查看: 2142|回復: 0
本人剛學單片機不久,分享下天空之城的電子琴源程序,希望能幫到更多的初學者朋友
ID:441855 發表于 2019-3-8 11:01 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <REG52.H>
#include <INTRINS.H>
//頻率常數即音樂術語中的音調,而節拍常數即音樂術語中的多少拍;
//所以拿出譜子, 試探編吧!
sbit Beep =  P1^5;
unsigned char n=0;  //n為節拍常數變量
unsigned char code music_tab[] ={
0x1c, 0x30, 0x19, 0x30, 0x18, 0x40, 0x19, 0x30,
0x18, 0x30, 0x13, 0x30, 0x19, 0x18, 0x26, 0x30,
0x26, 0x30, 0x1c, 0x40, 0x20, 0x30, 0x1c, 0x30,
0x18, 0x30, 0x20, 0x60, 0x26, 0x30, 0x26, 0x30,
0x24, 0x40, 0x26, 0x30, 0x24, 0x30, 0x18, 0x40,
0x26, 0x60, 0x18, 0x20, 0x18, 0x20, 0x18, 0x20,
0x19, 0x40, 0x24, 0x30, 0x24, 0x30, 0x19, 0x30,
0x19, 0x60, 0x1c, 0x30, 0x19, 0x30, 0x18, 0x40,
0x19, 0x30, 0x18, 0x30, 0x13, 0x30, 0x19, 0x60,
0x26, 0x30, 0x26, 0x30, 0x1c, 0x40, 0x20, 0x30,
0x1c, 0x30, 0x18, 0x30, 0x20, 0x80, 0x26, 0x30,
0x24, 0x30, 0x24, 0x30, 0x18, 0x30, 0x19, 0x20,
0x19, 0x30, 0x18, 0x30, 0x15, 0x20, 0x15, 0x20,
0x13, 0x20, 0x18, 0x40, 0x18, 0x30, 0x19, 0x30,
0x1c, 0x20, 0x1c, 0x20, 0x19, 0x30, 0x20, 0x30,
0x1c, 0x60, 0x18, 0x30, 0x15, 0x30, 0x13, 0x40,
0x15, 0x30, 0x13, 0x30, 0x10, 0x30, 0x15, 0x60,
0x20, 0x30, 0x20, 0x30, 0x18, 0x30, 0x19, 0x30,
0x18, 0x30, 0x13, 0x30, 0x13, 0x60, 0x1c, 0x20,
0x19, 0x20, 0x18, 0x30, 0x19, 0x30, 0x15, 0x20,
0x15, 0x20, 0x18, 0x40, 0x20, 0x30, 0x20, 0x30,
0x12, 0x30, 0x13, 0x30, 0x15, 0x30, 0x18, 0x30,
0x13, 0xc0, 0x13, 0x80, 0x13, 0x30, 0x0e, 0x80,
0x10, 0x30, 0x10, 0x30, 0x13, 0x20, 0x15, 0x20,
0x18, 0x40, 0x18, 0x30, 0x15, 0x30, 0x18, 0x20,
0x15, 0x20, 0x15, 0x30, 0x10, 0x30, 0x13, 0x60,
0x13, 0x30, 0x0e, 0x60, 0x10, 0x60, 0x13, 0x20,
0x15, 0x20, 0x18, 0x40, 0x18, 0x30, 0x15, 0x30,
0x15, 0x20, 0x18, 0x20, 0x15, 0x30, 0x19, 0x30,
0x1c, 0x60, 0x1c, 0x30, 0x19, 0x30, 0x1c, 0xc0,
0x00,
void int0()  interrupt 1   //采用中斷0 控制節拍
{  TH0=0xd8;
   TL0=0xef;
   n--;
void delay (unsigned char m)   //控制頻率延時
unsigned i=3*m;
while(--i);
void delayms(unsigned char a)  //豪秒延時子程序
  while(--a);                  //采用while(--a) 不要采用while(a--); 各位可編譯一下看看匯編結果就知道了!
{ unsigned char p,m;   //m為頻率常數變量
  unsigned char i=0;
  TMOD&=0x0f;
  TMOD|=0x01;
  TH0=0xd8;TL0=0xef;
  IE=0x82;
play:
    a: p=music_tab[i];
       if(p==0x00)       { i=0, delayms(1000); goto play;}     //如果碰到結束符,延時1秒,回到開始再來一遍
       else if(p==0xff)  { i=i+1;delayms(100),TR0=0; goto a;}  //若碰到休止符,延時100ms,繼續取下一音符
            else         {m=music_tab[i++], n=music_tab[i++];}  //取頻率常數 和 節拍常數
             TR0=1;                                             //開定時器1
           while(n!=0) Beep=~Beep,delay(m);                         //等待節拍完成, 通過P1口輸出音頻(可多聲道哦!)
       TR0=0;                                             //關定時器1
電子琴-天空之城 .rar
20.44 KB, 下載次數: 4, 下載積分: 黑幣 -5
