查看: 3573|回復(fù): 0
關(guān)于stm32f4串口USART置程序
ID:473192 發(fā)表于 2019-1-26 19:52 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "usart3.h"
//////////使用printf需要以下代碼
struct __FILE
        int handle;
FILE __stdout;
//定義_sys_exit()以避免使用半主機模式
_sys_exit(int x)
        x = x;
//重定義fputc函數(shù)
//重定向c庫函數(shù)printf到USART3
int fputc(int ch, FILE *f)
                /* 發(fā)送一個字節(jié)數(shù)據(jù)到USART3 */
                USART_SendData(USART3, (uint8_t) ch);
                /* 等待發(fā)送完畢 */
                while (USART_GetFlagStatus(USART3, USART_FLAG_TXE) == RESET);
                return (ch);
void uart3_init(void){
   //GPIO端口設(shè)置
        USART_InitTypeDef USART_InitStructure;
        NVIC_InitTypeDef NVIC_InitStructure;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB,ENABLE); //使能GPIOb時鐘
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3,ENABLE);//使能USART3時鐘
        //串口3對應(yīng)引腳復(fù)用映射
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource10,GPIO_AF_USART3);
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource11,GPIO_AF_USART3);
        //USART3端口配置
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_11;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//復(fù)用功能
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;        //速度50MHz
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽復(fù)用輸出
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; //上拉
        GPIO_Init(GPIOB,&GPIO_InitStructure); //初始化PB
   //USART3 初始化設(shè)置
        USART_InitStructure.USART_BaudRate = 4800;//波特率設(shè)置
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字長為8位數(shù)據(jù)格式
        USART_InitStructure.USART_StopBits = USART_StopBits_1;//一個停止位
        USART_InitStructure.USART_Parity = USART_Parity_No;//無奇偶校驗位
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//無硬件數(shù)據(jù)流控制
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;        //收發(fā)模式
  USART_Init(USART3, &USART_InitStructure); //初始化串口3
  USART_Cmd(USART3, ENABLE);  //使能串口3
//        USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);//開啟相關(guān)中斷
//        //Usart3 NVIC 配置
//  NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn;//串口3中斷通道
//        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=4;//搶占優(yōu)先級3
//        NVIC_InitStructure.NVIC_IRQChannelSubPriority =0;                //子優(yōu)先級3
//        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                        //IRQ通道使能
//        NVIC_Init(&NVIC_InitStructure);        //根據(jù)指定的參數(shù)初始化VIC寄存器、
//u8 Res3;//全局變量
//void USART3_IRQHandler(void)                        //串口3中斷服務(wù)程序
//        if(USART_GetITStatus(USART3, USART_IT_RXNE) != RESET)  //接收中斷
//                Res3=USART_ReceiveData(USART3);
//                USART_ClearFlag(USART3,USART_IT_RXNE); //清除標志位
。h文件
#ifndef __USART3_H
#define __USART3_H
#include "sys.h"
#include <stdio.h>
extern u8 Res3;
void uart3_init(void);
#endif
參與人數(shù) 1黑幣 +50 收起 理由
