VESC DC _ BLDC _ FOC本杰明控制器C源碼,分享大家
- Copyright 2016 Benjamin Vedder benjamin@vedder.se
- This file is part of the VESC firmware.
- The VESC firmware is free software: you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation, either version 3 of the License, or
- (at your option) any later version.
- The VESC firmware is distributed in the hope that it will be useful,
- but WITHOUT ANY WARRANTY; without even the implied warranty of
- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- GNU General Public License for more details.
- You should have received a copy of the GNU General Public License
- along with this program. If not, see <http://www.gnu.org/licenses/>.
- #include "ch.h"
- #include "hal.h"
- #include "stm32f4xx_conf.h"
- #include <stdio.h>
- #include <math.h>
- #include <string.h>
- #include <stdlib.h>
- #include "mc_interface.h"
- #include "mcpwm.h"
- #include "mcpwm_foc.h"
- #include "ledpwm.h"
- #include "comm_usb.h"
- #include "terminal.h"
- #include "hw.h"
- #include "app.h"
- #include "packet.h"
- #include "commands.h"
- #include "timeout.h"
- #include "comm_can.h"
- #include "ws2811.h"
- #include "led_external.h"
- #include "encoder.h"
- #include "servo.h"
- #include "servo_simple.h"
- #include "utils.h"
- #include "nrf_driver.h"
- #include "rfhelp.h"
- #include "spi_sw.h"
- * Timers used:
- * TIM7: servo
- * TIM1: mcpwm
- * TIM2: mcpwm
- * TIM12: mcpwm
- * TIM8: mcpwm
- * TIM3: servo_dec/Encoder (HW_R2)/servo_simple
- * TIM4: WS2811/WS2812 LEDs/Encoder (other HW)
- * DMA/stream Device Function
- * 1, 2 I2C1 Nunchuk, temp on rev 4.5
- * 1, 7 I2C1 Nunchuk, temp on rev 4.5
- * 1, 1 UART3 HW_R2
- * 1, 3 UART3 HW_R2
- * 2, 2 UART6 Other HW
- * 2, 7 UART6 Other HW
- * 2, 4 ADC mcpwm
- * 1, 0 TIM4 WS2811/WS2812 LEDs CH1 (Ch 1)
- * 1, 3 TIM4 WS2811/WS2812 LEDs CH2 (Ch 2)
- // Private variables
- static THD_WORKING_AREA(periodic_thread_wa, 1024);
- static THD_WORKING_AREA(timer_thread_wa, 128);
- static THD_FUNCTION(periodic_thread, arg) {
- (void)arg;
- chRegSetThreadName("Main periodic");
- for(;;) {
- if (mc_interface_get_state() == MC_STATE_RUNNING) {
- ledpwm_set_intensity(LED_GREEN, 1.0);
- } else {
- ledpwm_set_intensity(LED_GREEN, 0.2);
- mc_fault_code fault = mc_interface_get_fault();
- if (fault != FAULT_CODE_NONE) {
- for (int i = 0;i < (int)fault;i++) {
- ledpwm_set_intensity(LED_RED, 1.0);
- chThdSleepMilliseconds(250);
- ledpwm_set_intensity(LED_RED, 0.0);
- chThdSleepMilliseconds(500);
- } else {
- if (mc_interface_get_state() == MC_STATE_DETECTING) {
- commands_send_rotor_pos(mcpwm_get_detect_pos());
- disp_pos_mode display_mode = commands_get_disp_pos_mode();
- switch (display_mode) {
- case DISP_POS_MODE_ENCODER:
- commands_send_rotor_pos(encoder_read_deg());
- break;
- case DISP_POS_MODE_PID_POS:
- commands_send_rotor_pos(mc_interface_get_pid_pos_now());
- break;
- case DISP_POS_MODE_PID_POS_ERROR:
- commands_send_rotor_pos(utils_angle_difference(mc_interface_get_pid_pos_set(), mc_interface_get_pid_pos_now()));
- break;
- default:
- break;
- if (mc_interface_get_configuration()->motor_type == MOTOR_TYPE_FOC) {
- case DISP_POS_MODE_OBSERVER:
- commands_send_rotor_pos(mcpwm_foc_get_phase_observer());
- break;
- case DISP_POS_MODE_ENCODER_OBSERVER_ERROR:
- commands_send_rotor_pos(utils_angle_difference(mcpwm_foc_get_phase_observer(), mcpwm_foc_get_phase_encoder()));
- break;
- default:
- break;
- chThdSleepMilliseconds(10);
- // chThdSleepMilliseconds(40);
- // volatile const mc_configuration *conf = mc_interface_get_configuration();
- // float vq = mcpwm_foc_get_vq();
- // float iq = mc_interface_get_tot_current_directional();
- // float linkage = conf->foc_motor_flux_linkage;
- // float speed = ((2.0 * M_PI) / 60.0) * mc_interface_get_rpm();
- // if (iq < -6.0) {
- // float res = vq / (linkage * speed * iq);
- // res *= 2.0 / 3.0;
- // static float res_filtered = 0.0;
- // UTILS_LP_FAST(res_filtered, res, 0.02);
- // commands_printf("Res: %.4f", (double)res_filtered);
- // commands_printf("Max: %.2f Min: %.2f",
- // (double)mc_interface_get_configuration()->lo_current_motor_max_now,
- // (double)mc_interface_get_configuration()->lo_current_motor_min_now);
- static THD_FUNCTION(timer_thread, arg) {
- (void)arg;
- chRegSetThreadName("msec_timer");
- for(;;) {
- packet_timerfunc();
- chThdSleepMilliseconds(1);
- int main(void) {
- halInit();
- chSysInit();
- // Initialize the enable pins here and disable them
- // to avoid excessive current draw at boot because of
- // floating pins.
- #ifdef HW_HAS_DRV8313
- INIT_BR();
- #endif
- chThdSleepMilliseconds(1000);
- hw_init_gpio();
- LED_RED_OFF();
- LED_GREEN_OFF();
- conf_general_init();
- ledpwm_init();
- mc_configuration mcconf;
- conf_general_read_mc_configuration(&mcconf);
- mc_interface_init(&mcconf);
- commands_init();
- comm_usb_init();
- app_configuration appconf;
- conf_general_read_app_configuration(&appconf);
- app_set_configuration(&appconf);
- #ifdef HW_HAS_PERMANENT_NRF
- conf_general_permanent_nrf_found = nrf_driver_init();
- if (conf_general_permanent_nrf_found) {
- rfhelp_restart();
- } else {
- nrf_driver_stop();
- // Set the nrf SPI pins to the general SPI interface so that
- // an external NRF can be used with the NRF app.
- spi_sw_change_pins(
- HW_SPI_PORT_NSS, HW_SPI_PIN_NSS,
- HW_SPI_PORT_SCK, HW_SPI_PIN_SCK,
- HW_SPI_PORT_MOSI, HW_SPI_PIN_MOSI,
- HW_SPI_PORT_MISO, HW_SPI_PIN_MISO);
- #endif
- timeout_init();
- timeout_configure(appconf.timeout_msec, appconf.timeout_brake_current);
- #if CAN_ENABLE
- comm_can_init();
- #endif
- #if WS2811_ENABLE
- ws2811_init();
- #if !WS2811_TEST
- led_external_init();
- #endif
- #endif
- #if SERVO_OUT_ENABLE
- #if SERVO_OUT_SIMPLE
- servo_simple_init();
- #else
- servo_init();
- #endif
- #endif
- // Threads
- chThdCreateStatic(periodic_thread_wa, sizeof(periodic_thread_wa), NORMALPRIO, periodic_thread, NULL);
- chThdCreateStatic(timer_thread_wa, sizeof(timer_thread_wa), NORMALPRIO, timer_thread, NULL);
- #if WS2811_TEST
- unsigned int color_ind = 0;
- const int num = 4;
- const uint32_t colors[] = {COLOR_RED, COLOR_GOLD, COLOR_GRAY, COLOR_MAGENTA, COLOR_BLUE};
- const int brightness_set = 100;
- for (;;) {
- for (int i = 0;i < brightness_set;i++) {
- ws2811_set_brightness(i);
- for(int i = -num;i <= WS2811_LED_NUM;i++) {
- ws2811_set_led_color(i - 1, COLOR_BLACK);
- ws2811_set_led_color(i + num, colors[color_ind]);
- ws2811_set_led_color(0, COLOR_RED);
- ws2811_set_led_color(WS2811_LED_NUM - 1, COLOR_GREEN);
- chThdSleepMilliseconds(50);
- ws2811_set_brightness(brightness_set - i);
- color_ind++;
- if (color_ind >= sizeof(colors) / sizeof(uint32_t)) {
- color_ind = 0;
- static int asd = 0;
- asd++;
- if (asd >= 3) {
- asd = 0;
- for (unsigned int i = 0;i < sizeof(colors) / sizeof(uint32_t);i++) {
- ws2811_set_all(colors[i]);
- chThdSleepMilliseconds(2);
- chThdSleepMilliseconds(100);
- #endif
- for(;;) {
- if (encoder_is_configured()) {
- // comm_can_set_pos(0, encoder_read_deg());
bldc-master.7z
(760.42 KB, 下載次數: 122)
2019-1-26 00:39 上傳
VESC DC _ BLDC _ FOC控制器
