- /* --------------- APPLICATION GLOBALS ---------------- */
- static OS_TCB AppTaskStartTCB;
- static CPU_STK AppTaskStartStk[APP_CFG_TASK_START_STK_SIZE];
- static OS_TCB AppTaskObj0TCB;
- static CPU_STK AppTaskObj0Stk[APP_CFG_TASK_OBJ0_STK_SIZE];
- static OS_TCB AppTaskGUITCB;
- __align(8) static CPU_STK AppTaskGUIStk[APP_CFG_TASK_GUI_STK_SIZE];
- * FUNCTION PROTOTYPES
- static void AppTaskStart (void *p_arg);
- static void AppTaskCreate (void);
- static void AppObjCreate (void);
- static void AppTaskObj0 (void *p_arg);
- static void AppTaskGUI (void *p_arg);
- KEY Key1,Key2;
- uint8_t tpad_flag=0;
- * main()
- * Description : This is the standard entry point for C code. It is assumed that your code will call
- * main() once you have performed all necessary initialization.
- * Arguments : none
- * Returns : none
- int main(void)
- OS_ERR err;
- #if (CPU_CFG_NAME_EN == DEF_ENABLED)
- CPU_ERR cpu_err;
- #endif
- Mem_Init(); /* Initialize Memory Managment Module */
- Math_Init(); /* Initialize Mathematical Module */
- CPU_NameSet((CPU_CHAR *)"STM32F429II",
- (CPU_ERR *)&cpu_err);
- #endif
- BSP_IntDisAll(); /* Disable all Interrupts. */
- OSInit(&err); /* Init uC/OS-III. */
- App_OS_SetAllHooks();
- OSTaskCreate(&AppTaskStartTCB, /* Create the start task */
- "App Task Start",
- AppTaskStart,
- 0u,
- APP_CFG_TASK_START_PRIO,
- &AppTaskStartStk[0u],
- AppTaskStartStk[APP_CFG_TASK_START_STK_SIZE / 10u],
- APP_CFG_TASK_START_STK_SIZE,
- 0u,
- 0u,
- 0u,
- (OS_OPT_TASK_STK_CHK | OS_OPT_TASK_STK_CLR),
- &err);
- if(err!=OS_ERR_NONE) bsp_result|=BSP_OS;
- OSStart(&err); /* Start multitasking (i.e. give control to uC/OS-III). */
- while (DEF_ON) { /* Should Never Get Here. */
- //按鍵定時掃描的定時器
- static void inputscan(void)
- OS_ERR err;
- OSSchedLock(&err);
- GT9xx_GetOnePiont();//觸摸屏定時掃描
- OSSchedUnlock(&err);
- Key_RefreshState(&Key1);//刷新按鍵狀態
- Key_RefreshState(&Key2);//刷新按鍵狀態
- if(Key_AccessTimes(&Key1,KEY_ACCESS_READ)!=0)//按鍵被按下過
- LED2_TOGGLE;
- Key_AccessTimes(&Key1,KEY_ACCESS_WRITE_CLEAR);
- if(Key_AccessTimes(&Key2,KEY_ACCESS_READ)!=0)//按鍵被按下過
- LED3_TOGGLE;
- Key_AccessTimes(&Key2,KEY_ACCESS_WRITE_CLEAR);
- * STARTUP TASK
- * Description : This is an example of a startup task. As mentioned in the book's text, you MUST
- * initialize the ticker only once multitasking has started.
- * Arguments : p_arg is the argument passed to 'AppTaskStart()' by 'OSTaskCreate()'.
- * Returns : none
- * Notes : 1) The first line of code is used to prevent a compiler warning because 'p_arg' is not
- * used. The compiler should not generate any code for this statement.
- OS_ERR err;
- (void)p_arg;
- BSP_Init(); /* Initialize BSP functions */
- CPU_Init(); /* Initialize the uC/CPU services */
- #if OS_CFG_STAT_TASK_EN > 0u
- OSStatTaskCPUUsageInit(&err); /* Compute CPU capacity with no task running */
- #endif
- #ifdef CPU_CFG_INT_DIS_MEAS_EN
- CPU_IntDisMeasMaxCurReset();
- #endif
- #if (APP_CFG_SERIAL_EN == DEF_ENABLED)
- APP_TRACE_DBG(("Creating Application kernel objects\n\r"));
- #endif
- AppObjCreate();
- /* Create Applicaiton kernel objects */
- APP_TRACE_DBG(("Creating Application Tasks\n\r"));
- #endif
- AppTaskCreate(); /* Create Application tasks */
- while (DEF_TRUE)
- { /* Task body, always written as an infinite loop. */
- inputscan();
- OSTimeDlyHMSM(0u, 0u, 0u, 20u,
- OS_OPT_TIME_HMSM_STRICT,
- &err);
- * AppTaskCreate()
- * Description : Create Application Tasks.
- * Argument(s) : none
- * Return(s) : none
- * Caller(s) : AppTaskStart()
- * Note(s) : none.
- OS_ERR os_err;
- /* ---------- CREATE KERNEL OBJECTS TEST TASK --------- */
- OSTaskCreate((OS_TCB *)&AppTaskObj0TCB,
- (CPU_CHAR *)"Kernel Objects Task 0",
- (OS_TASK_PTR )AppTaskObj0,
- (void *)0,
- (OS_PRIO )APP_CFG_TASK_OBJ0_PRIO,
- (CPU_STK *)&AppTaskObj0Stk[0],
- (CPU_STK_SIZE )AppTaskObj0Stk[APP_CFG_TASK_OBJ0_STK_SIZE / 10u],
- (CPU_STK_SIZE )APP_CFG_TASK_OBJ0_STK_SIZE,
- (OS_MSG_QTY )0u,
- (OS_TICK )0u,
- (void *)0,
- (OS_OPT )(OS_OPT_TASK_STK_CHK | OS_OPT_TASK_STK_CLR),
- (OS_ERR *)&os_err);
- OSTaskCreate((OS_TCB *)&AppTaskGUITCB,
- (OS_TASK_PTR )AppTaskGUI,
- (void *)0,
- (OS_PRIO )APP_CFG_TASK_GUI_PRIO,
- (CPU_STK *)&AppTaskGUIStk[0],
- (CPU_STK_SIZE )AppTaskGUIStk[APP_CFG_TASK_GUI_STK_SIZE / 10u],
- (CPU_STK_SIZE )APP_CFG_TASK_GUI_STK_SIZE,
- (OS_MSG_QTY )0u,
- (OS_TICK )0u,
- (void *)0,
- * AppObjCreate()
- * Description : Create Application Kernel Objects.
- * Note(s) : none.
- KeyCreate(&Key1,GetPinStateOfKey1);
- KeyCreate(&Key2,GetPinStateOfKey2);
- * AppTaskObj0()
- * Description : Test uC/OS-III objects.
- * Argument(s) : p_arg is the argument passed to 'AppTaskObj0' by 'OSTaskCreate()'.
- * Caller(s) : This is a task
- * Note(s) : none.
- OS_ERR err;
- static uint8_t tpad_count=0;
- (void)p_arg;
- while(TPAD_Init())
- tpad_count++;
- if(tpad_count>=10)
- bsp_result |= BSP_TPAD;
- break;
- bsp_DelayUS(1000);
- while(1)
- if((tpad_count<10)&&TPAD_Scan(0))
- BEEP_ON;
- if(UserApp_Flag)tpad_flag=1;
- OSTimeDlyHMSM(0, 0, 0, 100,
- &err);
- BEEP_OFF;
- /************** 板載錯誤 ***************/
- void hardwareerr(void)
- OS_ERR err;
- printf("bsp_result->(0x%04X)\n",bsp_result);
- if((bsp_result&(~BSP_NETWORK))==0) return;
- if(!((bsp_result&BSP_SDRAM)||(bsp_result&BSP_GUI)))
- char tempstr[20];
- sprintf(tempstr,"error->(0x%04X)",bsp_result);
- GUI_Clear();
- GUI_SetColor(GUI_RED);
- GUI_SetFont(GUI_FONT_24_ASCII);
- GUI_DispStringHCenterAt(tempstr, 400,120);
- LCD_BL_ON();
- while(1)
- LED1_ON;//BEEP_ON;
- OSTimeDlyHMSM(0,0,0,500,OS_OPT_TIME_HMSM_STRICT,&err);
- LED1_OFF;//BEEP_OFF;
- OSTimeDlyHMSM(0,0,0,100,OS_OPT_TIME_HMSM_STRICT,&err);
- * AppTaskObj1()
- * Argument(s) : p_arg is the argument passed to 'AppTaskObj1' by 'OSTaskCreate()'.
- * Note(s) : none.
- (void)p_arg;
- if(bsp_result!=BSP_OK)
- hardwareerr();
- while(1)
- emWinMainApp();
- /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
33. uCOSIII_emWin528_Demo(光敏電阻).7z
(3.09 MB, 下載次數: 39)
2019-1-21 02:38 上傳
