=0;      //期望 接收到的ACK 長茺
u8 Uart_Send_Buf[UART_SEND_LEN];
u8 Uart_Receive_Buf[UART_RECEIVE_LEN];
void UART1_IO_Config(void)
  PA_DDR_DDR3 =0;//輸入
  PA_CR1_C13  =1;//上拉輸入
  PA_CR2_C23 =0;
  PA_ODR_ODR2 =1;
  PA_CR1_C12  =1;//推挽輸出
  PA_CR2_C22  =1;//輸出擺率10M
  PA_DDR_DDR2 =1;//輸出高電平,TX空閑狀態為高電平,如果不設置,會莫名奇妙的發送0x00
    //開啟引腳的UART功能
    //00: USART1_TX on PC3 and USART1_RX on PC2
    //01: USART1_TX on PA2 and USART1_RX on PA3
    //10: USART1_TX on PC5 and USART1_RX on PC6
    SYSCFG_RMPCR1_USART1TR_REMAP =1;//PC2,PC3      這個要搞懂
    //如果需要使用其他引腳作為串口發送接收引腳,請在這里選擇
void UART1_CLK_EN()
  CLK_PCKENR1_PCKEN15=1;//開啟USART外設時鐘
void UART1_CLK_DIS()
  CLK_PCKENR1_PCKEN15=0;//開啟USART外設時鐘
void UART1_Mode_Config()
    //設置串口工作方式
    USART1_CR1_M =0;//1 start bit,8 data bit,n stop bit
    USART1_CR3_STOP0=0;USART1_CR3_STOP1=0;//1 stop bit
    //設置波特率
    //波特率設置為9600
    // 2000000/9600=208    //2000000是此時系統的主時鐘頻率,默認8分頻,16M/8=2M
    //208(DEC)=00D0(HEX)
    USART1_BRR2 =0x03;//the BRR2 should be programmed before BRR1
    USART1_BRR1 =0x68;
    USART1_CR2_TEN=1;//使能發送
//    USART1_CR2_TIEN=0;//打開發送中斷
    USART1_CR2_REN=1;//使能接收.
    USART1_CR2_RIEN=1;//打開接收中斷
void UART1_NVID_Config()
void UART1_Config()
  UART1_IO_Config();
  UART1_CLK_EN();
  UART1_Mode_Config();// 9600 8 1  發送 接收 接收中斷
  UART1_NVID_Config();
void Uart1_Send_Data(unsigned char  data)
  while(0       ==      USART1_SR_TXE);        //判斷發送數據寄存器是否為空
  USART1_DR     =       data;                //向發送寄存器寫入數據
void Uart1_Send_String(u8 *data,u8 len,u8 enter_en)
u8 i=0;
for(i=0;i<len;i++)
  Uart1_Send_Data(data[i]);
if(ENTER_EN          ==     enter_en )
  Uart1_Send_Data(0x0D);
  Uart1_Send_Data(0x0A);
void UART_Receive_Buf_Clear()
  Uart_Receive_len      =       0;
  Uart_Receive_Flag     =       0;
void Send_ADC_Value(void)
  Uart1_Send_String("val= ",5,ENTER_DIS);
  Uart1_Send_Data(VDD_Value1/10 +0x30);
  Uart1_Send_Data(VDD_Value1%10 +0x30);
  Uart1_Send_String("V",1,ENTER_EN);
#pragma vector=USART_T_TXE_vector
__interrupt void USART_TX_ISR (void)
  if(USART1_SR_TC==1);
#pragma vector=USART_R_RXNE_vector
__interrupt void USART_RX_ISR(void)
  u8 ch;
  if(1  ==      USART1_SR_RXNE)
     Uart_Receive_Flag          |=       TRUE;
     if(0x8000    !=      (Uart_Receive_len&0x8000))
        Uart_Receive_Buf[Uart_Receive_len++]        =       USART1_DR;
        if((Uart_Receive_len>=UART_RECEIVE_LEN)||(Uart_Receive_len>=Uart_Receive_Ack_len))
          Uart_Receive_len     |=      0x8000;
      ch        =       USART1_DR;
