#include <STC15F2K60S2.H>
#include"intrins.h"
sbit key=P3^5;
sbit LED=P3^4;
unsigned char L,value,time,num;
bit S,flag,d;
void delay_ms(unsigned char z)
unsigned int x,y;
for(x=z; x>0; x--)
for(y=848; y>0; y--);
void HY()
{ if(!S)
switch(L)
case 0: LED=1;break;
case 1: LED=0;delay_ms(2);LED=1;delay_ms(8);break;
case 2: LED=0;delay_ms(4);LED=1;delay_ms(6);break;
case 3: LED=0;delay_ms(6);LED=1;delay_ms(4);break;
case 4: LED=0;break;
if(S)
switch(L)
case 1: LED=0;delay_ms(45);LED=1;delay_ms(255);break;
case 2: LED=0;delay_ms(80);LED=1;delay_ms(220);break;
case 3: LED=0;delay_ms(150);LED=1;delay_ms(150);break;
case 4: LED=0;delay_ms(10);LED=1;delay_ms(90);break;
void Timer0Init(void) //5毫秒@12.000MHz
AUXR &= 0x7F; //定時器時鐘12T模式
TMOD &= 0xF0; //設(shè)置定時器模式
TL0 = 0x00; //設(shè)置定時初值
TH0 = 0xEE; //設(shè)置定時初值
TF0 = 0; //清除TF0標(biāo)志
TR0 = 1; //定時器0開始計時
EA = 1;
ET0 = 1;
unsigned char getkey()
static unsigned char lp=0;
switch(lp)
case 0:
if(!key)lp++;
else if(flag)
if(++time>50)
value=1; //單擊
time=0,
flag=0;
break;
case 1:if(!key)lp++;else lp=0;break; // 消抖動
case 2:
if(key)
lp++;
if(flag)
value=2; //連擊
flag=0;
else flag=1;
else if(++num>250)
flag=0;
value=3; //長按
lp++;
break;
case 3:if(key){lp=0;num=0;time=0;}break;
return value;
main()
LED=1;
L=0;S=0;flag=0;value=0,d=0;
Timer0Init();
if(d==0&&key==1)
LED=1;
ET0 = 0;
INT_CLKO |= 0x20; //INT3 Enable
PCON = 0x02; //MCU進(jìn)入掉電模式
_nop_();
_nop_();
_nop_();
_nop_();
HY();
void timer()interrupt 1
switch(getkey())
case 1:
L++;
value=0;
if(L>4) L=1;
break;
case 2: S=~S;L=1;value=0;break;
case 3: L=0;value=0;d=0; break;
void INT3_int (void) interrupt 11
INT_CLKO &= 0xDF;
delay_ms(30);
if(key==0)
{d=1;
L=1;
ET0 = 1;
