簡易溫控器程序 簡易溫控器 DS18B20 掉電儲存 藍牙無線讀取 長短鍵設(shè)置 LCD1602顯示
- // 業(yè)余愛好簡易無線溫控
- //DS18B20 LCD1602顯示 按鍵設(shè)置 增加 長短鍵 上限 下限 設(shè)置值掉電保存 無線APP讀取
- //函數(shù)文件
- //主函數(shù) 溫度讀取 LCD1602 按鍵 I2C
- #include <reg52.h>
- #include <intrins.h>
- #include<string.h>
- sfr PLC = 0x97;
- bit flag1s = 0; //1s 定時標(biāo)志
- unsigned char T0RH = 0; //T0 重載值的高字節(jié)
- unsigned char T0RL = 0; //T0 重載值的低字節(jié)
- void ConfigTimer0(unsigned int ms);
- unsigned char IntToString(unsigned char *str, int dat);
- extern bit Start18B20();
- extern bit Get18B20Temp(int *temp);
- extern void shumaguanb(signed char sed);
- extern void shumaguana(signed char sec);
- unsigned char shangcha ();
- unsigned char xiacha() ;
- extern void saomiao();
- extern tm1637(unsigned char C,S) ;
- extern void InitLcd1602();
- extern void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
- extern void xianshi(unsigned char x,sec);
- extern unsigned char shezhi();
- extern void I2CStart();
- extern void I2CStop();
- extern unsigned char I2CReadNAK();
- extern bit I2CWrite(unsigned char dat);
- unsigned char E2ReadByte(unsigned char addr);
- void E2WriteByte(unsigned char addr, unsigned char dat);
- bit cmdArrived = 0; //命令到達標(biāo)志,即接收到上位機下發(fā)的命令
- unsigned char cmdIndex ; //命令索引,即與上位機約定好的數(shù)組編號
- unsigned char cntTxd = 0; //串口發(fā)送計數(shù)器
- unsigned char *ptrTxd; //串口發(fā)送指針
- unsigned char array1[20] = "1-Hello! \r\n";
- void ConfigUART(unsigned int baud);
- unsigned char R[10]="C-Tmpe\r\n";
- unsigned char T[10]="C-Scz\r\n";
- unsigned char M[10]="C-Xcz\r\n";
- unsigned char d[20];
- unsigned char sc[10];
- unsigned char xc[10];
- sbit out=P2^5;//溫度輸出
- sbit K=P1^4;
- void main()
- static unsigned char shangchazhi;
- static unsigned char xiachazhi;
- unsigned char c;
- bit res;
- int temp; //讀取到的當(dāng)前溫度值
- int intT, decT; //溫度值的整數(shù)和小數(shù)部分
- unsigned char len;
- unsigned char str[12];
- unsigned char S[12];
- unsigned char X[12];
- shangchazhi=E2ReadByte(0x02);
- xiachazhi=E2ReadByte(0x05);
- EA = 1; //開總中斷
- ConfigTimer0(10); //T0 定時 10ms
- ConfigUART(9600); //配置波特率為 9600
- Start18B20(); //啟動 DS18B20
- InitLcd1602(); //初始化液晶
- while (1)
- K=0;
- if (cmdArrived)
- cmdArrived = 0;
- if( cmdIndex=='A')
- strcpy(d,str);
- strcat(d,R);
- ptrTxd =d; //數(shù)組 1 的首地址賦值給發(fā)送指針
- cntTxd = sizeof(d); //數(shù)組 1 的長度賦值給發(fā)送計數(shù)器
- TI = 1; //手動方式啟動發(fā)送中斷,處理數(shù)據(jù)發(fā)送
- else if (cmdIndex=='B')
- len = IntToString(sc, shangchazhi); //整數(shù)部分轉(zhuǎn)換為字符串
- sc[len] = '\0';
- strcpy(d,sc);
- strcat(d,T);
- else if (cmdIndex=='C')
- len = IntToString(xc, xiachazhi); //整數(shù)部分轉(zhuǎn)換為字符串
- xc[len] = '\0';
- strcpy(d,xc);
- strcat(d,M);
- if (flag1s) //每秒更新一次溫度
- flag1s = 0;
- res = Get18B20Temp(&temp); //讀取當(dāng)前溫度
- if (res) //讀取成功時,刷新當(dāng)前溫度顯示
- intT = temp >> 4; //分離出溫度值整數(shù)部分
- decT = temp & 0xF; //分離出溫度值小數(shù)部分
- len = IntToString(str, intT); //整數(shù)部分轉(zhuǎn)換為字符串
- str[len++] = '.'; //添加小數(shù)點
- decT = (decT*10) / 16; //二進制的小數(shù)部分轉(zhuǎn)換為 1 位十進制位
- str[len++] = decT + '0'; //十進制小數(shù)位再轉(zhuǎn)換為 ASCII 字符
- while (len < 6) //用空格補齊到 6 個字符長度
- str[len++] = ' ';
- str[len] = '\0'; //添加字符串結(jié)束符
- LcdShowStr(0, 0, "Temp") ;
- LcdShowStr(5, 0, str); //顯示到液晶屏上
- else //讀取失敗時,提示錯誤信息
- LcdShowStr(0, 0, "error!");
- if (intT>=shangchazhi)
- out=1;
- LcdShowStr(11, 0, "OFF");
- else if (intT<=xiachazhi)
- LcdShowStr(11, 0, "ON");
- out=0;
- Start18B20(); //重新啟動下一次轉(zhuǎn)換
- LcdShowStr(0, 1, "B-") ;
- S[0] = (shangchazhi/100%10) + '0';
- S[1] = (shangchazhi/10%10) + '0';
- S[2] = (shangchazhi%10) + '0';
- S[3] = '\0';
- LcdShowStr(3, 1, S) ; //上差顯示
- LcdShowStr(7, 1, "C-") ;
- X[0] = (xiachazhi/100%10) + '0';
- X[1] = (xiachazhi/10%10) + '0';
- X[2] = (xiachazhi%10) + '0';
- X[3] = '\0';
- LcdShowStr(11, 1, X) ; //上差顯示
- c=shezhi();
- if (c==0)
- { c=shezhi();
- LcdShowStr(15, 0,"A" ); //顯示到液晶屏上
- if(c==1)
- shangchazhi= shangcha();
- LcdShowStr(15, 0,"B" ); //顯示到液晶屏上
- E2WriteByte(0x02, shangchazhi);
- if (c==2)
- xiachazhi=xiacha();
- LcdShowStr(15, 0,"C" ); //顯示到液晶屏上
- E2WriteByte(0x05, xiachazhi);
- /* 整型數(shù)轉(zhuǎn)換為字符串, str-字符串指針, dat-待轉(zhuǎn)換數(shù),返回值-字符串長度 */
- signed char i = 0;
- unsigned char len = 0;
- unsigned char buf[6];
- if (dat < 0) //如果為負數(shù),首先取絕對值,并在指針上添加負號
- dat = -dat;
- *str++ = '-';
- len++;
- do { //先轉(zhuǎn)換為低位在前的十進制數(shù)組
- buf[i++] = dat % 10;
- dat /= 10;
- } while (dat > 0);
- len += i; //i 最后的值就是有效字符的個數(shù)
- while (i-- > 0) //將數(shù)組值轉(zhuǎn)換為 ASCII 碼反向拷貝到接收指針上
- *str++ = buf[i] + '0';
- *str = '\0'; //添加字符串結(jié)束符
- return len; //返回字符串長度
- /* 配置并啟動 T0, ms-T0 定時時間 */
- unsigned long tmp; //臨時變量
- tmp = 11059200 / 12; //定時器計數(shù)頻率
- tmp = (tmp * ms) / 1000; //計算所需的計數(shù)值
- tmp = 65536 - tmp; //計算定時器重載值
- tmp = tmp + 12; //補償中斷響應(yīng)延時造成的誤差
- T0RH = (unsigned char)(tmp>>8); //定時器重載值拆分為高低字節(jié)
- T0RL = (unsigned char)tmp;
- TMOD &= 0xF0; //清零 T0 的控制位
- TMOD |= 0x01; //配置 T0 為模式 1
- TH0 = T0RH; //加載 T0 重載值
- TL0 = T0RL;
- ET0 = 1; //使能 T0 中斷
- TR0 = 1; //啟動 T0
- /* T0 中斷服務(wù)函數(shù),完成 1 秒定時 */
- void InterruptTimer0() interrupt 1
- static unsigned char tmr1s = 0;
- TH0 = T0RH; //重新加載重載值
- TL0 = T0RL;
- tmr1s++;
- if (tmr1s >= 100) //定時 1s
- tmr1s = 0;
- flag1s = 1;
- /* 讀取 EEPROM 中的一個字節(jié), addr-字節(jié)地址 */
- unsigned char dat;
- I2CStart();
- I2CWrite(0x50<<1); //尋址器件,后續(xù)為寫操作
- I2CWrite(addr); //寫入存儲地址
- I2CStart(); //發(fā)送重復(fù)啟動信號
- I2CWrite((0x50<<1)|0x01); //尋址器件,后續(xù)為讀操作
- dat = I2CReadNAK(); //讀取一個字節(jié)數(shù)據(jù)
- I2CStop();
- return dat;
- /* 向 EEPROM 中寫入一個字節(jié), addr-字節(jié)地址 */
- I2CStart();
- I2CWrite(dat); //寫入一個字節(jié)數(shù)據(jù)
- I2CStop();
- /* 串口配置函數(shù), baud-通信波特率 */
- SCON = 0x50; //配置串口為模式 1
- TMOD &= 0x0F; //清零 T1 的控制位
- TMOD |= 0x20; //配置 T1 為模式 2
- TH1 = 256 - (11059200/12/32)/baud; //計算 T1 重載值
- TL1 = TH1; //初值等于重載值
- ET1 = 0; //禁止 T1 中斷
- ES = 1; //使能串口中斷
- TR1 = 1; //啟動 T1
- /* UART 中斷服務(wù)函數(shù) */
- void InterruptUART() interrupt 4
- if (RI) //接收到字節(jié)
藍牙溫控.rar
(68.71 KB, 下載次數(shù): 30)
2019-2-28 11:32 上傳
下載積分: 黑幣 -5
