查看: 3200|回復: 3
基于STC12C5A60S2的帶有掉電記憶功能的音樂盒
ID:475984 發表于 2019-2-12 18:11 | 顯示全部樓層 |閱讀模式
晶振值33.1776MHz
功能簡介:K16控制暫停與繼續
          K4 上一曲
     K12下一曲
    數碼管顯示當前歌曲序號
具有lcd1602顯示功能
應用EEPROM具有掉電記憶
默認演奏上次斷電所演奏的歌曲
主函數
  1. #include <stc12c5a60s2.h>
  2. #define Xtal 33177600  //賦晶振值
  3. #define All 4          //歌曲總數
  4. sbit BUZZ = P1^3;  //蜂鳴器控制引腳
  5. sbit KEY = P2^4;   //按鍵定義
  6. sbit KEY4 = P2^7;
  7. sbit KEY12 = P2^5;
  8. /*sbit ADDR0 = P2^0; //數碼管顯示控制
  9. sbit ADDR1 = P2^1;
  10. sbit ADDR2 = P2^2;
  11. sbit ENLED = P1^1; //總線收發器*/
  12. bit KeySta = 1;  //當前按鍵狀態
  13. bit KeySta4 = 1;
  14. bit KeySta12 = 1;
  15. bit backup = 1;  //默認彈起時時一
  16. bit backup4 = 1;
  17. bit backup12 = 1;
  18. bit cntkey = 0;  //判斷暫停還是播放
  19. bit breakflage = 0;//用按鍵改變歌曲標志
  20. unsigned char keybuf = 0xFF;
  21. unsigned char keybuf4 = 0xFF;
  22. unsigned char keybuf12 = 0xFF;
  23. unsigned char Num; //第幾首歌
  24. unsigned char sizeofNote;//節拍的多少
  25. void E2WriteByte(unsigned char addr, unsigned char dat);
  26. unsigned char E2ReadByte(unsigned char addr);
  27. void Delay_ms(unsigned int ms);//延時函數
  28. extern void I2CStart();
  29. extern void I2CStop();
  30. extern unsigned char I2CReadNAK();
  31. extern bit I2CWrite(unsigned char dat);
  32. extern void LcdWriteCmd(unsigned char cmd);
  33. extern void LcdWaitReady();
  34. extern void InitLcd1602();
  35. extern void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
  36. void lcd1602updata();
  37. void PlayControl(unsigned char Num);//歌曲選擇函數
  38. void Play();//演奏函數
  39. //unsigned char code LedChar[] = {0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E};//數碼管顯示字符轉換表
  40. unsigned int code NoteFrequ[] = {  //中音1-7低音1-7和高音1-7對應頻率列表
  41.     523,  587,  659,  698,  784,  880,  988,  //中音1-7
  42.     1047, 1175, 1319, 1397, 1568, 1760, 1976,  //高音1-7
  43.           262, 294, 330, 349, 392, 440, 494,300//低音1-7  最后一個純屬湊數
  44. };
  45. unsigned int code NoteReload[] = { //中音1-7和高音1-7對應的定時器重載值
  46.     65536 - (Xtal/12) / (523*2),  //中音1
  47.     65536 - (Xtal/12) / (587*2),  //2
  48.     65536 - (Xtal/12) / (659*2),  //3
  49.     65536 - (Xtal/12) / (698*2),  //4
  50.     65536 - (Xtal/12) / (784*2),  //5
  51.     65536 - (Xtal/12) / (880*2),  //6
  52.     65536 - (Xtal/12) / (988*2),  //7
  53.     65536 - (Xtal/12) / (1047*2), //高音1
  54.     65536 - (Xtal/12) / (1175*2), //2
  55.     65536 - (Xtal/12) / (1319*2), //3
  56.     65536 - (Xtal/12) / (1397*2), //4
  57.     65536 - (Xtal/12) / (1568*2), //5
  58.     65536 - (Xtal/12) / (1760*2), //6
  59.     65536 - (Xtal/12) / (1976*2), //7
  60.           65536 - (Xtal/12) / (262*2), //低音1
  61.     65536 - (Xtal/12) / (294*2), //2
  62.     65536 - (Xtal/12) / (330*2), //3
  63.     65536 - (Xtal/12) / (349*2), //4
  64.     65536 - (Xtal/12) / (392*2), //5
  65.     65536 - (Xtal/12) / (440*2), //6
  66.     65536 - (Xtal/12) / (494*2), //7
  67.                 65536 - (Xtal/12) / (300*2), //純屬湊數
  68. };
  69. unsigned char *SongNote, *SongBeat;//指針
  70. unsigned char code XiaoXingXingNote[] = {   //小星星
  71.         1, 1, 5, 5,    6, 6, 5,    4, 4, 3, 3,    2, 2, 1,
  72.         5, 5, 4, 4,    3, 3, 2,    5, 5, 4, 4,    3, 3, 2 ,
  73.         1, 1, 5, 5,    6, 6, 5,    4, 4, 3, 3,    2, 2, 1, 0xff    };
  74. unsigned char code XiaoXingXingBeat[] = {
  75.         4, 4, 4, 4,    4, 4, 8,    4, 4, 4, 4,    4, 4, 8,
  76.         4, 4, 4, 4,    4, 4, 8,    4, 4, 4, 4,    4, 4, 8,
  77.         4, 4, 4, 4,    4, 4, 8,    4, 4, 4, 4,    4, 4, 8,};
  78. unsigned char code TwoTigerNote[] = {    //兩只老虎音符表
  79.         1,   2,   3, 1,    1,   2,   3, 1,   3, 4, 5,   3, 4, 5,
  80.         5,6, 5,4, 3, 1,    5,6, 5,4, 3, 1,   1, 5, 1,   1, 5, 1,0xff};
  81. unsigned char code TwoTigerBeat[] = {    //兩只老虎節拍表,4表示一拍,1就是1/4拍,8就是2拍
  82.         4,   4,   4, 4,    4,   4,   4, 4,   4, 4, 8,   4, 4, 8,
  83.         3,1, 3,1, 4, 4,    3,1, 3,1, 4, 4,   4, 4, 8,   4, 4, 8,
  84.     };
  85. unsigned char code HappybirthdayNote[] = {  //生日快樂歌
  86.         5, 5, 6, 5, 8, 7, 22, 5, 5, 6, 5, 9, 8, 5, 5, 12, 10, 8, 7, 6, 11, 11,  10, 8, 9, 8,0xff };
  87. unsigned char code HappybirthdayBeat[] = {
  88.         2, 2, 4, 4, 4, 4, 4, 2, 2,  4, 4, 4, 8, 2, 2, 4, 4, 4, 4, 8, 2, 2, 4, 4, 4, 8};
  89. unsigned char code         ZhiduanqingchangNote[] = { //紙短情長
  90.               //8, 9, 10, 9, 8, 6, 22, 11, 10, 9, 22, 7, 8, 9, 7, 7, 5, 22, 7, 9, 8, 8, 3, 4, 2, 3, 1, 1, 5, 2,  //前奏
  91.         19, 3, 3, 3, 2, 3, 1, 2, 2, 2, 1, 2, 5, 1, 1, 1, 20, 1, 20, 19,     2, 2, 2, 3, 20, 19, 4, 4, 4, 3, 4, 1, 2, 2, 2, 1, 2, 5,
  92.                1, 1, 1, 20, 1, 20, 3, 2, 2, 1, 1, 22, 22, 22, 1, 1, 2,             3, 3, 3, 22, 3, 2, 1, 21, 6, 5, 22, 5, 6, 7, 8, 3, 3, 22, 8, 7, 8,
  93.               7, 3, 5, 5, 6, 8, 5, 6, 22, 6, 5, 4,5, 3, 2, 1, 20, 1,               3, 2, 2, 1, 2, 5, 1, 2, 5, 22, 22, 22, 1, 1, 2,
  94.         3, 3, 2, 3, 22, 3, 2, 1, 5, 5, 3, 5, 22, 5, 6, 7,                   8, 8, 8, 8, 8, 7, 6, 7, 6, 3, 5, 5, 5, 6, 8, 5, 6, 22, 6, 5, 4,
  95.         5, 3, 2, 1, 6, 1, 3, 2, 2, 1, 2, 1, 20, 1, 22,                      22, 20, 1, 3, 2, 2, 22, 2, 1, 2, 1, 1, 22, 20, 1, 1, 0xff};
  96. unsigned char code ZhiduanqingchangBeat[] = {
  97.               //2, 2, 2, 2, 2, 2, 2, 2, 2, 1, 8, 4, 2, 2, 2, 2, 2, 2, 2, 2, 2, 1, 8, 8, 12, 4, 5, 4, 8, 8, 4,   //前奏
  98.         8, 2, 2, 2, 2, 2, 5, 2, 2, 2, 2, 2, 5, 2, 2, 2, 2, 2, 4, 2,       2, 2, 2, 2, 2, 4, 2, 2, 2, 2, 4, 5, 2, 2, 2, 2, 2, 5,
  99.         2, 2, 2, 2, 2, 5, 2, 2, 2, 2, 8, 4, 4, 2, 2, 2, 2,                4, 2, 2, 2, 2, 2, 2, 4, 2, 2, 2, 2, 2, 2, 4, 2, 2, 2, 2, 2, 2,
  100.         4, 2, 5, 2, 2, 2, 4, 2, 2, 2, 2, 2, 2, 4, 2, 5, 1, 1,             2, 2, 2, 2, 2, 4, 2, 16, 16,4, 4, 2, 2, 2, 2,
  101.         2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2,                   2, 2, 2, 2, 2, 2, 2, 2, 2, 4, 2, 4, 2, 2, 2, 4, 2, 2, 2, 2, 2,
  102.         2, 4, 2, 5, 1, 1, 2, 2, 2, 2, 2, 4, 1, 12, 4,                     2, 1, 1, 2, 2, 8, 2, 1, 1, 2, 2, 8, 2, 2, 12, 16};
  103. bit enable = 1;   //蜂鳴器發聲使能標志
  104. bit tmrflag = 0;  //定時器中斷完成標志
  105. unsigned char T0RH = 0xFF;  //T0重載值的高字節
  106. unsigned char T0RL = 0x00;  //T0重載值的低字節
  107. void main()
  108. {
  109.     unsigned char dat;
  110.     EA = 1;       //使能全局中斷
  111.     TMOD = 0x11;  //配置T0,T1工作在模式1
  112.     TH0 = T0RH;
  113.     TL0 = T0RL;
  114.     ET0 = 1;      //使能T0中斷
  115.           ET1 = 1;      //使能T1中斷
  116.           TR1 = 1;      //啟動T1
  117.          // ENLED = 0x00; //使能總線收發器
  118.          // ADDR2=1; ADDR1=0; ADDR0=1;//選擇最右邊的數碼管
  119.           P23 = 0;      //啟用KEY
  120.           InitLcd1602();
  121.           dat = E2ReadByte(0x01);    //讀取指定地址上的一個字節
  122.           if(dat>All||dat<=0)
  123.                         Num = 1;
  124.                 else
  125.     Num = dat;
  126.     while (1)
  127.     {
  128.                         //P0 = LedChar[Num]; //數碼管顯示當前歌曲序號
  129.                         LcdWriteCmd(0x01);  //清屏
  130.                         lcd1602updata();
  131.       PlayControl(Num);
  132.                         if(breakflage == 1)
  133.                                 breakflage = 0;
  134.                         else
  135.                                 Delay_ms(500);
  136.     }
  137. }
  138. void PlayControl(unsigned char Num)
  139. {
  140.         E2WriteByte(0x01, Num);    //再寫回到對應的地址上
  141.         switch(Num)
  142.         {
  143.                 case 4:SongNote = XiaoXingXingNote;    SongBeat =  XiaoXingXingBeat;  sizeofNote = sizeof(XiaoXingXingNote);    Play();break;
  144.     case 2:SongNote = TwoTigerNote;        SongBeat =TwoTigerBeat;        sizeofNote = sizeof(TwoTigerNote);        Play();break;
  145.                 case 3:SongNote = HappybirthdayNote;   SongBeat =HappybirthdayBeat;   sizeofNote = sizeof(HappybirthdayNote);   Play();break;
  146.                 case 1:SongNote = ZhiduanqingchangNote;SongBeat =ZhiduanqingchangBeat;sizeofNote = sizeof(ZhiduanqingchangNote);Play();break;
  147.                 default:break;
  148.         }
  149. }
  150. void lcd1602updata()
  151. {
  152.         switch(Num)
  153.         {
  154.                 case 1:LcdShowStr(4,0,"1.zhiduanqingchang");break;
  155.           case 2:LcdShowStr(4,0,"2.liangzhilaohu");break;
  156.           case 3:LcdShowStr(4,0,"3.zhunishengrikuaile");break;
  157.           case 4:LcdShowStr(4,0,"4.xiaoxingxing");break;
  158.                 default:break;
  159.         }
  160. }
  161. /* 演奏函數 */
  162. void Play()//演奏函數
  163. {
  164.     unsigned char beat;   //當前節拍索引
  165.     unsigned char note;   //當前節拍對應的音符
  166.     unsigned int time = 0;      //當前節拍計時
  167.     unsigned int beatTime = 0;  //當前節拍總時間
  168.     unsigned int soundTime = 0; //當前節拍需發聲時間
  169.     for (beat=0; beat<sizeofNote; )  //用節拍索引作為循環變量
  170.     {
  171.                                 if(breakflage == 1)
  172.                                         break;
  173.         while (!tmrflag);  //每次定時器中斷完成后,檢測并處理節拍
  174.         tmrflag = 0;
  175.         if (time == 0)  //當前節拍播完則啟動一個新節拍
  176.         {
  177.                                         if(breakflage == 1)
  178.                                                 break;
  179.             note = SongNote[beat] - 1;
  180.                                           if(note == 0xfe)
  181.                                                 {
  182.                                                         if(Num == All)
  183.        Num = 1;
  184.                                                         else
  185.                                                         Num++;
  186.                                                         break;
  187.                                                 }
  188.             T0RH = NoteReload[note] >> 8;
  189.             T0RL = NoteReload[note];
  190.             beatTime = (SongBeat[beat] * NoteFrequ[note]) >> 2;//計算節拍總時間,右移2位相當于除4,移位代替除法可以加快執行速度
  191.             soundTime = beatTime - (beatTime >> 2);//計算發聲時間,
  192.             enable = 1;  //指示蜂鳴器開始發聲
  193.                                                 if (note == 21)//簡譜的0 等待
  194.                                                         enable =0;
  195.             time++;
  196.         }
  197.         else  //當前節拍未播完則處理當前節拍
  198.         {
  199.             if (time >= beatTime)  //當前持續時間到達節拍總時間時歸零,
  200.             {                      //并遞增節拍索引,以準備啟動新節拍
  201.                 time = 0;
  202.                 beat++;
  203.             }
  204.             else  //當前持續時間未達到總時間時,
  205.             {
  206.                 time++;   //累加時間計數
  207.                 if (time == soundTime)  //到達發聲時間后,指示關閉蜂鳴器,
  208.                 {                       //插入0.25*總時間的靜音間隔,
  209.                     enable = 0;         //用以區分連續的兩個節拍
  210.                 }
  211.             }
  212.         }
  213.     }
  214. }
  215. void Delay_ms(unsigned int ms)
  216. {
  217.         for(;ms > 0;ms--)
  218.         {
  219.         unsigned char i, j;
  220.         i = 33;
  221.         j = 66;
  222.         do
  223.         {
  224.                 while (--j);
  225.         } while (--i);
  226.   }
  227. }
  228. unsigned char E2ReadByte(unsigned char addr)
  229. {
  230.         unsigned char dat;
  231.         I2CStart();
  232.         I2CWrite(0x51<<1);//發送E2PROM地址
  233.         I2CWrite(addr);//要讀取的地址
  234.         I2CStart();        //重新發送起始信號
  235.         I2CWrite((0x51<<1) |0x01);
  236.         dat = I2CReadNAK();
  237.         I2CStop();
  238.         return dat;
  239. }
  240. void E2WriteByte(unsigned char addr, unsigned char dat)
  241. {
  242.         I2CStart();
  243.         I2CWrite(0x51<<1);//發送E2PROM地址
  244.         I2CWrite(addr);//要寫入的地址
  245.         I2CWrite(dat);//要寫入的數據
  246.         I2CStop();
  247. }
  248. /*控制蜂鳴器發聲 */
  249. void InterruptTimer0() interrupt 1
  250. {
  251.     TH0 = T0RH;   //重新加載重載值
  252.     TL0 = T0RL;
  253.     tmrflag = 1;
  254.     if (enable)   //使能時反轉蜂鳴器控制電平
  255.         BUZZ = ~BUZZ;
  256.     else          //未使能時關閉蜂鳴器
  257.         BUZZ = 1;
  258. }
  259. /*按鍵掃描*/
  260. void InterruptTimer1() interrupt 3 //按鍵部分參看之前的帖子 帶有計次功能的秒表
  261. {
  262.         TH1 = 0xC9;
  263.         TL1 = 0xEA;
  264.
  265.           keybuf = (keybuf<<1) | KEY;
  266.     if (keybuf == 0x00)
  267.         KeySta = 0;
  268.     else if (keybuf == 0xFF)
  269.         KeySta = 1;
  270.     else{}
  271.
  272.           keybuf4 = (keybuf4<<1) | KEY4;
  273.     if (keybuf4 == 0x00)
  274.         KeySta4 = 0;
  275.     else if (keybuf4 == 0xFF)
  276.         KeySta4 = 1;
  277.     else{}
  278.
  279.          keybuf12= (keybuf12<<1) | KEY12;
  280.     if (keybuf12 == 0x00)
  281.         KeySta12 = 0;
  282.     else if (keybuf12 == 0xFF)
  283.         KeySta12 = 1;
  284.     else{}
  285.
  286.                               if (KeySta != backup)
  287.         {
  288.             if (backup == 0)
  289.                                                 {
  290.                                                         cntkey=~cntkey;
  291.                                                         TR0 = cntkey;
  292.                                                 }
  293.             backup = KeySta;
  294.         }
  295.                 if (KeySta4 != backup4)
  296.                 {
  297.                         if(backup4 ==0)
  298.                         {
  299.                                 breakflage = 1;
  300.                                 if(Num <All)
  301.                                   Num++;
  302.                           else if(Num == All)
  303.                                         Num =1;
  304.                                 LcdWriteCmd(0x01);  //清屏
  305.                                 lcd1602updata();
  306.                                 //P0 = LedChar[Num];
  307.                         }
  308.                         backup4 = KeySta4;
  309.                 }
  310.
  311.                 if (KeySta12 != backup12)
  312.                 {
  313.                         if(backup12 ==0)
  314.                         {
  315.                                 breakflage = 1;
  316.                                 if(Num >1)
  317.                                   Num--;
  318.                           else if(Num == 1)
  319.                                         Num =All;
  320.
  321.                                 LcdWriteCmd(0x01);  //清屏
  322.                                 lcd1602updata();
  323.                                 //P0 = LedChar[Num];
  324.                         }
  325.                         backup12 = KeySta12;
  326.                 }
  327.
  328. }
LCD1602函數
  1. #include <STC12C5A60S2.h>
  2. #include <intrins.h>
  3. #define LCD1602_DB  P0
  4. sbit LCD1602_RS = P2^0;
  5. sbit LCD1602_RW = P2^1;
  6. sbit LCD1602_E  = P1^2;
  7. # pragma optimize(4, SPEED)
  8. void delayus(unsigned int n)
  9. {
  10.     extern void _nop_(void);
  11.     register unsigned char i = n, j = (n>>8);
  12.     _nop_(); _nop_(); _nop_();
  13.     if ((--i) | j)
  14.     {
  15.         do
  16.         {
  17.             _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_();
  18.             if (0xFF == (i--)) j--; else {_nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_();};
  19.         } while (i | j);
  20.     }
  21. }
  22. void delayms(unsigned int n) {while (n--) delayus(1000);}
  23. /* 等待液晶準備好 */
  24. void LcdWaitReady()
  25. {
  26.     unsigned char sta;
  27.
  28.     LCD1602_DB = 0xFF;
  29.     LCD1602_RS = 0;
  30.     LCD1602_RW = 1;
  31.     do {
  32.         LCD1602_E = 1;
  33.         sta = LCD1602_DB; //讀取狀態字
  34.         LCD1602_E = 0;
  35.     } while (sta & 0x80); //bit7等于1表示液晶正忙,重復檢測直到其等于0為止
  36. }
  37. /* 向LCD1602液晶寫入一字節命令,cmd-待寫入命令值 */
  38. void LcdWriteCmd(unsigned char cmd)
  39. {
  40.         LcdWaitReady();
  41.         LCD1602_RS = 0;
  42.         LCD1602_RW = 0;
  43.         LCD1602_DB = cmd;
  44.             delayus(1);
  45.         LCD1602_E = 1;    delayus(1);
  46.         LCD1602_E = 0;    delayms(2);
  47. }
  48. void LcdWriteDat(unsigned char dat)
  49. {
  50.         LcdWaitReady();
  51.         LCD1602_RS = 1;
  52.         LCD1602_RW = 0;
  53.         LCD1602_DB = dat;    delayus(1);
  54.         LCD1602_E = 1;    delayus(1);
  55.         LCD1602_E = 0;    delayms(2);
  56. }
  57. /* 設置顯示RAM起始地址,亦即光標位置,(x,y)-對應屏幕上的字符坐標 */
  58. void LcdSetCursor(unsigned char x, unsigned char y)
  59. {
  60.     unsigned char addr;
  61.
  62.     if (y == 0)  //由輸入的屏幕坐標計算顯示RAM的地址
  63.         addr = 0x00 + x;  //第一行字符地址從0x00起始
  64.     else
  65.         addr = 0x40 + x;  //第二行字符地址從0x40起始
  66.     LcdWriteCmd(addr | 0x80);  //設置RAM地址
  67. }
  68. /* 在液晶上顯示字符串,(x,y)-對應屏幕上的起始坐標,str-字符串指針 */
  69. void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str)
  70. {
  71.         bit flag = 0;
  72.         unsigned char Num = 0;
  73.     LcdSetCursor(x, y);   //設置起始地址
  74.
  75.     while (*str != '\0')  //連續寫入字符串數據,直到檢測到結束符
  76.     {
  77.         LcdWriteDat(*str++);
  78.                          Num ++;
  79.                         if(Num >=12)
  80.                         {
  81.                                 flag = 1;
  82.                                 break;
  83.                         }
  84.     }
  85.                 if(flag == 1)
  86.                 {
  87.       LcdSetCursor(0, 1);
  88.                         while (*str != '\0')  //連續寫入字符串數據,直到檢測到結束符
  89.     {
  90.         LcdWriteDat(*str++);
  91.     }
  92.                 }
  93. }
  94. /* 初始化1602液晶 */
  95. void InitLcd1602()
  96. {
  97.     LcdWriteCmd(0x38);  //16*2顯示,5*7點陣,8位數據接口
  98.     LcdWriteCmd(0x0C);  //顯示器開,光標關閉
  99.     LcdWriteCmd(0x06);  //文字不動,地址自動+1
  100.     LcdWriteCmd(0x01);  //清屏
  101. }
ID:1 發表于 2019-2-13 00:43 | 顯示全部樓層
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
ID:229821 發表于 2019-3-29 20:11 | 顯示全部樓層
下面還有嗎??
ID:399179 發表于 2019-11-22 21:53 來自觸屏版 | 顯示全部樓層
saya0769 發表于 2019-3-29 20:11
下面還有嗎??
掉電記憶程序怎么寫?
