基于stm32的智能插座設(shè)計,其中包含hlw8012和DHT11和iaq等傳感器設(shè)計代碼,用于測量電流電壓功率和溫度濕度和空氣中的TVOC值。同時也用到了i2c。
單片機(jī)源程序如下:
- #include "pbdata.h"
- extern u8 P_mode_flag;
- extern u8 I_mode_flag;
- extern u8 V_mode_flag;
- extern u8 close_IT_flag;
- u8 select_mode(u8 Mode)//默認(rèn)為電流模式,返回值為當(dāng)前的模式
- if(Mode ==1)
- HLW8012_SEL_L;
- else
- HLW8012_SEL_H;
- return Mode ;
- float HLW_avg(float *PULSE_T)
- u16 k;
- float avg_8012=0;
- for(k=0;k<10;k++)
- avg_8012= avg_8012+*(PULSE_T+k);
- avg_8012=avg_8012/10;
- return avg_8012 ;
- float HLW_V_DATA_CAL(float mea_V,float avg_8012)
- mea_V=(cal_V*cal_V_T)/avg_8012;
- return mea_V;
- float HLW_I_DATA_CAL(float mea_I,float avg_8012)
- mea_I=(cal_I*cal_I_T)/avg_8012;
- return mea_I;
- float HLW_P_DATA_CAL(float mea_P,float avg_8012)
- mea_P=(cal_P*cal_P_T)/avg_8012;
- return mea_P;
- void HLW_close_IT(void)
- TIM3->CR1 &= ~(0x01);
- EXTI->IMR&=~(1<<1);//屏蔽line11上的中斷
- EXTI->IMR&=~(1<<2);//屏蔽line11上的中斷
- P_mode_flag=0;
- I_mode_flag=0;
- V_mode_flag=0;
- float HLW_P_factor(float mea_P,float mea_V,float mea_I)
- float P_factor;
- P_factor=mea_P/(mea_V *mea_I );
- return P_factor;
- void HLW_8012_data(float mea_P,float mea_V,float mea_I,float P_factor)
- printf("有效電壓為: %.3f V\r\n",mea_V);
- printf("有效電流為: %.3f A\r\n",mea_I);
- printf("有功功率為: %.3f W\r\n",mea_P);
- P_factor =HLW_P_factor(mea_P,mea_V,mea_I);
- printf("功率因數(shù)為: %3f \r\n", P_factor);
復(fù)制代碼- #include "pbdata.h"
- float mea_P; //測量的有效功率
- float mea_apparent_P_; //測量的視在功率
- float P_factor ; //測量的功率因數(shù)
- float mea_V; //測量的電壓
- float mea_I; //測量的電流
- u8 shift_Mode=0;
- u8 P_mode_flag=0;
- u8 I_mode_flag=0;
- u8 V_mode_flag=0;
- u8 close_IT_flag=0;
- u8 DHT11_sd;
- u8 DHT11_wd;
- u8 iaq_Read_buf[9]; //讀取的數(shù)據(jù)存放的數(shù)組
- u16 iaq_pred;
- u8 iaq_status;
- s32 iaq_res;
- u16 iaq_tvoc;
- u32 ad=0; //存放ADC1讀取的數(shù)值
- u32 ad1=0;//存放ADC2讀取的數(shù)值
- u8 i=0;
- u8 j=0;
- double gl=0.5;
- double dy=1,dl=0.3;
- int main(void)
- RCC_Configuration(); //系統(tǒng)時鐘初始化
- GPIO_Configuration();//端口初始化
- USART_Configuration();//串口配置
- NVIC_Configuration(); //中斷優(yōu)先級配置
- ADC_Configuration(); //ADC
- ADC2_Configuration();
- I2C_Self_Init();//軟件模擬I2C
- EXTI_Configuration();
- // TIM3_Configuration();//定時中斷配置
- LCD_Init(); //液晶屏初始化
- LCD_Show();
- while(1)
程序.zip
(3.26 KB, 下載次數(shù): 78)
2019-3-8 02:04 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
