F303vct6,多通道adc,dma
1.gpio.c文件內(nèi)容需要改,按你們的實際接線
2.查詢狀態(tài)指令<255/STATUS_?中下劃線為非法字符,會導(dǎo)致串口命令解析出問題;我現(xiàn)在去掉了下劃線改為:<255/STATUS?
STM32單片機(jī)源程序如下:
- /* Includes ------------------------------------------------------------------*/
- #include "main.h"
- #include "adc1.h"
- #include "adc2.h"
- #include "usart1.h"
- #include "ws_spi3.h"
- #include "spi1.h"
- #include "string.h"
- #include "gpio.h"
- #include "usart2.h"
- #include "usart3.h"
- #include <math.h>
- #include "w5500.h"
- #include "W5500_conf.h"
- #include "socket.h"
- #include "utility.h"
- #include <stdio.h>
- #include "tcp_demo.h"
- #include "instruct.h"
- #include "instructADC.h"
- #include "dac.h"
- int paInputMin[3]={10,10,10};
- int paInputMax[3]={550,550,550};
- int paOutputRatio[3]={150,150,150};
- int paOutputMin[3]={10,1500,100};
- int pa1inPutmax;
- int pa2inputmax;
- int pa3inputmin;
- int pa1OutPutmin;
- int pa2Outputmin;
- int pa3Outputmin;
- int dataRatio;
- int MaxTempter=90;
- int remateLocalold=0;
- int Errornumber1,Errornumber2;
- u8 pa1ContrlState, pa2ContrlState, pa3ContrlState;
- /** @addtogroup STM32F30x_StdPeriph_Examples
- /** @addtogroup Basic_example
- #ifdef __GNUC__
- /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
- set to 'Yes') calls __io_putchar() */
- #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
- #else
- #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
- #endif /* __GNUC__ */
- __IO uint32_t TimingDelay = 0;
- u32 i=0;
- u8 j;
- float m,temp;
- int main(void)
- /*!< At this stage the microcontroller clock setting is already configured,
- this is done through SystemInit() function which is called from startup
- file (startup_stm32f30x.s) before to branch to application main.
- To reconfigure the default setting of SystemInit() function, refer to
- system_stm32f30x.c file
- //resent STm32
- // __set_FAULTMASK(1);
- // NVIC_SystemReset();
- uart1_init(115200);
- uart2_init(115200);
- uart3_init(115200);
- adc1_init();
- adc2_init();
- // SPI3_Configuration();
- // SPI1_Configuration();
- GPIO_Config();
- DAC_Config();
- DAC1_out(1800);
- DAC2_out(1500);
- gpio_for_w5500_config(); /*初始化MCU相關(guān)引腳*/
- reset_w5500(); /*硬復(fù)位W5500*/
- set_w5500_mac(); /*配置MAC地址*/
- set_w5500_ip(); /*配置IP地址*/
- socket_buf_init(txsize, rxsize); /*初始化8個Socket的發(fā)送接收緩存大小*/
- printf(" 源地網(wǎng)絡(luò)適配版作為TCP 服務(wù)器,建立偵聽,等待PC作為TCP Client建立連接 \r\n");
- printf(" W5500監(jiān)聽端口為: %d \r\n",local_port);
- printf(" 連接成功后,TCP Client發(fā)送數(shù)據(jù)給W5500,W5500將返回對應(yīng)數(shù)據(jù) \r\n");
- while (1)
- loopback_tcps(SOCK_TCPS, local_port);/*TCP_Server 數(shù)據(jù)回環(huán)測試程序*/
- getADCpara();
- //異常保護(hù)
- if(ALLerror_open==0)
- PAERROR();
- Delay(5);
- usart1_cmd();
- if(controlState())
- if(remateLocalold==0)
- SetPA1RFONOFF(0);
- SetPA2RFONOFF(0);
- SetPA3RFONOFF(0);
- for(i=0;i<3;i++)
- Tempter_errorState[i]=0;
- output_errorState[i]=0;
- input_errorState[i]=0;
- clearchan1();
- remateLocalold=1;
- else
- localCTR1();
- remateLocalold=0;
- Delay(5);
- * @brief Inserts a delay time.
- * @param nTime: specifies the delay time length, in milliseconds.
- * @retval None
- void Delay(__IO uint32_t nTime)
- TimingDelay = nTime;
- while(TimingDelay != 0);
- void localCTR1(void)
- u8 i,PA1statan,PA2statan,PA3statan;
- ///////////////// remate to local///////////////////////////////
- if(remateLocalold==1)
- SetPA1RFONOFF(0);PA1statan=0;
- SetPA2RFONOFF(0);PA2statan=0;
- SetPA3RFONOFF(0);PA3statan=0;
- for(i=0;i<3;i++)
- clearchan1();
- //////////////////////pA1 local /////////////////////////////////
- if(Tempter_errorState[0]==0&&output_errorState[0]==0&&input_errorState[0]==0)
- if( remotePA1RFONOFF())
- SetPA1RFONOFF(1);
- else
- SetPA1RFONOFF(0);
- else
- SetPA1RFONOFF(0);
- if(GetPA1RFONOFF()==0&&remotePA1RFONOFF()==0)
- Tempter_errorState[0]=0;
- output_errorState[0]=0;
- input_errorState[0]=0;
- clearchan1();
- //////////////////////pA2 local /////////////////////////////////
- if(!Tempter_errorState[1]&&!output_errorState[1]&&!input_errorState[1])
- if( remotePA2RFONOFF())
- SetPA2RFONOFF(1);
- else
- SetPA2RFONOFF(0);
- else
- SetPA2RFONOFF(0);
- if(GetPA2RFONOFF()==0&&remotePA2RFONOFF()==0)
- Tempter_errorState[1]=0;
- output_errorState[1]=0;
- input_errorState[1]=0;
- //////////////////////pA3 local /////////////////////////////////
- if(!Tempter_errorState[2]&&!output_errorState[2]&&!input_errorState[2])
- if( remotePA3RFONOFF())
- SetPA3RFONOFF(1);
- PA3statan=1;
- else
- SetPA3RFONOFF(0);
- PA3statan=0;
- else
- SetPA3RFONOFF(0);
- PA3statan=0;
- if(GetPA3RFONOFF()==0&&remotePA3RFONOFF()==0)
- Tempter_errorState[2]=0;
- output_errorState[2]=0;
- input_errorState[2]=0;
- void TimingDelay_Decrement(void)
- if (TimingDelay != 0x00)
- TimingDelay--;
- void PAERROR(void)
- int panumber;
- int pa2inputmax=2000;//將PA2、PA3兩個輸入輸出門限提前
- int pa3inputmax=2000;
- int pa2oOutputmin=900;
- int pa3oOutputmin=90;
- int un=0;
- double voldata=0;
- for(panumber=0;panumber<3;panumber++)
- if(TestTempter[panumber]> MaxTempter ||Tempter_errorState[panumber]==1 )//wendu
- Tempter_errorState[panumber] = 1;
- SetPARFONOFF(panumber+1,0);
- else
- Tempter_errorState[panumber] = 0;
- if(input_errorState[panumber]==1)
- else if(panumber==0)
- input_errorState[panumber]=0;
- else if(panumber==1)
- if(PaPower[1]>pa2inputmax)
- input_errorState[panumber]=1;
- InputPA2Dispay(1);
- else if(panumber==2)
- if(PaPower[4]> pa3inputmax)
- //InputPA3Dispay(1);
- //output power+
- if(output_errorState[panumber]==1)
- output_errorState[panumber]=0;
- if(PA1IsOrNotError()==1)
- output_errorState[panumber]=1;
- else if(panumber==1)//0:no,1:red,2 green
- voldata= PaPower[3]-PaPower[2];
- if(PaPower[2]>pa2oOutputmin)
- OutputPA2Dispay(0);
- if(PaPower[1]<pa2inputmax)
- InputPA2Dispay(0);
- Errornumber1=0;
- else if(PaPower[2]<pa2oOutputmin && voldata<50)//todo 50
- Errornumber1++;
- if(Errornumber1>6)
- OutputPA2Dispay(1);
- un=10;
- else
- OutputPA2Dispay(2);
- Errornumber1=0;
- InputPA2Dispay(2);
- if(PaPower[7]<1)
- PaPower[7]=1;
- dataRatio=PaPower[6]*100/PaPower[7];
- if(PaPower[6]<pa3oOutputmin)
- if(PaPower[4]<pa3inputmax)
- Errornumber2=0;
- InputPA3Dispay(0);
- OutputPA3Dispay(0);
- else if(PaPower[6]>pa3oOutputmin && dataRatio<180)//pulse is off
- //printf("%d\r\n",dataRatio);
- Errornumber2++;
- if(Errornumber2>5)
- //OutputPA3Dispay(1);
- else
- Errornumber2=0;
- OutputPA3Dispay(2);
- InputPA3Dispay(2);
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t* file, uint32_t line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* Infinite loop */
- while (1)
- #endif
- PUTCHAR_PROTOTYPE
- /* Place your implementation of fputc here */
- /* e.g. write a character to the USART */
- USART_SendData(EVAL_COM1, (uint8_t) ch);
- /* Loop until the end of transmission */
- while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
- return ch;
- /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
監(jiān)控程序_10.29.7z
(306.32 KB, 下載次數(shù): 53)
2019-1-17 16:08 上傳
dmaadc
