查看: 2430|回復: 1
stm32 ds18b20數字溫度傳感器代碼
ID:477769 發表于 2019-2-18 16:10 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
基于stm32mini開發板  12864教學工程 親測有效
圖形液晶顯示
HJ12864M-1
基于st7290
顯示一個中文菜單,通過菜單控制D2,D4,D8的顯示
  1. /*************************************************
  2. 函數名:main.c
  3. 功 能 :12864液晶模塊演示范例——基于查詢忙狀態實現
  4. 時 間 :2016/03/08
  5. 作 者 :沈紅衛,紹興文理學院 機械與電氣工程學院
  6. *************************************************/
  7. #include <stm32f10x.h>
  8. #include "delay.h"                //延時函數的頭文件
  9. #include "st12864.h"        //液晶模塊接口函數的頭文件
  10. /*-----------------待顯示的字符串------------------------*/
  11. //由于KEIL對中文支持的BUG,導致擴展ASCII碼不能正確被識別,所以直接使用內碼
  12. //使用內碼查詢軟件可以查詢每個漢字的內碼
  13. //例如:你好的內碼為0xC4,0xE3,0xBA,0xC3
  14. //以下為“你好串口實”的內碼
  15. u8  Table0[]={0xC4,0xE3,0xBA,0xC3,0xB4,0xAE,0xBF,0xDA,0xCA,0xB5,0x20,0x20,0x20,0x20,0x20,0x20};
  16. //u8  Table0[]={0xC4,0xE3,0xBA,0xC3,0xB4,0xAE,0xBF,0xDA,0xCA,0xB5};
  17. u8  Table1[]={0xC4,0xE3,0xBA,0xC3,0xB4,0xAE,0xBF,0xDA,0xCA,0xB5,0x11,0x20,0x20,0x20,0x20,0x20};
  18. u8  Table2[]={0xC4,0xE3,0xBA,0xC3,0xB4,0xAE,0xBF,0xDA,0xCA,0xB5,0x20,0x20,0x20,0x20,0x20,0x20};
  19. u8  Table3[]={0xC4,0xE3,0xBA,0xC3,0xB4,0xAE,0xBF,0xDA,0xCA,0xB5,0x20,0x20,0x20,0x20,0x20,0x20};
  20. u8  Table4[]={0xC4,0xE3,0xBA,0xC3,0xB4,0xAE,0xBF,0xDA,0xCA,0xB5,0x20,0x20,0x20,0x20,0x20,0x20};
  21. u8  Table5[]={0xC4,0xE3,0xBA,0xC3,0xB4,0xAE,0xBF,0xDA,0xCA,0xB5,0x20,0x20,0x20,0x20,0x20,0x20};
  22. u8  Table6[]={0xC4,0xE3,0xBA,0xC3,0xB4,0xAE,0xBF,0xDA,0xCA,0xB5,0x20,0x20,0x20,0x20,0x20,0x20};
  23. u8  Table7[]={0xC4,0xE3,0xBA,0xC3,0xB4,0xAE,0xBF,0xDA,0xCA,0xB5,0x20,0x20,0x20,0x20,0x20,0x20};
  24. u8  value []={0,1,2,3,4,5,6,8,9};
  25. //范例演示用BMP圖片數據
  26. u8 BMP1[]={
  27. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  28. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  29. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  30. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x18,
  31. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x78,
  32. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF3,0xF8,
  33. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xC0,
  34. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x00,
  35. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xF8,
  36. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xF8,
  37. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x18,
  38. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,
  39. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0x78,
  40. 0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x18,
  41. 0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,0x00,0x00,0xCF,0x98,
  42. 0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0xC6,0x18,
  43. 0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0x01,0xFF,0xF0,0x00,0x00,0x00,0x00,0xFF,0xF8,
  44. 0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFE,0x00,0x1F,0xFE,0x00,0x00,0x00,0x00,0xFF,0xF8,
  45. 0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFE,0x00,0x03,0xFF,0xC0,0x00,0x00,0x00,0x80,0x08,
  46. 0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0xFF,0xF8,0x00,0x00,0x00,0x78,0x00,
  47. 0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0x80,0x00,0x3F,0xFF,0x00,0x00,0x00,0xE0,0x00,
  48. 0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x00,0x0F,0xFF,0xC0,0x00,0x00,0xC0,0x18,
  49. 0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x00,0x07,0xFF,0xF8,0x00,0x00,0xFF,0xF8,
  50. 0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x01,0xFF,0xFE,0x00,0x00,0xFF,0xF8,
  51. 0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x00,0x00,0xFF,0xFF,0x80,0x00,0xC0,0x18,
  52. 0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x00,0x7F,0xFF,0xE0,0x00,0xF8,0x00,
  53. 0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x00,0x3F,0xFF,0xF8,0x00,0x00,0x00,
  54. 0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x1F,0xFF,0xFC,0x00,0xFF,0xF8,
  55. 0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x1F,0xFF,0xFF,0x00,0xFF,0xF8,
  56. 0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x80,0x87,0xE0,
  57. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x7E,0x00,
  58. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0xF8,0x18,
  59. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0xFF,0xF8,
  60. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x80,0x08,
  61. 0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x80,0x10,0xE0,
  62. 0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x1F,0xFF,0xFF,0x00,0xF0,0x38,
  63. 0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x1F,0xFF,0xFE,0x00,0xCF,0x98,
  64. 0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x00,0x3F,0xFF,0xF8,0x00,0xC6,0x18,
  65. 0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x00,0x7F,0xFF,0xE0,0x00,0xC6,0x18,
  66. 0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x00,0x00,0x7F,0xFF,0x80,0x00,0xFF,0xF8,
  67. 0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x01,0xFF,0xFE,0x00,0x00,0xC0,0x18,
  68. 0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x00,0x03,0xFF,0xF0,0x00,0x00,0x00,0x00,
  69. 0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x00,0x0F,0xFF,0xC0,0x00,0x00,0xC0,0x18,
  70. 0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0x80,0x00,0x3F,0xFE,0x00,0x00,0x00,0xFF,0xF8,
  71. 0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0xFF,0xF0,0x00,0x00,0x00,0xFF,0xF8,
  72. 0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFE,0x00,0x03,0xFF,0xC0,0x00,0x00,0x00,0xC0,0x18,
  73. 0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFE,0x00,0x3F,0xFC,0x00,0x00,0x00,0x00,0x00,0xF0,
  74. 0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0x03,0xFF,0xF0,0x00,0x00,0x00,0x00,0x00,0x38,
  75. 0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x18,
  76. 0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x00,0x00,0x00,0x00,0x00,0xC0,0x18,
  77. 0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xF8,
  78. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x18,
  79. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,
  80. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x38,
  81. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xF8,
  82. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xD8,
  83. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF1,0x80,
  84. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0x88,
  85. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xF8,
  86. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,
  87. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  88. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  89. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  90. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
  91. };
  92. //系統時鐘初始化函數
  93. //采用固件庫函數方式編程
  94. //pll:選擇的倍頻數,從2開始,最大值為16(這里最大為9)
  95. /*******************************************************************************
  96. * Function Name  : Rcc_Init
  97. * Description    : RCC配置(使用外部8MHz晶振)
  98. * Input          : uint32_t,PLL的倍頻系數,例如9就是9*8=72M
  99. * Output         : 無
  100. * Return         : 無
  101. *******************************************************************************/
  102. void Stm32_Clock_Init(u8 pll)
  103. {
  104.     ErrorStatus HSEStartUpStatus;
  105.     /*將外設RCC寄存器重設為缺省值*/
  106.     RCC_DeInit();
  107.     /*設置外部高速晶振(HSE)*/
  108.     RCC_HSEConfig(RCC_HSE_ON);   //RCC_HSE_ON——HSE晶振打開(ON)
  109.     /*等待HSE起振*/
  110.     HSEStartUpStatus = RCC_WaitForHSEStartUp();
  111.     if(HSEStartUpStatus == SUCCESS)        //SUCCESS:HSE晶振穩定且就緒
  112.     {
  113.         /*設置AHB時鐘(HCLK)*/
  114.         RCC_HCLKConfig(RCC_SYSCLK_Div1);  //RCC_SYSCLK_Div1——AHB時鐘= 系統時鐘
  115.         /* 設置高速AHB時鐘(PCLK2)*/
  116.         RCC_PCLK2Config(RCC_HCLK_Div1);   //RCC_HCLK_Div1——APB2時鐘= HCLK
  117.         /*設置低速AHB時鐘(PCLK1)*/
  118.         RCC_PCLK1Config(RCC_HCLK_Div2);   //RCC_HCLK_Div2——APB1時鐘= HCLK / 2
  119.         /*設置FLASH存儲器延時時鐘周期數*/
  120.         FLASH_SetLatency(FLASH_ACR_LATENCY_2);//FLASH_Latency_2  2延時周期
  121.         /*選擇FLASH預取指緩存的模式*/
  122.         FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);// 預取指緩存使能
  123.         /*設置PLL時鐘源及倍頻系數*/
  124.         //RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
  125.         // PLL的輸入時鐘= HSE時鐘頻率;RCC_PLLMul_9——PLL輸入時鐘x 9
  126.         switch(pll)
  127.         {
  128.             case 2: RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_2);
  129.                     break;
  130.             case 3: RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_3);
  131.                     break;
  132.             case 4: RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_4);
  133.                     break;
  134.             case 5: RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_5);
  135.                     break;
  136.             case 6: RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_6);
  137.                     break;
  138.             case 7: RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_7);
  139.                     break;
  140.             case 8: RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_8);
  141.                     break;
  142.             case 9: RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
  143.                     break;
  144.             default:
  145.                     RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_2);
  146.                     break;
  147.
  148.         }
  149.         /*使能PLL */
  150.         RCC_PLLCmd(ENABLE);
  151.         /*檢查指定的RCC標志位(PLL準備好標志)設置與否*/
  152.         while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
  153.         {
  154.         }
  155.         /*設置系統時鐘(SYSCLK)*/
  156.         RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  157.         //RCC_SYSCLKSource_PLLCLK——選擇PLL作為系統時鐘
  158.         /* PLL返回用作系統時鐘的時鐘源*/
  159.         while(RCC_GetSYSCLKSource() != 0x08)        //0x08:PLL作為系統時鐘
  160.         {
  161.         }
  162.      }
  163.     /*使能或者失能APB2外設時鐘*/
  164.     /*
  165.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
  166.     RCC_APB2Periph_GPIOC , ENABLE);
  167.     */
  168.     //RCC_APB2Periph_GPIOA    GPIOA時鐘
  169.     //RCC_APB2Periph_GPIOB    GPIOB時鐘
  170.     //RCC_APB2Periph_GPIOC    GPIOC時鐘
  171.     //RCC_APB2Periph_GPIOD    GPIOD時鐘
  172. }
  173. u8 MenuItem_0[]={" Select:        "};
  174. u8 MenuItem_1[]={"  light led1    "};
  175. u8 MenuItem_2[]={"  light led2    "};
  176. u8 MenuItem_3[]={"  light two led "};
  177. void DisplayMenu(u8 cur)
  178. {
  179.         Display_LCD_String(0,MenuItem_0,1);
  180.         switch(cur)
  181.         {
  182.                 case 1:
  183.                                         MenuItem_1[1]=26;                //字符->的ASCII碼
  184.                                         MenuItem_2[1]=0x20;                //空格
  185.                                         MenuItem_3[1]=0x20;
  186.                                         Display_LCD_String(1,MenuItem_1,1);
  187.                                         Display_LCD_String(2,MenuItem_2,1);
  188.                                         Display_LCD_String(3,MenuItem_3,1);
  189.                                         break;
  190.                 case 2:
  191.                                         MenuItem_1[1]=0x20;                //字符->的ASCII碼
  192.                                         MenuItem_2[1]=26;                //空格
  193.                                         MenuItem_3[1]=0x20;
  194.                                         Display_LCD_String(1,MenuItem_1,1);
  195.                                         Display_LCD_String(2,MenuItem_2,1);
  196.                                         Display_LCD_String(3,MenuItem_3,1);
  197.                                         break;
  198.                 case 3:
  199.                                         MenuItem_1[1]=0x20;                //字符->的ASCII碼
  200.                                         MenuItem_2[1]=0x20;                //空格
  201.                                         MenuItem_3[1]=26;
  202.                                         Display_LCD_String(1,MenuItem_1,1);
  203.                                         Display_LCD_String(2,MenuItem_2,1);
  204.                                         Display_LCD_String(3,MenuItem_3,1);
  205.                                         break;
  206.         }
  207.
  208.
  209. }
  210. int main(void)
  211. {
  212.         u8 time=50;
  213.
  214.         Stm32_Clock_Init(9); //系統時鐘設置
  215.
  216.         delay_init(72);             //延時初始化
  217. //        uart_init(72,9600);  //串口初始化
  218.
  219.     delay_ms(1000);
  220.         LCD12864_Init();         //12864初始化
  221. /*---------------------顯示字符串-------------------*/
  222. //        Display_LCD_String(0 , Table0,time);
  223.         Disp_HZ(0,Table0,5);  //指定個數漢字顯示
  224.         delay_ms(100);
  225. //        Display_LCD_String(1 , Table1,time);
  226.         Disp_HZ(1,Table1,5);
  227.         delay_ms(100);
  228. //        Display_LCD_String(2 , Table2,time);
  229.         Disp_HZ(2,Table2,5);
  230.         delay_ms(100);
  231.         Display_LCD_String(3 , Table3,time);        //8個漢字或16字節字符顯示
  232.         delay_ms(1500);
  233.         Write_LCD_Command(0x01);        //清屏
  234.         LCD_Clear_TXT();
  235.            delay_ms(50);
  236. /*
  237.         PutBMP(BMP1);                        //外星人
  238.         delay_ms(1500);
  239.         LCD_Clear_BMP();                //清除圖片
  240.         PutBMP(BMP1);                        //NBA標志
  241.         delay_ms(1500);
  242.         LCD_Clear_BMP();           //清除圖片
  243.         PutBMP(BMP1);                        //暴漫男主
  244.         delay_ms(1500);
  245.         LCD_Clear_BMP();           //清除圖片
  246.
  247.         Write_LCD_Command(0x30);        //必須再次打開基本指令,因為繪圖開了擴充指令
  248.         Display_LCD_String(1 , Table4,time);
  249.         delay_ms(100);
  250.         Display_LCD_String(2 , Table5,time);
  251.         delay_ms(100);
  252.         Display_LCD_String(3, Table6,time);
  253.         delay_ms(100);
  254. //---------------------顯示自定義字符------------------
  255.            Write_LCD_Command(0x34);         //要用到畫圖功能,必須打開擴充指令
  256.         Write_LCD_Command(0x36);
  257.     Draw_Char4x5Line(30,5,value,10)        ;  //顯示自定義字符0~9
  258.         Draw_Update();                                           //更新顯示
  259.         Write_LCD_Command(0x30);                 //再次打開基本指令,后面用到
  260.
  261.         delay_ms(1500);
  262.     LCD_Clear_TXT();
  263.         delay_ms(50);
  264.     Display_LCD_String(3, Table7,time);
  265. //    LCD_Clear_BMP();
  266.     Draw_Clear();
  267. */
  268.     DisplayMenu(1);
  269.     delay_ms(2000);
  270.     DisplayMenu(2);
  271.
  272.            while(1);
  273. }
12864顯示工程.7z (207.99 KB, 下載次數: 9)
ID:1 發表于 2019-2-19 03:48 | 只看該作者
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
