我把無線非鎖接收板接到單片機,,來控制PWM的發射和終止。但是按一下有時候可以發出,有時候按好幾下都發不出,請高手解決,
#include "pwm_register.h"
#include "stdbool.h"
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
int n;
uchar i;
sbit D0 = P0^0;
sbit D1 = P0^1;
sbit D = P2^7;
sbit D3 = P0^3;
sbit VT=P0^4;
void LED_init()
ENLED=0;
ADDR3=0;
ADDR2=0;
ADDR1=0;
ADDR0=0;
delay(uchar);
wb_int0() interrupt 0
if(VT==0)
i=D;
EA=1;
EX0=1;
IT0=1;
LED_init();
if(i==1)
delay(5);
if(i==1)
n++;
delay(10);
if(n==1)
enable_xsfr();
pwm_clock_speed(0);
set_pwm_period(0x1000);
set_pwm0_T1_T2_point(0x200,0x700);
enable_pwm0();
disable_xsfr();
enable_pwm();
if(n==2)
disable_pwm();
disable_pwm0();
n=0;
while(!D);
delay(10);
while(!D);
delay(uchar x)
uchar a,b;
for(a=x;a>0;a--)
for(b=200;b>0;b--);
2019-2-11 20:55 上傳
