查看: 5598|回復: 3
*** ERROR L104: MULTIPLE PUBLIC DEFINITIONS 求看看編程問題
ID:478396 發表于 2019-2-28 11:50 | 顯示全部樓層 |閱讀模式
Rebuild target 'Target 1'
compiling 18b20.c...
compiling L1602.C...
linking...
    SYMBOL:  MAIN
    MODULE:  .\L1602.obj (L1602)
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
    SEGMENT: ?PR?MAIN?L1602
Program Size: data=28.0 xdata=0 code=851
Target not created.
Build Time Elapsed:  00:00:01
  1. #include<reg52.h>
  2. sbit RS = P2^0;
  3. sbit RW = P2^1;
  4. sbit EN = P2^2;
  5. #define RS_CLR RS=0
  6. #define RS_SET RS=1
  7. #define RW_CLR RW=0
  8. #define RW_SET RW=1
  9. #define EN_CLR EN=0
  10. #define EN_SET EN=1
  11. void delay_us(unsigned int r) /{
  12. if (r== 0)
  13.   {
  14.   return ;
  15.   }
  16.   while (--r);
  17. }
  18. void delay_ms(unsigned char f)
  19. {
  20. unsigned char k, u;
  21. for (k = 1; k < f; k++)
  22. {
  23.    for (u = 1;u; u++)
  24.    {   ;   }
  25.     }
  26. }
  27. void LCD_write_com(unsigned char com)
  28. {
  29. RS_CLR;
  30. RW_CLR;
  31. EN_SET;
  32. P0 = com;
  33. delay_us(5);
  34. EN_CLR;
  35. }
  36. void LCD_write_Data(unsigned char Data)
  37. {
  38. RS_SET;
  39. RW_CLR;
  40. EN_SET;
  41. P0 = Data;
  42. delay_us(5);
  43. EN_CLR;
  44. }
  45. void LCD_clear(void)
  46. {
  47. LCD_write_com(0x01);
  48. delay_ms(5);}
  49. void LCD_write_str(unsigned char x1,unsigned char y1,unsigned char *s)
  50. {
  51. if (y1 == 0)
  52. {
  53. LCD_write_com(0x80 + x1);
  54. }
  55. else
  56. {
  57. LCD_write_com(0xC0 + x1);
  58. }
  59. while (*s)
  60. {
  61. LCD_write_Data( *s);
  62. s ++;
  63. }
  64. }
  65. void LCD_write_char(unsigned char x1,unsigned char y1,unsigned char Data)
  66. {
  67. if (y1 == 0)
  68. {
  69. LCD_write_com(0x80 + x1);
  70. }
  71. else
  72. {
  73. LCD_write_com(0xC0 + x1);
  74. }
  75. LCD_write_Data( Data);
  76. }
  77. void LCD_init(void)
  78. {
  79.    LCD_write_com(0x38);
  80.    delay_ms(5);
  81.    LCD_write_com(0x38);
  82.    delay_ms(5);
  83.    LCD_write_com(0x38);
  84.    delay_ms(5);
  85.    LCD_write_com(0x38);
  86.    LCD_write_com(0x08);
  87.    LCD_write_com(0x01);
  88.    LCD_write_com(0x06);
  89.    delay_ms(5);
  90.    LCD_write_com(0x0C);
  91.    }
  92.
  93.    void main(void)
  94. {
  95.   unsigned char i2;
  96. unsigned char *p;
  97. delay_ms(100);
  98. LCD_init();
  99. while (1)
  100. {
  101. i2 = 1;
  102. p = "222222";
  103. LCD_clear();
  104. LCD_write_str(2,0,"Welcome to");
  105. delay_ms(250);
  106. while (*p)
  107. {
  108. LCD_write_char(i2,1,*p);
  109. i2 ++;
  110. p ++;
  111. delay_ms(250);
  112. }
  113. delay_ms(250);
  114. }
  115. }
ID:94031 發表于 2019-2-28 16:36 | 顯示全部樓層
多重定義,要看整個工程才能找到具體原因。
ID:404160 發表于 2019-2-28 17:09 | 顯示全部樓層
L1602模塊和main模塊有同名的定義。
ID:758285 發表于 2020-5-25 16:22 | 顯示全部樓層
我和你問題一模一樣 請問你解決了嗎
