原本是要上傳整個工程 的,但是壓縮后比較大,現(xiàn)在只能貼出來主程序部分。
void Init_UART1(void)
UART1_DeInit();
UART1_Init((u32)9600, UART1_WORDLENGTH_8D, UART1_STOPBITS_1, UART1_PARITY_NO, UART1_SYNCMODE_CLOCK_DISABLE, UART1_MODE_TX_ENABLE);
// UART1_Cmd(ENABLE);
void Send(uint8_t dat)
while(( UART1_GetFlagStatus(UART1_FLAG_TXE)==RESET));
UART1_SendData8(dat);
void Init_ADC(void)
//GPIO_Init(GPIOD, GPIO_PIN_2, GPIO_MODE_IN_FL_NO_IT);
ADC1_DeInit();
ADC1_Init(ADC1_CONVERSIONMODE_SINGLE, ADC1_CHANNEL_3, ADC1_PRESSEL_FCPU_D2, ADC1_EXTTRIG_TIM, DISABLE, ADC1_ALIGN_RIGHT, ADC1_SCHMITTTRIG_CHANNEL3, ENABLE);
ADC1_Cmd(ENABLE);
void UART1_sendhex(unsigned char dat)
Send('0');
Send('x');
Send(HexTable[dat>>4]);
Send(HexTable[dat&0x0f]);
Send(' ');
void UART1_sendstr(unsigned char *dat)
while(*dat!='\0')
Send(*dat);
dat++;
//delay2us();
void main(void)
FlagStatus flag_status;
u16 u16_adc1_value;
Init_UART1();
Init_ADC();
/* Infinite loop */
while (1)
//Send(0xf0);
ADC1_StartConversion();
flag_status = ADC1_GetFlagStatus(ADC1_FLAG_EOC);
// while(flag_status == RESET); // SET or RESET
u16_adc1_value = ADC1_GetConversionValue();
UART1_sendhex((u16_adc1_value>>8));
UART1_sendhex((u16_adc1_value&0xff));
UART1_sendstr("\r\n");
#ifdef USE_FULL_ASSERT
void assert_failed(u8* file, u32 line)
/* Infinite loop */
while (1)
#endif
自已動手調(diào)試一下。
