使用單片機(jī),每秒,通過串口發(fā)個(gè)10個(gè)字節(jié)的數(shù)據(jù)到電腦,然后點(diǎn)燈(每秒取反),讓蜂鳴器響或不響。
需要使用到定時(shí)器和定時(shí)器中斷和串口中斷。
單片機(jī)源程序如下:
- #include<reg52.h>
- #define uint unsigned int
- #define uchar unsigned char
- char code num[]={0x44,0x5f,0x34,0x15,0x0f,0x85,0x84,0x57,0x04,0x05};
- char code fnum[]={0x40,0x5b,0x30,0x11,0x0b,0x81,0x80,0x53,0x00,0x01};
- uchar f_shi,f_ge,shi,ge,num1,a=0,b=0,j,i=4;
- void matrixkeyscan();
- void delayms(uint xms);
- void display(uchar, uchar, uchar, uchar );
- void main()
- TMOD=0x11;
- TH0=(65536-45872)/256;
- TL0=(65536-45872)%256;
- TH1=(65536-458)/256;
- TL1=(65536-458)%256;
- EA=1;
- ET0=1;
- TR0=1;
- ET1=1;
- TR1=1;
- while(1)
- matrixkeyscan();
- void display(uchar f_shi,uchar f_ge,uchar shi,uchar ge)
- P3=0xfb;P1=num[f_shi];P1=0Xff;
- P3=0xf7;P1=fnum[f_ge];P1=0Xff;
- P3=0xef;P1=num[shi]; P1=0Xff;
- P3=0xdf;P1=num[ge]; P1=0Xff;
- uint i,j;
- for(i=xms;i>0;i--)
- for(j=110;j>0;j--);
- uchar temp,key;
- P2=0Xfe;
- temp=P2;
- temp=temp&0xf0;
- if(temp != 0xf0)
- delayms(10);
- temp=P2;
- temp=temp & 0xf0;
- if(temp != 0xf0)
- temp=P2;
- switch(temp)
- case 0x7e: j=0;
- break;
- case 0xbe: j=1;
- break;
- case 0xde: j=2;
- break;
- case 0xee: j=3;
- break;
- while(temp != 0Xf0)
- temp=P2;
- temp=temp&0xf0;
- P2=0Xfd;
- temp=P2;
- temp=temp&0xf0;
- if(temp != 0xf0)
- delayms(10);
- temp=P2;
- temp=temp & 0xf0;
- if(temp != 0xf0)
- temp=P2;
- switch(temp)
- case 0x7d: j=4;
- break;
- case 0xbd: j=5;
- break;
- case 0xdd: j=6;
- break;
- case 0xed: j=7;
- break;
- temp=P2;
- temp=temp&0xf0;
- P2=0Xfb;
- temp=P2;
- temp=temp&0xf0;
- if(temp != 0xf0)
- delayms(10);
- temp=P2;
- temp=temp & 0xf0;
- if(temp != 0xf0)
- temp=P2;
- switch(temp)
- case 0x7b: j=8;
- break;
- case 0xbb: j=9;
- break;
- case 0xdb: j=0;
- break;
- case 0xeb: j=0;
- break;
- temp=P2;
- temp=temp&0xf0;
- P2=0Xf7;
- temp=P2;
- temp=temp&0xf0;
- if(temp != 0xf0)
- delayms(10);
- temp=P2;
- temp=temp & 0xf0;
- if(temp != 0xf0)
- temp=P2;
- switch(temp)
- case 0x77: i=0;
- break;
- case 0xb7: i=1;
- break;
- case 0xd7: i=2;
- break;
- case 0xe7: i=3;
- break;
- temp=P2;
- temp=temp&0xf0;
- void chronograph() interrupt 1
- if(i==0)
- switch(j)
- case 0: f_shi=0; i=4;break;
- case 1: f_shi=1; i=4;break;
- case 2: f_shi=2; i=4;break;
- case 3: f_shi=3; i=4;break;
- case 4: f_shi=4; i=4;break;
- case 5: f_shi=5; i=4;break;
- if(i==1)
- switch(j)
- case 0: f_ge=0; i=4;break;
- case 1: f_ge=1; i=4;break;
- case 2: f_ge=2; i=4;break;
- case 3: f_ge=3; i=4;break;
- case 4: f_ge=4; i=4;break;
- case 5: f_ge=5; i=4;break;
- case 6: f_ge=6; i=4;break;
- case 7: f_ge=7; i=4;break;
- case 8: f_ge=8; i=4;break;
- case 9: f_ge=9; i=4;break;
- if(i==2)
- switch(j)
- case 0: shi=0; i=4;break;
- case 1: shi=1; i=4;break;
- case 2: shi=2; i=4;break;
- case 3: shi=3; i=4;break;
- case 4: shi=4; i=4;break;
- case 5: shi=5; i=4;break;
- if(i==3)
- switch(j)
- case 0: ge=0; i=4;break;
- case 1: ge=1; i=4;break;
- case 2: ge=2; i=4;break;
- case 3: ge=3; i=4;break;
- case 4: ge=4; i=4;break;
- case 5: ge=5; i=4;break;
- case 6: ge=6; i=4;break;
- case 7: ge=7; i=4;break;
- case 8: ge=8; i=4;break;
- case 9: ge=9; i=4;break;
- num1++;
- if(num1==20)
- num1=0;
- ge++;
- if(ge==10)
- ge=0;
- shi++;
- if(shi==6)
- shi=0;
- f_ge++;
- if(f_ge==10)
- f_ge=0;
- f_shi++;
- if(f_shi==6)
- ge=0;
- shi=0;
- f_ge=0;
- f_shi=0;
- void xianshi() interrupt 3
- display(f_shi,f_ge,shi,ge);
單片機(jī)編程4.zip
(27.77 KB, 下載次數(shù): 5)
2019-3-9 12:56 上傳
點(diǎn)擊文件名下載附件
