查看: 2582|回復: 4
求助APP線程連接問題(TCP)—安卓軟件
ID:245521 發表于 2019-2-24 20:53 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
我自己做了一個手機APP,主要是連接一個物聯網模塊【esp8266】,但是app一直顯示通訊失敗,所以把代碼貼出來希望大家幫幫小白,可能是線程某個地方的問題。
package com.example.afan.one;
import android.support.v7.app.AppCompatActivity;
import android.os.Bundle;
import android.view.View;
import android.widget.Button;
import android.widget.EditText;
import android.widget.Toast;
import java.io.BufferedReader;
import java.io.IOException;
import java.io.InputStreamReader;
import java.io.PrintStream;
import java.net.Socket;
public class MainActivity extends AppCompatActivity implements View.OnClickListener {
    private EditText mIp;   //  IP
    private EditText mPort;     //  端口號
    private String mStrIp;      //  字符串類型ip
    private int miPort;    //  字符類型端口
    private Button mBtnConnect; //  連接
    private Button mLedON;      //  按鈕LED燈開
    private Button mLedOFF;     //  按鈕LED燈關
    private Socket mSocket;     //  套接字
    private PrintStream out;    //  打印輸出流
    private ConnectThread mConnectThread;   //  TCP連接線
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        mBtnConnect = (Button) findViewById(R.id.bt1);
        mLedON = (Button) findViewById(R.id.bt2);
        mLedOFF = (Button) findViewById(R.id.bt3);
        mIp = (EditText) findViewById(R.id.edit_IP);
        mPort = (EditText) findViewById(R.id.edit_PORT);
        mBtnConnect.setOnClickListener(this);
        mLedON.setOnClickListener(this);
        mLedOFF.setOnClickListener(this);
    @Override
    public void onClick(View view) {
        switch (view.getId()) {
            case R.id.bt1:
                if (mSocket == null || !mSocket.isConnected()) {
                    mStrIp = mIp.getText().toString();
                    miPort = Integer.valueOf(mPort.getText().toString());
                    mConnectThread = new ConnectThread(mStrIp, miPort);
                    mConnectThread.start();
                if (mSocket != null && mSocket.isConnected()) {
                    try {
                        mSocket.close();
                        mSocket = null;   //  清空mSocket
                        mBtnConnect.setText("連接");
                        Toast.makeText(MainActivity.this, "連接已關閉", Toast.LENGTH_LONG).show();
                    } catch (IOException e) {
                        e.printStackTrace();
                break;
            case R.id.bt2:
                if (out != null) {
                    out.print("0");
                    out.flush();
                break;
            case R.id.bt3:
                if (out != null) {
                    out.print("1");
                    out.flush();
                break;
    private class ConnectThread extends Thread {
        private String ip;
        private int port;
        public ConnectThread(String ip, int port) {
            this.ip = ip;
            this.port = port;
        public void run() {
            try {
                mSocket = new Socket(ip, port);
                out = new PrintStream(mSocket.getOutputStream());
                runOnUiThread(new Runnable() {
                    @Override
                    public void run() {
                        mBtnConnect.setText("斷開");
                        Toast.makeText(MainActivity.this, "連接成功", Toast.LENGTH_LONG).show();
                new HeartBeatThread().start();
                    @Override
                    public void run() {
                        Toast.makeText(MainActivity.this, "連接失敗", Toast.LENGTH_LONG).show();
    private class HeartBeatThread extends Thread {
        @Override
        public void run() {
            while (true) {
                try {
                    Thread.sleep(3000);
                    if (!mSocket.isConnected()) {
                            @Override
                            public void run() {
                                Toast.makeText(MainActivity.this, "連接已關閉", Toast.LENGTH_SHORT).show();
                } catch (InterruptedException e) {
ID:123289 發表于 2019-2-25 07:55 | 只看該作者
我想用單片機及其它電子部分知識換你的手機APP知識。加我QQ,下方有。加時注明手機APP。
ID:245521 發表于 2019-2-25 11:03 | 只看該作者
yzwzfyz 發表于 2019-2-25 07:55
什么意思?給你app嗎還是
ID:123289 發表于 2019-2-25 11:57 | 只看該作者
互相學習而矣
ID:245521 發表于 2019-2-25 19:35 | 只看該作者
有玩安卓的大佬嗎
