查看: 1118|回復: 1
尋跡小車程序
ID:469687 發表于 2019-1-17 15:00 | 顯示全部樓層 |閱讀模式
/*賽道邊框黑,賽道白*/
#include <reg52.h>
/****L298N硬件連接***/
sbit ENA = P1^0;
sbit ENB = P1^1;
sbit IN4 = P1^2;  /*1*/
sbit IN3 = P1^3;  /*0*/
sbit IN2 = P1^4;  /*1*/
sbit IN1 = P1^5;  /*0*/
sbit left3 = P0^0;
sbit left2 = P0^1;
sbit left1 = P0^2;
sbit right1= P0^3;
sbit right2= P0^4;
sbit right3= P0^5;
unsigned char zkb1 = 0;
unsigned char zkb2 = 0;
unsigned char t = 0;
void init()
    EA = 1;
    TMOD |= 0x01;
    TH0 =(65536 - 100) / 256;
    TL0 = (65536 - 100)% 256;
    ET0 = 1;
    TR0 = 1;
void timer0() interrupt 1
    TH0 = (65536 - 100) / 256;
    TL0 = (65536 - 100) % 256;
    if(t < zkb1)
      ENA = 1;
      ENA = 0;
    if(t < zkb2)
          ENB = 1;
          ENB = 0;
    ++t;
    if(t >= 100)
        t = 0;
void turn_left1()
    zkb1 = 30;
    zkb2 = 0;
void turn_left2()
    zkb1 = 0;
    zkb2 = 50;
void turn_left3()
    zkb1 = 0;
    zkb2 = 50;
void turn_right1()
    zkb1 =0;
    zkb2 =50;
void turn_right2()
    zkb1 =50;
    zkb2 =0;
void turn_right3()
    zkb1 =30;
    zkb2 =0;
void turn_qianjin()
    zkb1 =80;
    zkb2 =80;
/****主函數部分***/
    init();
  zkb1 = 70;
  zkb2 = 70;
    IN1 = 0;
    IN2 = 1;
    IN3 = 1;
    IN4 = 0;
  if((left3==1)&&(left2==0)&&(right3==0)&&(right2==0)&&(right1==0))
     turn_left3() ;
     if((left3==0)&&(left2==1)&&(right3==0)&&(right2==0)&&(right1==0))
     turn_left2() ;
  if((left3==0)&&(left2==0)&&(left1==0)&&(right3==0)&&(right2==0)&&(right1==0))
     turn_left1() ;
     if((left3==0)&&(left2==0)&&(left1==0)&&(right3==1)&&(right2==0))
    turn_right3();
  if((left3==0)&&(left2==0)&&(left1==0)&&(right3==0)&&(right2==1))
    turn_right2();
    turn_right1();
  if((left3==0)&&(left2==0)&&(left1==1)&&(right3==0)&&(right2==0)&&(right1==1))
    turn_qianjin() ;
ID:1 發表于 2019-1-18 01:21 | 顯示全部樓層
補全原理圖或者詳細說明一下電路連接即可獲得100+黑幣
