查看: 2392|回復(fù): 1
STM32紅外遙控交通燈程序
ID:474146 發(fā)表于 2019-2-11 02:43 | 顯示全部樓層 |閱讀模式
STM32紅外遙控交通燈
單片機(jī)源程序如下:
  1. /* Includes ------------------------------------------------------------------*/
  2. #include "stm32f10x.h"
  3. #include "Lcd_Driver.h"
  4. #include "GUI.h"
  5. #include "delay.h"
  6. #include "Picture.h"
  7. #include "LCD.h"
  8. #include "led.h"
  9. #include "sys.h"
  10. #include "usart.h"
  11. #include "remote.h"
  12. GPIO_InitTypeDef GPIO_InitStructure;
  13. void RCC_Configuration(void);
  14. void Delayms(__IO uint32_t nCount);
  15. unsigned char Num[10]={0,1,2,3,4,5,6,7,8,9};
  16. unsigned char flag=0;
  17. int i ;
  18. uchar num0=30;
  19. void Redraw_Mainmenu(void)
  20. {
  21.         Lcd_Clear(GRAY0);
  22.
  23.         Gui_DrawFont_GBK16(16,0,BLUE,GRAY0,"全動(dòng)電子技術(shù)");
  24.         Gui_DrawFont_GBK16(16,20,RED,GRAY0,"液晶測試程序");
  25.         DisplayButtonUp(15,38,113,58); //x1,y1,x2,y2
  26.         Gui_DrawFont_GBK16(16,40,YELLOW,GRAY0,"顏色填充測試");
  27.         DisplayButtonUp(15,68,113,88); //x1,y1,x2,y2
  28.         Gui_DrawFont_GBK16(16,70,BLUE,GRAY0,"文字顯示測試");
  29.         DisplayButtonUp(15,98,113,118); //x1,y1,x2,y2
  30.         Gui_DrawFont_GBK16(16,100,RED,GRAY0,"圖片顯示測試");
  31.         Gui_DrawFont_GBK16(16,120,BLUE,GRAY0,"S1:Move.    ");
  32.         Gui_DrawFont_GBK16(16,140,RED,GRAY0, "S2:Sellect  ");
  33.
  34.         Gui_DrawFont_Num32(100,125,RED,GRAY0,Num[5]);
  35.         delay_ms(1000);
  36.         Gui_DrawFont_Num32(100,125,RED,GRAY0,Num[4]);
  37.         delay_ms(1000);
  38.         Gui_DrawFont_Num32(100,125,RED,GRAY0,Num[3]);
  39.         delay_ms(1000);
  40.         Gui_DrawFont_Num32(100,125,RED,GRAY0,Num[2]);
  41.         delay_ms(1000);
  42.         Gui_DrawFont_Num32(100,125,RED,GRAY0,Num[1]);
  43.         delay_ms(1000);
  44.         Gui_DrawFont_Num32(100,125,RED,GRAY0,Num[0]);
  45. }
  46. void Num_Test(void)
  47. {
  48.         u8 i=0;
  49.         Lcd_Clear(GRAY0);
  50.         Gui_DrawFont_GBK16(16,20,RED,GRAY0,"Num Test");
  51.         delay_ms(1000);
  52.         Lcd_Clear(GRAY0);
  53.         for(i=0;i<10;i++)
  54.         {
  55.         Gui_DrawFont_Num32((i%3)*40,32*(i/3)+30,RED,GRAY0,Num[i+1]);
  56.         delay_ms(100);
  57.         }
  58.
  59. }
  60. void Font_Test(void)
  61. {
  62.         Lcd_Clear(GRAY0);
  63.         Gui_DrawFont_GBK16(16,10,BLUE,GRAY0,"文字顯示測試");
  64.         delay_ms(1000);
  65.         Lcd_Clear(GRAY0);
  66.         Gui_DrawFont_GBK16(16,30,YELLOW,GRAY0,"全動(dòng)電子技術(shù)");
  67.         Gui_DrawFont_GBK16(16,50,BLUE,GRAY0,"專注液晶批發(fā)");
  68.         Gui_DrawFont_GBK16(16,70,RED,GRAY0, "全程技術(shù)支持");
  69.         Gui_DrawFont_GBK16(0,100,BLUE,GRAY0,"Tel:15989313508");
  70.         Gui_DrawFont_GBK16(0,130,RED,GRAY0, "www.qdtech.net");
  71.         delay_ms(1800);
  72. }
  73. void Color_Test(void)
  74. {
  75.         u8 i=1;
  76.         Lcd_Clear(GRAY0);
  77.
  78.         Gui_DrawFont_GBK16(20,10,BLUE,GRAY0,"Color Test");
  79.         delay_ms(200);
  80.         while(i--)
  81.         {
  82.         Lcd_Clear(WHITE);
  83.         Lcd_Clear(BLACK);
  84.         Lcd_Clear(RED);
  85.   Lcd_Clear(GREEN);
  86.   Lcd_Clear(BLUE);
  87.         }
  88. }
  89. //16位 垂直掃描  右到左  高位在前
  90. void show_pic()
  91. {
  92.         int i,j,k;
  93.         unsigned char picH,picL;
  94.         Lcd_Clear(GRAY0);
  95.         Gui_DrawFont_GBK16(16,10,BLUE,GRAY0,"圖片顯示測試");
  96.         delay_ms(1000);
  97.         Lcd_Clear(GRAY0);
  98.         k=0;
  99.         for(i=0;i<128;i++)
  100.         for(j=0;j<160;j++)
  101.         {
  102.                 picH=gImage_123[k++];
  103.                 picL=gImage_123[k++];
  104.                 Lcd_WriteData(picH);
  105.                 Lcd_WriteData(picL);
  106.         }
  107. }
  108. u16 ID=0;
  109. int main(void)
  110. {
  111.
  112.         u8 key,t=0;
  113.   u8 *str=0;
  114.
  115.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  116.         uart_init(115200);
  117.         LED_Init();
  118.
  119.         Remote_Init();
  120.
  121.   SystemInit();
  122.   delay_init(72);//延時(shí)初始化
  123.         Lcd_Init(0);
  124.         LCD_LED_SET;//??IO?????
  125.
  126. while(1)
  127.   {
  128.   TM1620_Init();
  129.         init_TM1620i();      // ???LCD????
  130.         init_TM1620ii();
  131.                 LCD_LED_SET;//??IO?????
  132.     /*Redraw_Mainmenu();
  133.                 Color_Test();//????????
  134.                 Num_Test();
  135.                 Font_Test();//???????
  136.                 show_pic();//??????
  137.                 delay_ms(1200);*/
  138.
  139.
  140.                     lcd0_display(88);   //lcd0???????
  141.                                 lcd2_display(88);
  142.                     lcd1_display(88);   //lcd0???????
  143.                                 lcd3_display(88);
  144.
  145.
  146.                 key=Remote_Scan();
  147.                 if(key)
  148.         {
  149.                                         Lcd_Clear(GRAY0); //有按鍵則清屏
  150.             switch(key)
  151.             {
  152.                 case 0:str="ERROR";break;
  153.                 case 162:str="yellow led on";flag=1;break;
  154.                 case 98:str="yellow led off";flag=0;break;
  155.                 case 2:str="green led on";flag=2;  break;
  156.                 case 226:str="green led off";  flag=3; break;
  157.                                                           case 194:str="Pattern 1"; flag=4;break;
  158.                 case 34:str="Pattern 2";flag=5;break;
  159.                 case 224:str="Pattern 3";flag=6;break;
  160.                 case 168:str="Pattern 4";flag=7;break;
  161.                 case 144:str="play";flag=8;break;
  162.                 case 104:str="1";flag=9;break;
  163.                 case 152:str="2";break;
  164.                 case 176:str="3";break;
  165.                 case 48:str="4";break;
  166.                 case 24:str="5";break;
  167.                 case 122:str="6";break;
  168.                 case 16:str="7";break;
  169.                 case 56:str="8";break;
  170.                 case 90:str="9";break;
  171.                 case 66:str="0";break;
  172.                 case 82:str="DELETE";break;
  173.             }
  174.
  175.                                 Gui_DrawFont_GBK16(16,10,BLUE,GRAY0,str);
  176.                         }
  177.                                 if(flag==1)
  178.                                 {
  179.
  180.                                         LED0= 1 ;
  181.                                         LED1=1;
  182.                                         LED2=1;
  183.                                         LED3=1;
  184.                                 }
  185.                            if(flag==0)
  186.                                          {
  187.                                          LED0= 0 ;
  188.                                          LED1=0;
  189.                                          LED2=0;
  190.                                          LED3=0;
  191.                                          }
  192.                                          if(flag==2)
  193.                                          {
  194.                                          LED4= 1 ;
  195.                                          LED5=1;
  196.                                          LED6=1;
  197.                                          LED7=1;
  198.                                          }
  199.                                          if(flag==3)
  200.                                          {
  201.                                          LED4= 0 ;
  202.                                          LED5=0;
  203.                                          LED6=0;
  204.                                          LED7=0;
  205.                                          }
  206.                                          if(flag==4)
  207.                                          {
  208.        while(num0)
  209.                         {
  210.                                 num0--;
  211.                                 lcd0_display(num0);
  212.
  213.
  214.                         delay_ms(200);
  215.
  216.                                 if(num0 == 0)
  217.                                                 {
  218.                                                 while(4-i)
  219.                                                 {
  220.                                         LED0= 1 ;
  221.                                         LED1=1;
  222.                                         LED2=1;
  223.                                         LED3=1;
  224.                                         LED4= 1 ;
  225.                                          LED5=1;
  226.                                          LED6=1;
  227.                                          LED7=1;
  228.                                 delay_ms(1000);
  229.                                                           LED0= 0 ;
  230.                                          LED1=0;
  231.                                          LED2=0;
  232.                                          LED3=0;
  233.                                                           LED4= 0 ;
  234.                                          LED5=0;
  235.                                          LED6=0;
  236.                                          LED7=0;
  237.                                                          delay_ms(1000);
  238.                                                          i++;
  239.
  240.                                                 }break;         }
  241.
  242.
  243.                                          }break;
  244.                                          }
  245.            if(flag==5)
  246.                                          {
  247.                                                  while(num0)
  248.                                                  {
  249.
  250.                                                  num0--;
  251.                                 lcd1_display(num0);
  252.
  253.                         delay_ms(200);
  254.                                                 if(num0 == 0)
  255.                                                 {
  256.                                                  while(4-i)
  257.                                                  {
  258.                                          LED0=1 ;
  259.                                                  delay_ms(200);
  260.                                          LED0=0;
  261.                                          LED7=1;
  262.                                                  delay_ms(200);
  263.                                          LED7=0;
  264.                                                  LED3=1;
  265.                                                  delay_ms(200);
  266.                                                  LED3=0;
  267.                                                  LED4=1;
  268.                                                  delay_ms(200);
  269.                                                  LED4=0;
  270.                                                  LED2=1;
  271.                                                  delay_ms(200);
  272.                                                  LED2=0;
  273.                                                  LED5=1;
  274.                                                  delay_ms(200);
  275.                                                  LED5=0;
  276.                                                  LED1=1;
  277.                                                  delay_ms(200);
  278.                                                  LED1=0;
  279.                                                  LED6=1;
  280.                                                  delay_ms(200);
  281.                                                  LED6=0;
  282.                                                  delay_ms(200);
  283.                                                  i++;
  284.                                          } break;}
  285.                                          }break;
  286.                                          }
  287.
  288.
  289.                                          if(flag==6)
  290.                                          {
  291.                                                  while(num0)
  292.                                                  { num0--;
  293.                                 lcd3_display(num0);
  294.
  295.
  296.                         delay_ms(200);
  297.                                                  if(num0 == 0)
  298.                                                 {
  299.                                                  while(4-i)
  300.                                                  {
  301.                                          LED0=1 ;
  302.                                                  delay_ms(200);
  303.                                          LED0=0;
  304.                                          LED6=1;
  305.                                                  delay_ms(200);
  306.                                          LED6=0;
  307.                                                   LED1=1;
  308.                                                  delay_ms(200);
  309.                                                  LED1=0;
  310.                                                  LED5=1;
  311.                                                  delay_ms(200);
  312.                                                  LED5=0;
  313.                                                  LED2=1;
  314.                                                  delay_ms(200);
  315.                                                  LED2=0;
  316.                                                  LED4=1;
  317.                                                  delay_ms(200);
  318.                                                  LED4=0;
  319.                                                  LED3=1;
  320.                                                  delay_ms(200);
  321.                                                   LED3=0;
  322.                                                  LED7=1;
  323.                                                  delay_ms(200);
  324.                                                  LED7=0;
  325.                                                  delay_ms(200);
  326.                                                  i++;
  327.                                          }break;}
  328.                                  }break;
  329.                                          }
  330.                                           if(flag==7)
  331.                                          {
  332.                                                  while(num0)
  333.                                                  {num0--;
  334.                                 lcd2_display(num0);
  335.
  336.
  337.                         delay_ms(200);
  338.                                                  if(num0 == 0)
  339.                                                 {
  340.                                                  while(4-i)
  341.                                                  {
  342.                                          LED0=1 ;
  343.                                                 LED1=1;
  344.                                                  LED2=1;
  345.                                                  LED3=1;
  346.                                                  delay_ms(200);
  347.                                                          LED0=0 ;
  348.                                                 LED1=0;
  349.                                                  LED2=0;
  350.                                                  LED3=0;
  351.
  352.                                                   LED4=1;
  353.                                                  LED5=1;
  354.                                                  LED6=1;
  355.                                                  LED7=1;
  356.                                                  delay_ms(200);
  357.                                                            LED4=0;
  358.                                                  LED5=0;
  359.                                                  LED6=0;
  360.                                                  LED7=0;
  361.                                                  i++;
  362.                                          }break;}
  363.                                  }break;
  364.                          }
  365.   }
  366.         LCD_LED_CLR;//IO?????
  367. }
  368. void RCC_Configuration(void)
  369. {
  370.   /* Setup the microcontroller system. Initialize the Embedded Flash Interface,
  371.      initialize the PLL and update the SystemFrequency variable. */
  372.   SystemInit();
  373. }
  374. void Delayms(__IO uint32_t nCount)
  375. {
  376.   for(; nCount != 0; nCount--);
  377. }
  378. #ifdef  USE_FULL_ASSERT
  379. /**
  380.   * @brief  Reports the name of the source file and the source line number
  381.   *   where the assert_param error has occurred.
  382.   * @param file: pointer to the source file name
  383.   * @param line: assert_param error line source number
  384.   * @retval : None
  385.   */
  386. void assert_failed(uint8_t* file, uint32_t line)
  387. {
  388.   /* User can add his own implementation to report the file name and line number,
  389.      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  390.   /* Infinite loop */
  391.   while (1)
  392.   {
  393.   }
  394. }
  395. #endif
  396. /******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE****/
程序.7z (95.83 KB, 下載次數(shù): 19)
ID:1 發(fā)表于 2019-2-11 23:45 | 顯示全部樓層
本帖需要重新編輯補(bǔ)全電路原理圖,源碼,詳細(xì)說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
